how will i know my cpu is fried?
bacardi9966
99 (0.02/day)
Elk Grove, CA
Processor Intel Core 2 Extreme QX6850 3.0Ghz ( Not overclocked yet)
Motherboard ASUS Striker Extreme
Cooling Vigor Gaming 92mm Eltectric Thermal CPU Cooler
Memory Coirsair Dominator (4 x 1GB) DDR2 1066
Video Card(s) Dual EVGA 8800 Ultra 768MB ( SLI MODE )
Storage 150GB WD Raptor 10,000RPM (2)
Display(s) Samsung 37" HDTV Plasma
Case Antec P82SE Silver-Mirrored Steel Case
Audio Device(s) Supreme FX Onboard Audio
Power Supply ePOWER 1000Watt
Software Windows Vista Home Premium 64bit
please help mei think mines is fried.
d44ve
2,520 (0.38/day)
Processor Intel E6600 @ 4.2GHZ Wo0t!
Motherboard ASUS Striker Extreme & eVGA 680i A1
Cooling Phase Change !!
Memory OCZ SLI 1066MHZ (2GB)
Video Card(s) EVGA 8800 GTX
Storage Western Digital 320 GB
Case Antec 900
Power Supply Lian-Li V2000
Software Vista Ultimate
bacardi9966
99 (0.02/day)
Elk Grove, CA
ummm nothing shows up on my LCD. tried evry goddam method. check my other post. =[[
and no beeping sounds either
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Does it at least post? And if so do you have this problem in safe Mode? and if you do not have the problem in safe mode then lower your resolution and refresh rate and try again on a normal boot.
bacardi9966
99 (0.02/day)
Elk Grove, CA
nothing shows on my LCD....-_- cant even acess BIOS
while startup no beeping..=[
GJSNeptune
2,570 (0.39/day)
Ohio
Processor AMD Athlon 64 X2 5000+ Black Edition
Motherboard Gigabyte GA-MA770-DS3
Cooling Tuniq Tower 120 (with Scythe SFF21E)
Memory 2x1GB Corsair XMS2 DDR2-800 CAS4 DHX
Video Card(s) PALiT 9800GTX 512MB PCI-E
Storage WD2500AAKS, WD1600YS, WD1200JD, WD400EB
Display(s) LG L1920P, Viewsonic VA520
Case Lian-Li A05b (with two 120mm Yate Loon D12SM)
Power Supply Corsair HX520
Software Vista Business 32-bit/XP Pro 32-bit dual-boot
Could be bad memory. Try different sticks or swap them. Try one at a time if applicable.
bacardi9966
99 (0.02/day)
Elk Grove, CA
its not the ram
GJSNeptune
2,570 (0.39/day)
Ohio
Okay. Have you looked at the CPU? Does it smell or look burnt?
d44ve
2,520 (0.38/day)
Case Antec 900
it would help if we knew your system specs too
GJSNeptune
2,570 (0.39/day)
Ohio
Try to give us more than one short sentence.
bacardi9966
99 (0.02/day)
Elk Grove, CA
umm no it doesnt look or smelt burnt.
and my system specs are::
Pentium D 2.8Ghz
Asrock 775Dual-VSTA mobo
2GB PNY DDR2 PC5300 Ram
EVGA 8600GT 256MB GPU
500WATT Psu
160GB WD caviar SE HD
GJSNeptune
2,570 (0.39/day)
Ohio
I have the same board, CPU, and hard drive. Unless you somehow know for sure it's not the memory, please look into it. I had a lot of memory problems with mine where a few sticks would hang the BIOS or not initialize it at all.
2,481 (0.35/day)
Did you plug in the 20/24 pin connector to the motherboard from the PSU?
Did you also plug in the 4 pin power connector on the motherboard from the PSU?
Many people forget the 4 pin connector and if you dont do that than only your fans will spin and nothing else will happen
bacardi9966
99 (0.02/day)
Elk Grove, CA
i know for a fact that its not the ram causing this problem
GJSNeptune
2,570 (0.39/day)
Ohio
We don't. Please explain why. Did you even OC the CPU? Do you run high temps? Your system should shut down if the CPU gets too hot.
bacardi9966
99 (0.02/day)
Elk Grove, CA
never OC'd the cpu before. computer turns on, no beeping sounds, no display =[
GJSNeptune
2,570 (0.39/day)
Ohio
Then it's likely not the CPU. If you're so sure it's not your memory, please explain why you know it's not. (This is the second time I've asked).
6,270 (0.89/day)
New York
check your monitor cable.
bacardi9966
99 (0.02/day)
Elk Grove, CA
lol i checked that first.
2,481 (0.35/day)
Dude did you even look at this.
Check this:
I HAVE HAD AND SEEN THIS ISSUE BEFORE
bacardi9966
99 (0.02/day)
Elk Grove, CA
yes the 4pin has been in the whole time from the start. i would never forget that. =[
i dont think im ever going to overcome this problem
d44ve
2,520 (0.38/day)
Case Antec 900
Have you re-wobbulated the wobbulater recently? It could be that.....
j/k
Seriously though, how do you know its not the ram?
GJSNeptune
2,570 (0.39/day)
Ohio
I'm saying it's the memory until you tell me why it isn't. Or are you ignoring/blocking my posts?
6,270 (0.89/day)
New York
are you able to try a different Monitor all together?
bacardi9966
99 (0.02/day)
Elk Grove, CA
yea done that.
same.
