- Nov 13, 2007
- 11,366 (1.76/day)
- Austin Texas
System Name | Arrow in the Knee |
Processor | 265KF -50mv, 32 NGU 34 D2D 40 ring |
Motherboard | ASUS PRIME Z890-M |
Cooling | Thermalright Phantom Spirit EVO (Intake) |
Memory | 64GB DDR5 7200 CL34-44-44-44-88 TREFI 65535 |
Video Card(s) | RTX 4090 FE |
Storage | 2TB WD SN850, 4TB WD SN850X |
Display(s) | Alienware 32" 4k 240hz OLED |
Case | Jonsbo Z20 |
Audio Device(s) | Yes |
Power Supply | Corsair SF750 |
Mouse | DeathadderV2 X Hyperspeed |
Keyboard | Aula F75 cream switches |
Software | Windows 11 |
Benchmark Scores | They're pretty good, nothing crazy. |
Yes! a black ice quality rad with 9 FPI for ultra low airflow!!!
<<<< I am this excited about this
Those who water-cool knows what this means... HWlabs has always made rads for high flow fans, but now they made a thermochill like rad. Here are the specs:
Black Ice® SR1 radiators feature a custom compressed core width utilizing streamlined 45 micron copper fins giving it unparalleled performance from sub-800rpm to 2000rpm fans and flow constricted systems.
Features:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=200&products_id=25925
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme, Black Ice® GTX and most 120mm form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Fully RoHS compliant.**Expected Q3 2009**
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Carbon Black Finish
- Renowned Black Ice® quality.
- Patent Pending Design.
