i need help copying and pasting inside windows 10 app folders and subfolders
529 (0.12/day)
st. louis missouri
Processor Ryzen 5 5600
Motherboard Asus b450F ROG Strix
Cooling 3 case fans plus deepcool maxx V2 cpu heatsink
Memory 16 GB Crucial Ballistix DDR4
Video Card(s) Zotac RTX 3060 TI
Storage 3 SSD's, 1 Samsung 970 Evo NVME and 2 sata (Crucial 1 TB and ADATA 480 GB) and 2 sata hardrives
Display(s) 27 inch Asus 75hz gaming monitor
Case NZXT h500i black
Power Supply Corsair cx650m 650 watt psu
Mouse Corsair M65 Pro RGB
Keyboard Inland RGB mechanical keyboard with blue optical switches.
Software windows 10 64 bit
Hey guys, ok I have an issue I have just spent the last two hours trying to figure out. Basically I am trying to copy and paste inside a specific windows 10 app folder under program files, but everytime i try do so windows states you need permission to perform this action even though I am the administrator and I have changed the advanced security options to allow me to modify windows 10 app folders under the advanced settings.
In all of my google searching I havent found any solution so far so if anyone here knows to how to do this I would greatly appreciate it and thank you.
18,584 (2.63/day)
System Name AlderLake
"You shall not use any cheat related apps/ trainers on windows 10" :D
529 (0.12/day)
st. louis missouri
thats not what im trying to do. Im just want to copy some files from the apps folder but windows wont let me.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
529 (0.12/day)
st. louis missouri
Its does a little bit, but i have given admin rights to have full access to all the folders in windows apps in program files including the folder im trying to modify and the only account on my pc is mine and im the admin.
However i did not change the
Replace owner on sub containers and objects because i didnt see that option when i was changing those settings.
Il try again when i get home tonight im at work right now thank you for your help.
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Always check the effective permissions against your account. If you're not showing as the owner and every permissions check box ticked, then you'll see problems like this.
I'm interested to see how you get on. :)
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
I've never heard of that one either o_O ...apparently user level control policies abound.
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
MS made it really difficult for users to get permission to several folders, you have to take ownership first then add full control then change effective permissions. I think. Oh and you need to jump thru the flaming hoops like a good little doggy.
It really is a chore to disable Cortana. It's doable.
529 (0.12/day)
st. louis missouri
Where is the setting for that? And il definitely let you know how it goes.
This one of the biggest pains in the ass i have dealt with within windows, but i like a challenge.
Ok but that setting was on the page you linked me to go to.
Maybe its a new setting in win 10.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Yes, I've never seen it before myself. Let us know how it pans out.
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
See first screenshot below.
- Open file properties (left hand window)
- Click Advanced
- Advanced Security Settings opens (right hand window)
- Click on the Effective Access tab
- Click Select a user and enter your username in the dialog box, then click OK
- Click on View effective access
Check permissions, see second screenshot. Full Control should be ticked and by definition all the other tickboxes as well. You should be the owner too.
Note that I've had cases where even with this complete level of access I could sometimes not access a file or folder properly no matter what I did, especially with system folders or app installation folders.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I've had this issue before with earlier versions of 10 after upgrading, mostly with other HDD's. Resetting ownership permissions and rebooting generally resolved it though.
It can definitely be annoying and the permissions change isn't necessarily going to resolve during the current live session, so after making ownership changes, do consider performing a log off/log on or reboot.
http://www.tenforums.com/general-su...ays-i-dont-have-permission-save-anything.html
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
You'd think you wouldn't need to log off/on after a simple thing like this, but you're right, you sometimes do. :wtf:
I remember the times when I had the most trouble with taking ownership of files and folders. When I had a HDD connected as a slave with another (usually old and borked) Windows install on it that I wanted to get data off and generally have a nose around with. Those pesky OS folders containing the core of the Windows installation just wouldn't submit to my ownership properly no matter what I did. Why, I have no idea and it was infuriating. There was no encrytion on it, either.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Just throwing it out there, but I've seen the permission error get thrown when trying to delete something that is in use. Windows is stupid like that sometimes...
529 (0.12/day)
st. louis missouri
Ok guys, il give this all a try later tonight or tomorrow and let you all know how it goe. Thanks for all the help
529 (0.12/day)
st. louis missouri
ok I have made some progress. I am able to modify and copy and paste to the windows apps main folder but not the app I want to access. I get the error message destination folder access denied whenever to try. Well I am done for tonight. if anyone else has an idea feel free to share and thank you all again for the help.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Sometime program files aren't located where they appear to be. Which would explain why you cant move them
529 (0.12/day)
st. louis missouri
Im not trying to move anything just trying to copy some files into the app folder but the throws that error message destination folder access denied.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
  • Can you give us the specific locations you are copying from and to?
  • Can you take screenshots of what's going on?
  • Can you take screenshots of the ownership of the directory you're experiencing issues with?
If you're not comfortable sharing that information, I do understand...but I feel like what was suggested before should've resolved it. Have you tried modifying ownership at the hard drive level? Did you log off/log on or reboot after changing ownership permissions?
Possibly check Event Viewer security and system logs as well, might be something else...but likely you are getting closer to resolving this just don't have all the permissions adjusted accordingly. But maybe more specific details about your issue, where things are located that you're having issues with, etc. will assist us better in telling you what needs to be done to accomplish what you're seeking to resolve.
:toast:
529 (0.12/day)
st. louis missouri
Im trying to copy over a file so i can use my gamepad with a game thats installed in that location but i need to copy the files to use the gamepad. I sort of found a workaround. I copied the entire folder of the game to a different location on my harddrive and was able to copy the files that way but i had to redownload the game which is annoying, but luckily the files I copied didnt get deleted or over ridden.
the game is still downloading so i havent been able to test it just yet so finger crossed everything works correctly, if not il provide screenshots and update everyone.
831 (0.26/day)
System Name Gaming Desktop
Processor i7 6700k
Motherboard asus rog alpha
Cooling H110i
Memory Corsair Dominator 16gb DDR4 3200
Video Card(s) GTX 1080
Storage EVO 840 500gb, EVO 850 500gb, Perc 710 Raid WD RED 4tbx4
Case Corsair 500r
Power Supply Antec 850
Mouse Logitec G502
Keyboard a cheap dell
this is the best solution. giving you're user account rights to the "program files" folder is an unnecessary security risk.
that being said the best way of getting files into program files is open a command prompt as administrator. and copy the files from the command prompt. dragging and dropping the files generally doesn't invoke the UAC prompt to escalate your privileges.
even though your account is an administrator, UAC will stomp all over permissions when it is trying to protect you from yourself.
8,246 (2.09/day)
SE Michigan
System Name Dumbass
@qubit Sometimes, depending on fold you have to disable inheritance, if the OP's fold is nested deep, more than likely it still has inherited permissions.
There is also Powershell to change permissions, althought I am still learning, there are scripts out there.
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
Thing is disabling inheritance could be impractical as there may be hundreds of folders and thousands of files, depending where on the HDD you start from. Typically, if I'm looking around that old defunct Windows install on a slave HDD that I'm gonna wipe afterwards, I'll start from the root and let inheritance change the permissions on every single file and folder. Doesn't always work perfectly though and it's not clear why. Even rebooting the PC doesn't always help.
8,246 (2.09/day)
SE Michigan
System Name Dumbass
It depends what you need to accomplish, I dont recommend it lightly, its something to change only when absolutely necessary. Besides, it affects windows security, if you should have a virus or a hacker they could have access to something they normally wouldnt.
Now if I really wanted a windows app removed, I use Powershell, but even then M$ reinstalls the app on the next update whether you want it or not.
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
Yes, it would affect security, but I'm talking about doing this to a Windows install that I'm going to scrap which is sitting on a slave drive (or another partition) not the active Windows installation so this isn't an issue.
