- Apr 28, 2007
- 1,193 (0.18/day)
- Bellevue, WA
System Name | 0BL1V10N |
Processor | Intel Core i7 11700K @ 5.1GHz all-core turbo |
Motherboard | ASRock Z590 Taichi |
Cooling | Cooler Master MasterLiquid 360 (with stock CM fans), 12x Pccooler Moonlight Series ARGB 120mm fans |
Memory | (4x16GB) 64GB Mushkin Redline Lumina 3600MHz 16-19-19-39 XMP |
Video Card(s) | MSI RTX 4090 SUPRIM LIQUID 24G (not using stock fans) (+150MHz core, +1000MHz memory) |
Storage | Western Digital Black SN850X 2TB Gen4 NVMe |
Display(s) | 1x Alienware AW3821DW (3840x1600@144Hz), 2x Dell SE2717H (1080p@75Hz) |
Case | Phanteks Enthoo 719 Anthracite Grey |
Audio Device(s) | Schiit Modius + Drop THX AAA 789 + Custom Planar Magnetic Headphones |
Power Supply | Thermaltake Toughpower GF3 1200W (12VHPWR) |
Mouse | Logitech G502 X Plus |
Keyboard | Too many custom mechanical builds to list... |
Software | Windows 10 Pro 22H2 |
At first I thought how WHS does it's drive management was dumb but it really makes sense and enables one to have a crap ton of storage with basic hardware. The only limitation is the # of drives. I just happened to have a lot of them.
I don't see adding anymore drives, I don't have anymore free bays nor do I have any free IDE or SATA connections. 17 is the MAX. Anything else would have to be external.
What I do see is slowly replacing the little drives with bigger ones but I doubt I will lessen the # of drives. I mean if I get a stable rig running I don't see any reason aside from money that I wouldn't eventually replace them all with 1TB or higher.
Think of my server as a rackmount without the rackmount part. A typical 4U rack can hold at least 20 drives. My only issue is power, which is solved for the time being till I get a better PSU.
Someone has suggested a 650w Antec Earthwatts for about $80 but is there anything else? I looked at the Rosewill suggested here but I don't know if I trust that many drives on it.
