I think my Router is causing latency/intermittent connections
Darin
2 (0.00/day)
I have Time Warner Cable with 50Mbps and this problem only occurs when I am connected from my modem (Arris1670a in bridge mode) to my Router (WNDR3400) and then hardwired from router to computer. This affects my wifi also. When I plug the modem directly into my computer I have almost zero lag and pages load instantly. This is a relatively new issue and nothing has changed that I know of to cause it. I'm thinking it must be my router since everything works great when I bypass it??
Here are a couple of pings / tracerts that I ran. I'm not real good at interpreting them. I use 8.8.8.8 / 8.8.4.4 as my DNS
ping my router...
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=55ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=56ms TTL=64
Reply from 192.168.1.1: bytes=32 time=30ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=272ms TTL=64
Reply from 192.168.1.1: bytes=32 time=68ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=71ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 57, Received = 57, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 272ms, Average = 10ms
tracert google....
Tracing route to google.com [216.58.194.206]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 15 ms 27 ms 16 ms tge0-9-0-17.vntrcamv01h.socal.rr.com [76.167.29.197]
4 24 ms 32 ms 59 ms agg21.vnnycajz02r.socal.rr.com [72.129.14.92]
5 * * * Request timed out.
6 * 24 ms 19 ms bu-ether16.tustca4200w-bcr00.tbone.rr.com [66.109.6.64]
7 * * * Request timed out.
8 * * 43 ms 216.156.65.225.ptr.us.xo.net [216.156.65.225]
9 58 ms 49 ms 55 ms 216.156.65.102.ptr.us.xo.net [216.156.65.102]
10 * 62 ms 48 ms 64.233.174.238
11 145 ms * * 64.233.175.150
12 48 ms 38 ms 42 ms 64.233.174.205
13 40 ms 36 ms 36 ms 209.85.246.21
14 31 ms 37 ms 36 ms 72.14.238.189
15 38 ms 43 ms 51 ms sfo03s01-in-f14.1e100.net [216.58.194.206]
You tried reseting the router? New firmware? DD WRT ?
Bypass the router with direct connection to see if router is causing it or not.
