I thot DX11.1 should come with Shader Model 5.1 & DirectCompute 11.1?
875 (0.16/day)
Nairobi, Kenya
Processor Intel Core Ultra 7-265K
Motherboard ASUS ROG STRIX Z890-A
Cooling ID-Cooling FROZN A620 Pro SE
Memory Crucial Pro 96GB Kit (48GBx2) DDR5-5600
Video Card(s) Intel ARC A770 Limited Edition
Storage Solidigm P44 Pro 2TB x 2 / Sk Hynix Platinum P41 2TB
Display(s) Philips 32M1N5800A
Case Lian Li O11 Air Mini (White)
Power Supply Seasonic Prime Fanless Titanium 600W
Keyboard Dell KM714 Wireless
Software Windows 11 Pro x64
I thought DX11.1 should come with Shader Model 5.1 & DirectCompute 11.1?
But this is not the case instade AMD Radeon 7970 claims DX11.1 bit it has Shader Model 5.0 & DirectCompute 11.
I thought for the full features of DX11.1 to function the hardware should have Shader Model 5.1 & DirectCompute 11.1
Previous gen DX10 and DX10.1 hardware had shader Model 4.0 & 4.1 respectively, so as DirectCompute 10 & 10.1 respectively.
Does that mean that the upcoming hardware has no significant deference with current gen hardware in terms of hardware in handling Dx11 & 11.1?
And does that mean that current gen hardware can handle DX11.1? every other key details in terms of handling Direct X are same. apart from the coming GPU are just faster in general,....
W1zzard
Administrator
28,637 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
afaik dx 11.1 does not have any new shader instructions, so sm 5.0
875 (0.16/day)
Nairobi, Kenya
AMD Radeon Spex from http://www.amd.com/us/products/desktop/graphics/7000/7970/Pages/radeon-7970.aspx#3
Up to 925MHz Engine Clock
3GB GDDR5 Memory
1375MHz Memory Clock (5.5Gbps GDDR5)
264GB/s memory bandwidth (maximum)
3.79 TFLOPs Single Precision compute power
947 GFLOPs Double Precision compute power
GCN Architecture
32 compute units (2048 Stream Processors)
128 Texture Units
128 Z/Stencil ROP Units
32 Color ROP Units
Dual Geometry Engines
Dual Asynchronous Compute Engines (ACE)
PCI Express 3.0 x16 bus interface
DirectX® 11-capable graphics
9th generation programmable hardware tessellation units
Shader Model 5.0
DirectCompute 11
Accelerated multi-threading
HDR texture compression
Order-independent transparency
OpenGL 4.2 support
Partially Resident Textures (PRT)
Ultra-high resolution texture streaming
Image quality enhancement technology
Up to 24x multi-sample and super-sample anti-aliasing modes
Adaptive anti-aliasing
Morphological Anti-Aliasing (MLAA)
16x angle independent anisotropic texture filtering
128-bit floating point HDR rendering
AMD Eyefinity multi-display technology1
Up to 6 displays supported with DisplayPort 1.2 Multi-Stream Transport
Independent resolutions, refresh rates, color controls, and video overlays
Display grouping
Combine multiple displays to behave like a single large display
AMD App Acceleration2
OpenCL 1.2 Support
Microsoft C++ AMP
DirectCompute 11
Double Precision Floating Point
AMD HD Media Accelerator
Universal Video Decoder (UVD)
H.264
VC-1
MPEG-2 (SD & HD)
MVC (Blu-ray 3D)
MPEG-4 Part 2 (DivX/Xvid)
Adobe Flash
DXVA 1.0 & 2.0 support
Enhanced Video Quality features
Advanced post-processing and scaling
Deblocking
Denoising
Automatic deinterlacing
Mosquito noise reduction
Edge enhancement
3:2 pulldown detection
Advanced video color correction
Brighter whites processing (Blue Stretch)
Independent video gamma control
Flesh tone correction
Color vibrance control
Dynamic contrast
Dynamic video range control
AMD HD3D technology4
Stereoscopic 3D display/glasses support
Blu-ray 3D support
Stereoscopic 3D gaming
3rd party Stereoscopic 3D middleware software support
AMD CrossFire™ multi-GPU technology5
Dual, triple or quad-GPU scaling
Cutting-edge integrated display support
DisplayPort 1.2
Max resolution: 4096x2160 per display
21.6 Gbps bandwidth
High bit-rate audio
Quad HD/4k video support
3GHz HDMI 1.4a with Stereoscopic 3D Frame Packing Format, Deep Color, xvYCC wide gamut support, and high bit-rate audio
Max resolution: 4096x3112
1080p60 Stereoscopic 3D
Dual-link DVI with HDCP
Max resolution: 2560x1600
VGA
Max resolution: 2048x1536
Integrated HD audio controller
Output protected high bit rate 7.1 channel surround sound over HDMI with no additional cables required
Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
AMD PowerPlay™ power management technology3
Automatic power management with low power idle states
AMD PowerTune technology3
Intelligent TDP management technology
Dynamic clockspeed/performance enhancement for games
AMD ZeroCore Power3
Ultra-low idle power when the system’s display is off
Secondary GPUs in an AMD CrossFire™ configuration power down when unneeded
AMD Catalyst™ graphics and HD video configuration software
Software support for Windows 7, Windows Vista, and Windows XP
AMD Catalyst™ Control Center - AMD Catalyst™ software application and user interface for setup, configuration, and accessing features of AMD Radeon products
Unified Graphics display driver - AMD Catalyst™ software enabling other PC programs and devices to use advanced graphics, video, and features of AMD Radeon™ products
875 (0.16/day)
Nairobi, Kenya
So does that mean that even current DX11 cards can run DX11.1, is this the same scenario as DX9 - 9c where all the hard ware that could run Dx9 ware capable of running dx9c?
Over_Lord
764 (0.14/day)
Hyderabad
System Name BAH! - - tHE ECo FReAK
Processor Athlon II X4 620 @ 1.15V
Motherboard ASUS 785G EVO
Cooling Stock
Memory Corsair Titanium 4GB DDR3 1600MHz C9
Video Card(s) Sapphire HD5850 @ 1.049v
Storage Seagate 7200.12 500GB
Display(s) BenQ G2220HD
Case Cooler Master Elite 334
Power Supply Corsair VX550W
I'm happy actually. Won't make the DX11 card owners suddenly feel alienated.
Again a possibility MS are adding those features specifically which will be a part of next gen XBox GPU
Athlon2K15
HyperVtX™
7,909 (1.16/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
The following functionality has been added in Direct3D 11.1.
•Shader tracing
•Direct3D device sharing
•Check support of new Direct3D 11.1 features and formats
•Create larger constant buffers than a shader can access
•Use logical operations in a render target
•Force the sample count to create a rasterizer state
•Process video resources with shaders
•Change subresources with new copy options
•Discard resources and resource views
•Support a larger number of UAVs
•Bind a subrange of a constant buffer to a shader
•Retrieve the subrange of a constant buffer that is bound to a shader
•Clear all or part of a resource view
•Map SRVs of dynamic buffers with NO_OVERWRITE
•Use UAVs at every pipeline stage
875 (0.16/day)
Nairobi, Kenya
How so? can Current Direct X 11 cards run Direct X 11.1?
875 (0.16/day)
Nairobi, Kenya
•Shader tracing
Will this work on current gen GPUs?
1,238 (0.19/day)
SoCal
Processor AMD Phenom II 1055T @ 3.6ghz 1.3V
Motherboard Asus M5A97 EVO
Cooling Xigmatek SD1284
Memory 2x4GB Patriot Sector 5 PC3-12800 @ 7-8-7-24-1T 1.7V
Video Card(s) XFX Radeon HD 7950 DD @ 1100/1350 1.185V
Storage OCZ Agility 3 120GB + 2x7200.12 500GB Raid1
Display(s) QNIX QX2710 27" LCD 1440p @ 120hz
Case Cooler Master 690M
Power Supply Enermax Liberty 620W Eco Edition
Software Windows 7 Professional x64 / Ubuntu 12.04 x64
Doubt it. And it wasn't the case that all DX9 cards could runs DX 9.0c content. I couldn't play BioShock on my x800, because it was missing shader model 3.0. I had to get some 3rd party patch to disable the SM3.0 stuff to be able to play it (although I later upgraded to an HD 3850 that beasted it just fine).
875 (0.16/day)
Nairobi, Kenya
Ok not all coz of the deference in shader model, but i meant with the ones that had a card with SM3 or SM4 and had DX9c, even SM2 could ran DX9c.
So i mean since every other details are same in the sense of eg SM5.0 can run DX11 or DX11.1 if so then current hardware can run DX11.1
2,750 (0.44/day)
Minnesota
I've heard that current DX11 cards might support DX11.1. Sort of how OpenGL support increases with drivers (up to a point). But yes, as far I know it will stay at SM5.0. Don't know about DirectCompute though.
