I want to build a system, into an empty XBOX360 case. Is it possible?
494 (0.10/day)
Hesperus IV
System Name Salvaged
Processor AMD Phenom II X6, 1055T
Motherboard MSI (cant remember model..)
Cooling Antec Kühler + extra fans (Antec, Zalman, Coolermaster, Generic brand)
Memory 8Gb (2 x 4Gb)
Video Card(s) ATI Radeon HD6870
Storage Samsung 1TB, 320 Seagate, 250 Samsung
Display(s) LG Electronics
Case ANTEC Sonata III 500 (found/salvaged + modified)
Audio Device(s) 8Ch + Harman Kardon 2.1 (modified, electronics in JVC wood speakers)
Power Supply It's made in Denmark, never seen a PSU made there..
Software Win7 X64 Ultimate
As title says, and what I would like to know: Is it possible to modify the XBOX 360 case so it could fit say an mATX motherboard inside it?
I do have an empty XBOX 360 case (not slim), even the strange looking "dual" fan.
Also, I have an empty NES case..
Looking at youtube vids would sugest its possible but i have no idea where you would start.
The biggest problem is the PSU, what do you have in mind for this "rig"? [Gaming, MediaPC]
Your best option is to run the PSU externally, and I am doubting a full size GPU would fit. What is this PC going to be used for? If its a media center style then I would recommend a 5800K APU and 8GB DDR3 low profile. also use a 2.5 SSD and mount a custom DVD-RW. Its do able but def the PSU will have to be outside. I have seen pretty powerful PSU's like a standard Xbox 360 PSU being used on a ATX motherboard but would do some research on that.
yes its possible also with ps3 fat, but no discrete GPU only integrated so a 5800K or similar like brandon said
Yes. Go with an mini ITX board, A10-5800K as suggested, and get a slim PSU in the 300W range. It should fit into the case with little issue. The problem will be proper cooling.
Be cool to mount a H60/80 on the back of the case and the pump should set inside nicely due to the lower profile design.
Hey, thanks everyone!
This is what I need to get it running:
Motherboard: ASUS F2A85-M Pro
CPU: A10-5800K Black Edition
Memory: Kingston ValueRAM 4GB * 2 DDR3
HDD: Kingston 120GB SSDNow V+200 (2.5")
Optical drive: Sony-NEC-Optiarc SNO BR Combo
PSU This was a bit tricky, so a friend of mine who is a trained and certified electrician looked at the XBOX and said he could 'build' me a PSU for it. The parts will be bought from Elfa Distrelec, and tested before installation.
The "rig" is mainly for entertainment, like a media PC.
About cooling the entire thing, I was thinking myself of watercooling since everything would rather crowded in the box itself.
This is nothing I'm going to build today or tomorrow, but something to do when I have looked it over completely. Because when I start - there is no going back..
Nice xbox Media PC.
when you finish it post some pictures of it.
Hey...an XBox worth a shit for gaming!
Cool project, man.
Nice idea
