Iiyama Red Eagle GB3461WQSU Monitor sometimes does not display despite turning on
6,555 (1.11/day)
Midlands,UK
System Name Reborn|Partner
Processor AMD Ryzen 9600x|AMD Ryzen 7 5700x
Motherboard Asrock B650m Pro-RS|Asus B550m Prime Wifi
Cooling Arctic cooling freezer 34 white + Montech 120mm | Thermalright Silversoul 135 + Corsair 140mm white
Memory Corsair Vengeance DDR5 32GB 6000mhz|Corsair Vengeance DDR4 16GB 3200mhz
Video Card(s) XFX AMD RX 9070XT Swift Black 16GB| Zotac Nvidia RTX 4080 Super Trinity black edition 16GB
Storage 2x2TB WD Black SN1700|WD Blue 500GB NVME,Kingston 240GB SSD,2TB Corsair NVME
Display(s) AOC Gaming CU34G3S/BK | Iiyama XUB2792QSU gen 2 + Iiyama XUB2792QSU gen 1
Case Montech Air 100 White| Corsair Carbide Air 240 White
Audio Device(s) onboard/Speakers: Logitech G560 | onboard/Speakers: Sanyun SW208 white 2.0
Power Supply Seasonic Focus GX 850w Gold Modular | Corsair RMx White 750w Gold Modular
Mouse Microsoft Pro Intellimouse shadow | Razer Deathadder Essential white
Keyboard Epomaker mechanical keyboard| Razer huntsman v2
Hello all, I've been dealing with this problem every now and then since last year I believe, where the monitor would turn on with the led indicating it's turned on but all it display is a black/grey/white screen, then it eventually goes into standby.
If I was to turn on my PC it detects the DP signal, but does not display anything properly.
The same goes with my MacBook that is connected via HDMI.
I initially thought it was one of my LED lights interfering with the IPS panel detection,so I've made sure there is no LED lights around the desk that is turned on(my speakers have bright RGB built in) and LED strip on the wall but that's not the case now.
The quickest fix seems to be to just continuously force it to power cycle by unplugging the power plug and plugging it back in until it displays.
Has anyone experienced this before with their IPS monitors? If so is there anything that can be done about it? I'm probably past the warranty period now so getting it RMA for repair may be out of the question.
These kind of things makes me fed up on tech sometimes, I had an issue with my previous monitor, the Samsung g5 35inch, where it wouldn't turn on properly sometimes and the job button was faulty after few months of use and now this monitor is giving me a headache.
I would upload a short clip but the file too large.
I experienced something close to this with a much older Samsung monitor that its power module pcb blew out on. I power cycled it, it got worse real fast and then killed itself. Other than that, the only other thing it could be is windows display settings or the power options settings telling the pc to turn off the monitor immediately for some reason.
