I'm crashing every once in a while. help me please
1,205 (0.19/day)
Huntington Beach CA
System Name ROG MACHINE
Processor Ryzen 9 5950x
Motherboard Crosshair viii Hero
Cooling NZXT Kraken Z 73 my corsair H115i kicked the bucket corsair sucks lol
Memory g-skill rgb 64gb 4x16gb ddr4 3200mgz
Video Card(s) MSI Ventus 3x oc 3080
Storage Samsung 990 pro 4TB M.2 Samsung 980 pro 2TB M.2 two 16TB Seagate Iranwolf HD 10TB and a 12TB ironwol
Display(s) Samsung Odyssey G9 49-inch Monitor/ Samsung C34J79x 34 inch curved monitor
Case thermal take view 71 rgb
Audio Device(s) creative ae-5 sound card
Power Supply Seasonic Vertex 12 watt power supply
Mouse ROG CHAKRAM
Keyboard Rog Strix Flare II Animate Keyboard
Software windows 11 pro 64bit
my system has been crashing every few days and twice today. i reinstalled the video drivers after uninstalling them and using driver sweeper to clean out the left over stuff but still get crashes. bluescreanveiw shows dxgkrnl.sys and dxgkrnl.sys+5d000 to be the cause can some one help me?
What is the error code of the BSOD?
Also, it helps to know when the problem first occurred. What changes, if any, were made before then? When does the problem typically occur? Are you overclocking? etc.
BTW, that file is related to DirectX, so you could try re-installing that.
i think i was installing a old game about 3 weeks ago and when it installed the directX there was some errors so that could be the prblem i just don't know how to fix it.
ok just updated dx ill let you know if the bsod's stop thanks for your help
so far so good no crashes knock on wood.
Sweet, glad to hear that. Let us know if you have any more crashes or problems :toast:
PSU going out would be my guess.
well i just crashed again its lasted for a long time the crash is
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA800BC1D4E0
BCP2: FFFFF8800F3DE520
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
if that helps
Give us the crash log, you can use whocrashed too
how do i get the crash log? and here is what whocrashed said
System Information (local)
computer name: TIMOTHY-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD Phenom(tm) II X4 940 Processor AMD586, level: 16
4 logical processors, active mask: 15
RAM: 8588353536 total
VM: 2147352576, free: 1932070912
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 6/2/2011 10:59:50 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\060211-23103-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x164520)
Bugcheck code: 0x116 (0xFFFFFA800BC1D4E0, 0xFFFFF8800F3DE520, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 270.61
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 270.61
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 270.61 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation VIDEO_TDR_ERROR
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl!TdrResetFromTimeout+0x214)
file path: C:\Windows\system32\drivers\dxgkrnl.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics Kernel
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
well i just updated the driver to 275.33 that was released on 6/1/2011 i hope that fixes the problem.
Are you overclocked?
just a little bit the multiplier is set from 15 to 16 and a 3% over clock on the fsb so my cpu is at 3.3 and memory is at 1100
the video card is not over clocked
well so far after driver update there has been no crashes i hope it stays that way
