Incorrect VRAM usage displayed in MSI Afterburner
59 (0.02/day)
Sydney Australia
Processor i7 5930k
Motherboard MSI X99 SLI PLUS
Cooling Corsair H110i
Memory G.Skill DDR4 2400Mhz
Video Card(s) Gigabyte GTX 1080ti FE
Storage Samsung 256GB 840 Pro SSD x 2, Seagate 4TB Sata 3 HDD 64MB
Display(s) BenQ XL 2420Z 144Hz 1080p
Case Fractal ARC XL Full Tower
Audio Device(s) Bose USB Audio
Power Supply Seasonic 1050W 80 Plus Platinum
Keyboard Logitech 510s
Software Windows 7 64Bit Home Premium
Hi.
I have a Sapphire R9 290X Vapor-X 8gb and ran the Shadow of Mordor Benchmark in Ultra which supposedly needs 6Gb VRAM to run properly. I ran the benchmark and my VRAM as displayed in MSI Afterburner displayed a maximum of about 4.3Gb VRAM and then dropped to about 358Mb VRAM. I know that it should have been using over 5Gb VRAM but did not display properly. I have adjusted the VRAM limit in Afterburner to read 8192 so I know this is not the cause. Latest drivers are installed, Operating System Windows 7 Home Premium. Any ideas why this is happening? Thanks heaps.
44,274 (6.80/day)
Sounds like the game doesnt need more than 5GB
Hi.
59 (0.02/day)
Sydney Australia
Processor i7 5930k
Thanks but I do not understand how this relates to my problem, I must be missing something..........
44,274 (6.80/day)
Check gpuz if it shows 8192mb (8Gb)of ram then your card and drivers are fine.
You might want to checkout trixx
59 (0.02/day)
Sydney Australia
Processor i7 5930k
Yep here is what GPUZ says:
44,274 (6.80/day)
Sounds like a game problem or Msi Afterburner is goofed up.
3,471 (0.60/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
If you think it might be a problem on Afterburner's side, go ahead and report it over at Guru3d forums. [Mod. Edit. **Post in a civil manner please**]
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
The amount of vram used is dependent on a lot of factors, not just the "Ultra" settings. What screen resolution, other eye candy settings like AA and AF etc. They say 6gb because that's really the minimum you want to game at those settings decently. Doesn't really mean you'll see usage at 6gb all the time.
There's really nothing wrong with afterburner or gpuz
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Try running GPU-Z and select the "sensors" tab. Run it in the background while the game is running. Then check the sensors tab.
Also, just because the game says it requires 6Gb's of VRAM, doesn't mean it's going to use it all the time or in the benchmark. There may be very few situations where it actually requires it. It is also dependent on the actual video card and GPU architecture, instructions, algorithms, features, etc.
59 (0.02/day)
Sydney Australia
Processor i7 5930k
I am not speaking about the VRAM requirements for the game, only the fact that once the memory display exceeds about 4.3gb the display down down to about 358mb or so. I do believe the game uses a lot more than 4gb as some users with Titans have reported over 5gb usage. This is at 1080p, but this is not my issue.
I have ran GPUZ and MSI logs and the peak recorded VRAM usage is in agreement with the OSD.
W1zzard
Administrator
28,613 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Oh, so you are saying, once the memory usage goes beyond 4.3 GB, it will be displayed as ~350 MB ? Does this happen in GPU-Z as well? (second tab)
59 (0.02/day)
Sydney Australia
Processor i7 5930k
Correct, and is happens in GPUZ as well according to the log file. See log file below. See how to only goes to 4.3gb and then drops to 252 which is not right.
W1zzard
Administrator
28,613 (3.74/day)
Memory 48 GB
I could imagine some bug where the variable wraps around at 4 GB, not sure why it is able to go slightly above that then.
My best guess is AMD driver bug (surprise!), because I've seen GPU-Z report more than 4 GB VRAM usage just fine on NVIDIA, and I think on AMD too (not 100% sure and don't have a card to test).
OneMoar
There is Always Moar
8,837 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
SOM: benchmark is fairly light real world usage in game will be about 30% to 40% more then the benchmark
there is nothing wrong here
44,274 (6.80/day)
If the games run smoothly theres nothing to report.
-unsub-
43,629 (6.36/day)
Here you go.. though my card only has 3gb of VRAM:
43,629 (6.36/day)
1 (0.00/day)
Processor i7 3820@4.3Ghz
Motherboard GA-X79-UD5
Cooling Corsair H60V2
Memory 8x4GB Corsair Vengeance 1666MHz
Video Card(s) Sapphire HD7970 Ghz Vapor-X 6GB
Storage 4x1TB WD RED, 3TB WD Green, 256GB Samsung 830, 1TB Samsung 840 EVO
Display(s) Samsung LE40F86BDX, 2xLE40D550
Case Antec P193 V3
Power Supply Seasonic X-760
Software Windows 7 x64 Pro
Hello,
I registered just now because at last, I found that I was not alone anymore with this odd behavior...
I have a Sapphire 7970 6GB, and with Star Citizen I noticed the very same problem:
In the beginning I was wondering about a monitoring issue (which then would be a non issue), but as I remembered that with Watch Dogs, while I play with everything on Ultra+HDAO&TSAAx2 at a solid 30FPS VSync, when I set MSAAx8 I have a tremendous performance drop (compared to MSAAx4) while the VRAM usage drop from ~4GB to about 400-700MB (off the top of my head).
SC on the other hand seems to trash textures when reaching this limit, and I even remember seeing some FPS increase then (not systematical, thought).
As both GPU-Z and Process Explorer report the same VRAM consumption, but above all, as it has concrete consequences, it is definitely not a monitoring issue.
I once monitored the VRAM usage by launching multiple games to try and get a clue if it could be a per application dependency of whatever, (I went with WD, SC, SWTOR, LOTRO on multiple separate screen at the same time) and every time the global GPU cap was around ~4300MB.
So, I am also suspecting some kind of driver problem.
AFAIK, there is a 4GB VRAM resource limit for DX9 applications, but as we are talking about DX11 games, this should not be an issue; nevertheless I am wondering if a Mantle game could give a different result.
19,379 (3.46/day)
QFT...
138 (0.03/day)
System Name URBAN303
Processor AMD Ryzen 7 2700X
Motherboard AORUS B450 PRO
Memory 64 GB ( 4x 16GB Corsair Vengeance 2400Mhz )
Video Card(s) (Crossfire Sapphire Vega 64 Nitro+)
Storage SSD1 Corsair MP510 Nvme 2TB (PCIE 3.0 x4) / SSD2 Crucial S3 2TB / SSD3 Kingston S3 480 / 4TB Seagate
Display(s) 3x AOC 24" Borderless FreeSync!
Case Corsair 500R
Audio Device(s) Native Instrument Audio 6 MK2
Power Supply Corsair RM 1000 - 1000W 80+Gold
Mouse Logitech G300s
Keyboard Logitech G910
Software Windows 10 Pro 64bits
To use your 8GB vram, use multiple screens via Eyefinity :)
On my cfx euro truck simulator 2 (triple screens) 5760x1080 uses more 5700mb of vram + 700mb of dynamic memory ;)
note : While technically I have 2x R9 280X Toxic ...
59 (0.02/day)
Sydney Australia
Processor i7 5930k
Actually COD Advanced Warfare seems to uses well over 4gb memory when using 4x SS and Shadow of Mordor also on ultra. The question I was asking though is the discrepancy with MSI Afterburner in displaying correct VRAM usage.
138 (0.03/day)
Case Corsair 500R
Trust GPU-Z software and use the log AIDA64 hardware monitoring. You will see the memory usage of your video card :)
edit : 5107 Mb dedicated memory + 551 Mb dynamic memory in this example with Assetto Corsa on 5760x1080 (triple screens). (2x R9 280X Toxic 3GB)
59 (0.02/day)
Sydney Australia
Processor i7 5930k
Thank you for that. How do I enable hardware monitoring in AIDA64? I have looked through but must be missing something!
138 (0.03/day)
Case Corsair 500R
To activate Aida64 monitoring :
1°/ go to "Files" > "Preferences"
2°/ At the bottom of the column go to "In Connecting"
3°/ Check the values that you want to appear.
4°/ Check "Save sensors readings in an HTML file"
that's it all
* but i translate from french .... so see below :
