imperialreign
- Jul 19, 2007
- 7,043 (1.08/day)
- Sector ZZ₉ Plural Z Alpha
System Name | УльтраФиолет |
Processor | Intel Kentsfield Q9650 @ 3.8GHz (4.2GHz highest achieved) |
Motherboard | ASUS P5E3 Deluxe/WiFi; X38 NSB, ICH9R SSB |
Cooling | Delta V3 block, XPSC res, 120x3 rad, ST 1/2" pump - 10 fans, SYSTRIN HDD cooler, Antec HDD cooler |
Memory | Dual channel 8GB OCZ Platinum DDR3 @ 1800MHz @ 7-7-7-20 1T |
Video Card(s) | Quadfire: (2) Sapphire HD5970 |
Storage | (2) WD VelociRaptor 300GB SATA-300; WD 320GB SATA-300; WD 200GB UATA + WD 160GB UATA |
Display(s) | Samsung Syncmaster T240 24" (16:10) |
Case | Cooler Master Stacker 830 |
Audio Device(s) | Creative X-Fi Titanium Fatal1ty Pro PCI-E x1 |
Power Supply | Kingwin Mach1 1200W modular |
Software | Windows XP Home SP3; Vista Ultimate x64 SP2 |
Benchmark Scores | 3m06: 20270 here: http://hwbot.org/user.do?userId=12313 |
alright, here's the scenario up to now
between last night and this morning, the HAL.dll library in System32\ up and disappeared, which prevented WIN from booting up this morning - I'd get an error right after POSt and just prior to the boot screen. I went through all the recovery console routines, rebuilding the boot.ini, making sure the boot partition was alright, expanding the .dl_ from the WIN XP CD, etc. Nothing worked. The OS would just lockup at the boot screen . . .
so, I did a repair installation, which left all my hardware drivers and all in limbo, and all apps and drivers had to be removed and then re-installed . . .
but, now I'm getting errors with applications that access the SYS itself - SpeedFan, PC Probe, ASUS AI Suite, Audio Console, etc - at app startup, they tend to return errors citing invalid address, or other hardware access errors . . .
which, leads me to assume that WIN needs the chipset drivers re-installed. That'd be fine, except that the repair installation doesn't remove these drivers, and because WIN doesn't actually see anything wrong with them (no flag in System Properties dialog), and they're not out of date, any attempts to re-install the INF drivers appear to not be working.
Even trying to manually re-install them through the System Properties dialog, WIN is for some reason preventing me from removing the drivers from each listed piece of hardware.
So, my question, is there any way to remove the installed chipset package so that I can run the INF update utility again?
Or, am I stuck with having to do a clean re-install of the OS . . . again?
