Intel Ethernet vs Realtek Ethernet
Dammm00
1 (0.00/day)
Hi, could you tell me which ethernet is better between "Intel 2.5 Gb Ethernet" and "Realtek 2.5 Gb Ethernet"? (Windows 11, Wi-Fi 5Ghz goes to max 150 Mbps)
The first is on the mobo "Asus prime z790-A" and the second on the "prime z790-P"
1,237 (0.28/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
Realtek has come a long way, both are fine!
7,492 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
True it's only for specific use cases that one are preferred over the other, but as a end user both are fine for you.
2,670 (0.80/day)
This answer works for me it perfectly describes my feelings on the matter w/o trying to shill for Intel being better due to largely frivolous differences that are both hard to explain or understand how to properly setup in the first place w/o a guide and even then you have a lot of disputes over that.
13,953 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Your post is mixing apples and oranges. Ethernet and wifi are two, totally different network interfaces/protocols. One has nothing to do with the other. One uses wires, the other uses radio frequencies (wireless).
Also, ethernet protocols must comply with industry standards - standards that have been around for a very long time. In other words, both should work equally well. When choosing between two motherboards, I sure would not use that as a deciding factor.
7,492 (1.04/day)
I h that Lenovo recently have a lot of issues with their laptops running Intel Wi-Fi 6 AX211 cards.
Last week I had reports of more then 5 issues where WiFi doesn’t find any ssids in both Windows 10 & 11 and Lenovo confirmed this over the phone to me.
so far no official fix from Lenovo other then replacing the WiFi cards this is on Legions and ThinkPads.
i have a AX200 in my own Asus Crosshairs VIII Dark Hero and no issues so it might just be a Lenovo think.
18,584 (2.63/day)
System Name AlderLake
I'm using Intel Wi-Fi 6E AX210 with a 200Mbps connection, and reaching 200+wireless , no issues.
Wired my board has Ethernet 10G/1G Marvell AQtion AQC113C.
893 (1.01/day)
Processor Intel i7 77OOK
Motherboard Gigabyte Aorus something
Cooling Noctua NH-U12S dual fan
Memory Ballistix 32 Go
Video Card(s) MSI 3060 Gaming X
Storage Mixed bag of M2 SSD and SATA SSD
Display(s) MSI 34" 3440x1440 Artimys 343CQR
Case Old Corsair Obsidian something
Audio Device(s) Integrated
Power Supply Old Antec HCG 620 still running good
Mouse Steelseries something
Keyboard Steelseries someting too
Benchmark Scores bench ? no time to lose with bench ! :)
I've read bad think about the intel chip ( the i225 ) reliability ...
( like "self destoying" on the long term )
Some of you are aware of this ?
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
Yep asus boards seem to have issues with intel nic 1225-V
18,584 (2.63/day)
1,237 (0.28/day)
System Name Sierra
Yes, early ones had this issue but it’s long been fixed.
893 (1.01/day)
Never heared about "self destroying" intel wifi....
It is not about the wifi chip, but with the lan chip (i225)
Hope so, i've bought an Asus Strix B550-A equipped with, for my sister new's PC.
Hope it's well fixed ! :)
44,274 (6.80/day)
Ive never hand as issue with Realtek. It was Atheros always dropping drivers, and then my 2019 asus notebook dropping wifi inspite of using intgrated intel wifi adapter with drivers.
1,114 (0.58/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Philips
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Killer ethernet says hello!
18,584 (2.63/day)
262 (0.22/day)
If you visit the FreeNAS/TrueNAS forum, many people recommend using Intel NICs instead of Realtek hardware. Problems may occur in systems with high levels of network traffic between the server and multiple client computers. See link below:
Similarly, if you are building a stand-alone pfSense (or similar) Firewall in a computer, dual port Intel NICs are sometimes more reliable, especially when you have numerous clients connected simultaneously.
I had trouble for several years with three Asus XC-100C 10GbE NICs, until I updated the Aquantia driver in April 2020. Now the XC-100C cards work seamlessly with my 10Gig SPF+ fibre optic network.
I'm not against Realtek NICs per se. I chose my new Asus Prime X670-P WiFi motherboard because it had a 2.5GbE (Realtek) NIC. All the other 'cheap' AM4 boards I could buy had 1.0GbE chipsets. I wasn't prepared to spend £500+ on a motherboard with 10GbE, even though the rest of my network runs at 10Gb/s
Most of the dire warnings on the TrueNAS forum relate to old 100Base-T and 1.0GbE systems, so the new Realtek 2.5GbE chipsets might be just as reliable as Intel NICs in high traffic/multiple client situations.
If you're not building a server or a firewall, I shouldn't worry too much about the manufacturer of the Ethernet chipset on your motherboard. You can always buy a plug-in multi-Gig PCIe card if the integral NIC proves unreliable. A low-latency (but flaky) NIC might be more desirable in a gaming system, than a more dependable NIC in multi-client server.
44,274 (6.80/day)
It really makes no difference at what Network transceiver you have.
If you have problems check the router settings then transceiver settings/drivers. They still make pcie cards.
17,927 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
gigabyte boards as well.
my gigabyte b650 board was a fucking nightmare to deal with. internet would drop every 2-3 minutes then come back, it just was horrible.
also Intel LAN is always on ALWAYS ON if your PC is shut down, look behind your PC, the Intel LAN light will always still be blinking. creeps me the fuck out.
I am realtek LAN for life. fuck that noise, and fuck that gigabyte board for giving me biggest headache of my life for multiple reasons. I refunded it.
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
You would think intel ethernet could be overclocked by now.
Im playing with an old system fx6300/970 board with intel ethernet works just the same... its almost irrelevant to think about at this point.
349 (0.33/day)
System Name HP EliteBook 725 G3
Processor AMD PRO A10-8700B (1.8 GHz CMT dual module with 3.2 GHz boost)
Motherboard HP proprietary
Cooling pretty good
Memory 8 GB SK Hynix DDR3 SODIMM
Video Card(s) Radeon R6 (Carrizo/GCNv3)
Storage internal Kioxia XG6 1 TB NVMe SSD (aftermarket)
Display(s) HP P22h G4 21.5" 1080p (& 768p internal LCD)
Case HP proprietary metal case
Audio Device(s) built-in Conexant CX20724 HDA chipset -> Roland RH-200S
Power Supply HP-branded AC adapter
Mouse Steelseries Rival 310
Keyboard Cherry G84-5200
Software Alma Linux 9.1
Benchmark Scores Broadcom BCM94356 11ac M.2 WiFi card (aftermarket)
I think that has more to do with the quality of the FreeBSD Realtek ethernet chipset drivers than any inherently inferior design of Realtek ethernet chipsets. Considering how popular Realtek ethernet chips are even in higher end computers, I do not see any reason to avoid them unless you are 1. going to run FreeBSD or 2. have extremely specific needs as another poster already said above.
Now, Realtek WiFi is a different matter, especially on Linux. I would really recommend going with Intel or Mediatek (formerly Ralink) instead.
13,953 (2.04/day)
Nebraska, USA
Mouse Logitech M190
I think the above alludes to the bigger point here. No brand is immune from issues. And certainly, different models within the same brand may perform differently - despite the exact same protocols and standards they must follow.
Also, network performance (including continuity) depends on much more than just the NIC in our computers. For Ethernet, the router/switch on the other end must be equally robust and stable. And then there are those cheap, flimsy, fragile, often poorly made (and why I make my own), but absolutely critical network devices, the Ethernet cables (and their connectors) that play a major, but often overlooked role in network performance.
Similarly for wireless, there is the wireless NIC in our computers, but also the WAP (wireless access point) - typically integrated with the router or "residential gateway". But there is so much more. The antennas are critical. And not just the antennas themselves, but their placement and orientations.
And then, of course, there is what's in between, blocking, attenuating, interfering with the two-way "RF" signals.
The point is, network connections and performance is an end-to-end, two-way "system", where any part within can be the weakest link.
4,934 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
So what kind of broadband do you have if wi-fi only hits 150Mbps because it may be a non-issue if you don't approach speeds anywhere close to 2.5 Gbps.
