Intel Readies "The Element" - a Next-Generation of Modular PCs
AleksandarK
2,988 (1.06/day)
Yesterday Intel hosted an event in London, where it held a presentation and demonstration of new concept product. Simply called "The Element", this new products tries to introduce the concept of modular computing, where you can basically swap out parts and replace them with ease, to users of PCs who wanted this to happen for a long time.
If anyone remembers Razer's project Christine, which unfortunately didn't take off, this product should be of no surprise to them. The Element is a complete PC consisting out of CPU, RAM and Storage, with a PCIe slot attached to it. Featuring plenty of IO options like Thunderbolt, HDMI, Ethernet, USB, and Wi-Fi, The Element is a complete solution for computing. For the demo Intel soldered a BGA Xeon CPU with room for two SODIMM slots for memory and two M.2 ports for storage expansion, all cooled by a blower fan directly cooling the CPU heatsink. Power is supplied from PCIe slot (75 Watts) and 8 pin connector which would come from a regular PSU. There is also an option for the card to be powered by a 19 V power source if external power brick is provided.
As you can see from the above images, this concept basically wants to put all the computing power on a card that attaches to the single motherboard with a PCIe slot. Such approach would allow for some interesting solution when it comes to the design of a system, where you could build anything from small form factor PCs all the way to the giant builds that feature dozen or so of these units in order to form a server like unit. Possibilities for configuring the system based on "The Element" are almost endless.
While this comes as a PCIe card, there would be no regular AIB partners to release their own PCB design. Instead AIB partners would just be allowed to make small aesthetics adjustments like different cooling type (watercooling anyone?) and different designs of backplates.
While in the development phase for now, this concept is planned for release sometime in Q1 2020, most likely availability will be at the end of Q1 or beginning of Q2. Pricing is still unknown and configurations of this product will be OEM dependant, so that still remains a mystery until further notice.
silentbogo
5,651 (1.35/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
We forgot one more elephant in a room - QNAP Mustang-200... Basically the same thing, so I'm wondering if Intel chose the same solution for interconnect (e.g. using 10GbE IC as a bridge)
76 (0.04/day)
"Today Intel hosted an event in London "
At 7am!!!! I think you means "will host"!
191 (0.06/day)
System Name cryohellinc PC
Processor i7-4770k @4.5ghz
Motherboard MSI Z87 MPOWER
Cooling Corsair Hydro Series™ H115i
Memory Corsair Vengeance 16gb @1600mhz
Video Card(s) MSI Sea Hawk GTX 1080 2100mhz
Storage 3ssd - 64gb (software) ;128 (software + operational system); 256gb - Games + 1TB HDD
Display(s) PG348Q
Case Obsidian Series® 750D Full Tower ATX Case
Audio Device(s) Creative Sound Blaster ZxR + Beyerdynamic DT 990 Pro 250Ω
Power Supply Antec High Current Pro HCP-1200 1200W
Mouse SteelSeries Sensei
Keyboard SteelSeries 6gv2 + custom O-Rings. Using Via PS2 connector
A concept that has been looked into for quite some time. Finally, someone with loads of cash will attempt to materialize it.
5,821 (0.98/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
I hope they will keep the name and go at least on for 5 more versions later.
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Gimmicks Come, Gimmicks Go. :shadedshu:
53 (0.02/day)
Processor AMD Ryzen 5 3600
Motherboard MSI B450M Mortar MAX
Cooling AMD Wraith Prism
Memory 2x8GB 3200MHz CL16
Video Card(s) XFX Radeon RX580 GTS XXX 8GB
Storage Samsung Evo 500GB + 3x WD Green 1TB
Display(s) LG 29UM59-P
Case CoolerMaster NR400
Audio Device(s) ATH-M40FS + SMSL SD-793 II DAC
Power Supply Antec NewPower TP-650w 80%+
Mouse Logitech G500
Keyboard Krom Kernel TKL
Software Win10 x64
Converting PC's into blade enclosures?!
Can't see the point here really... By the time you need an additional module, the original one is not compatible (Intel ftw), or the enclosure conector is 1 or 2 gen's old...
61 (0.03/day)
Germany
System Name New Horyzen
Processor Ryzen 7 1700X
Motherboard ASRock Fatal1ty X370 Gaming K4
Cooling Noctua U-12S
Memory 2x 8GB Corsair Vengance LPX 3200MHz
Video Card(s) Sapphire 5700XT
Storage A lot
Case Modded Corsair Carbide 300R
Audio Device(s) ESI Maya44 eX, Focusrite Scarlett 2i4 2nd, Samson Meteor, Mixer and Headphone Amp
Power Supply SeaSonic M12II 750W
Keyboard HyperX Alloy & Logitech G13
Software All of it
Didn't we have things like this in the past?
Think back to the backplane systems. Was that realy a good solution?
As others have said, knowing Intels history with sockets, you will replace the whole machine when upgrading in 2 years.
457 (0.12/day)
System Name Marmo / Kanon
Processor Intel Core i7 9700K / AMD Ryzen 7 5800X
Motherboard Gigabyte Z390 Aorus Pro WiFi / X570S Aorus Pro AX
Cooling Noctua NH-U12S x 2
Memory Corsair Vengeance 32GB 2666-C16 / 32GB 3200-C16
Video Card(s) KFA2 RTX3070 Ti / Asus TUF RX 6800XT OC
Storage Samsung 970 EVO+ 1TB, 860 EVO 1TB / Samsung 970 Pro 1TB, 970 EVO+ 1TB
Display(s) Dell AW2521HFA / U2715H
Case Fractal Design Focus G / Pop Air RGB
Audio Device(s) Onboard / Creative SB ZxR
Power Supply SeaSonic Focus GX 650W / PX 750W
Mouse Logitech MX310 / G1
Keyboard Logitech G413 / G513
Software Win 11 Ent
Basically a desktop equivalent of the blade server where every component is hot swappable.
984 (0.21/day)
System Name Poor Man's PC
Processor Ryzen 7 7700
Display(s) Xiaomi G Pro 27i MiniLED
Case Asus A21 Case
Mouse Logitech MX Anywhere 3
VR HMD Meta Quest 2
So Intel found a way to get rid of their remaining Xeon :p
1,865 (0.60/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
I thought I was the only one familiar with that product, haha... I've been trying to find reviews of it to no avail
191 (0.09/day)
Processor Ryzen 9800X3D
Motherboard B650 - Asus TUF B650-E WiFi
Cooling Arctic Freezer II 240mm AIO
Memory 32GB DDR5-6000 - CAS 32
Video Card(s) 4070 Ti - Gigabyte Eagle OC
Display(s) 32” 1440p - Samsung C32HG70
Case Silverstone GD11
Audio Device(s) Focusrite Scarlett 8i6 3rd Gen - Sennheiser HD595
About 20 years late, and still looks half-baked. Shouldn't they be collaborating with about 10 other companies in order for this to work?
44,283 (6.80/day)
Close components produce heat
3,595 (1.11/day)
QNAP is just a coprocessor.
This project is about a more general concept of modular PCs, where only the CPU and RAM are fixed - everything else being easily changed. People have been looking forward to this for years (decades...).
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
So they basically put a whole system on a PCI Express card but...what's the point? PCI Express doesn't have enough bandwidth...nor control topography...to have multiple of these cards in one system or even the ability to drive other peripherals (like a dedicated GPU off the same complex.
I guess that's my point: why PCI Express? It should be using a new interconnect that facilities all types of high speed communication (CPU to CPU, CPU to AIB, AIB to RAM, etc.) and power delivery. I see nothing really revolutionary here. Certainly not a milestone for future products. All they did is basically flip PCI Express around (put the host on a card).
12,173 (1.71/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
The next intel socket will be a a blade socket that will last 9 months before they release the next one is all I see.
11,098 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
133652
I feel like they were leaning this way at one point then bailed for PIII.
silentbogo
5,651 (1.35/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
They have 3 types:
R- the FPGA
V- the AI co-processor
And the regular, which is actually not a co-processor, but two complete PCs with RAM & storage on a single PCB. You can do whatever you want with these cards, cause basically they are interfaced via 10GbE. There are two chips on the board(probably older Intel or Mellanox), which are wired directly to PCIe on the slot side, and NIC on the SoM side. You talk and manage those over the network, even though there are no cables.
So, you can deploy even something like a homebrew OpenMPI cluster or virtualized workspaces for relatively cheap.
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
i wonder if i could use that as a upgrade for my existing machine? like adding a new grapics card to the system but dont need to swap out a hole new mainboard + cpu, just plugin an extra one :D
8,570 (1.81/day)
Ovronnaz, Wallis, Switzerland
System Name main/SFFHTPCARGH!(tm)/Xiaomi Mi TV Stick/Samsung Galaxy S25/Ally
Processor Ryzen 7 5800X3D/i7-3770/S905X/Snapdragon 8 Elite/Ryzen Z1 Extreme
Memory 64gb DDR4 3600/8gb DDR3 1600/2gbLPDDR3/12gbLPDDR5x/16gb(10 sys)LPDDR5 6400
Video Card(s) Hellhound Spectral White RX 7900 XTX 24gb/GT 730/Mali 450MP5/Adreno 830/Radeon 780M 6gb LPDDR5
Storage 250gb870EVO/500gb860EVO/2tbSandisk/NVMe2tb+1tb/4tbextreme V2/1TB Arion/500gb/8gb/512gb/4tb SN850X
Display(s) X58222 32" 2880x1620/32"FHDTV/273E3LHSB 27" 1920x1080/6.67"/LTPO AMOLED panel FHD+120hz/7" FHD 120hz
Audio Device(s) Logi Z333/SB Audigy RX/HDMI/HDMI/Dolby Atmos/CVJ NightElf/Moondrop Chu II+BT20S/Nekocake GfL QBZ-191
VR HMD Medion Erazer
my WD external 1tb HDD could use that name ... oh wait ... it already use it ... minus the "The" :oops: :laugh:
3,595 (1.11/day)
They have 3 types:
You're obviously right.
But the principle stands. The idea of modular PCs is not about combining few separate machines. It's just a change of approach to how we make DIY setups. The goal being: to make it fast and very easy. It should be as simple as attaching an external USB drive, so that anyone could do it.
The point is: building DIY PCs will be as easy as connecting a multi-deck stereo system. Just a few cables.
What do you mean? PCIe has enough bandwidth today. The modular concept isn't much different from what we have today. It's just that every larger component will have "a box" and there will be more "risers".
CPU and RAM will always come together, because distance and compatibility are crucial for performance.
Seriously, imagine a laptop with attached external drives, eGPU, external network card, external sound card.
It works even today.
The idea here is really just to replace the USB cables with a shorted, more robust and much faster bus.
Building DIY desktops today is beyond what most can or are willing to do. With modular PCs they'll just push one big box into a slot next to other boxes. It'll be as easy as assembling a food blender.
1,164 (0.20/day)
Chicago, Illinois
I don't see a market for this. Especially considering the fact that a lot of people have realized that building a PC is pretty easy and even if you have difficulty you can just ask anywhere for help or do a google or youtube search and you'll find what you need.
266 (0.10/day)
Processor Intel core i5 4590s
Motherboard Asus Z97 Pro Gamer
Cooling Evercool EC115A 915SP Cpu cooler,Coolermaster [200mm (front and top)+140mm rear]
Memory Corsair 16GB(4x4) ddr3 CMZ16GX3M4X1600C9(Ver8.16)(XMP)
Video Card(s) MSI GTX 970 GAMING 4G
Storage Western Digital WDC WD2001FAS 2TB Black, Toshiba DT01ACA100 1TB
Display(s) LG Flatron L177WSB
Case Coolermaster CM Storm Enforcer
Audio Device(s) Creative A550 Speakers 5.1 channel
Power Supply SuperFlower Leadex 2 Gold 650W SF-650F14EG
Mouse PLNK M-740 Optical Mouse
Keyboard ibuypower GKB100 Gaming Keyboard
Software Windows 7 Sp1 64 bit
Can see this happening...with consoles in the future
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Sounds like a mess on the desk and NUCs can already do all that. I don't see this going anywhere because it's foundationally (PCI Express) stupid.
