- May 6, 2018
- 1,150 (0.45/day)
- Upstate NY
System Name | Dual Socket HP z820 Workstation |
Processor | Twin Intel Xeon E5 2673 v2 OEM processors (thats a total of 16C/32T) |
Motherboard | HP Dual Socket Motherboard |
Cooling | Stock HP liquid cooling |
Memory | 64GB Registered ECC memory kit (octal channel memory on this rig) |
Video Card(s) | MSI RX 5700 XT Gaming X 8GB |
Storage | 2 x 512GB SSD in raid 0 |
Display(s) | Acer 23" 75Hz Gaming monitors 1080P x2 |
Case | Brushed Aluminium |
Audio Device(s) | Integrated (5.1) |
Power Supply | HP 1125W Stock PSU |
Mouse | gaming mouse |
Keyboard | Dell |
Software | Windows 10 Pro |
Long overdue for a new system, and the time has finally come!
After losing a good lead on a cheap 8086K, I've spent the afternoon comparing alternative CPUs to replace it. I've decided to go with the fastest 9th gen core I5 CPU instead... I know, I know, it's not top tier, but I am still planning on getting 5000Ghz out of it. I'd say I have a 50/50 chance of making that happen. This CPU is second only to the 8086K in terms of overclockability averages (if going by the userbenchmark.com stats)... As you can see, the bell curve doesn't just drop off like a cliff, indicating this CPU has very good overclocking potential with the right hardware and doesn't face a "hard limit" as some other CPUs do. Here is the OC freq curve for the i5-9600KF, from userbenchmark.com
After this revelation, and realizing the $600+ and up price tag for the high-high end Intel chips, I've come to some additional conclusions regarding the purpose of this build and how it will be used. Meaning we will not be going flat out on the best hardware with this. This will be my daily driver, not an extreme overclocker, and I want to focus on single-thread performance vs brute force. This leads me to the Intel Core i5-9600KF, a 9th gen unlocked 6 core CPU that boosts to 4.6Ghz. The price/performance ratio cannot be beat, as they go for about $200 shipped. Seeing as how single-thread performance is nearly on par with the 9900k or the 8086k, I realized I likely won't notice any difference in day to day usage (short of benchmarking). And my target goal of 5.0Ghz all core is still intact. I like the KF chips without the GPU, so that's my new CPU choice.
I also realized I don't need all new components as I have a good Coolermaster case here, and Antec 650W PSU, as well as an MSI RX580 GPU to throw at it.
I think I found a pretty sweet motherboard on newegg to go with it as well. Seeing as how the video card and motherboard are all MSI I decided to top it off with the MSI Core Frozr XL 120mm air cooler.. so this should be a handsome build when it's all said and done, especially when resting in the Coolermaster padded case. In terms of the RAM I backed off just a little from my 4500Mhz goal and downgraded to 4000Mhz Gskill Trident z b-die at 18-19-19-39
Here is a list of the parts I just purchased on Newegg:
Memory = G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 4000 (PC4 32000) Intel Z270 / Z370 Memory (Desktop Memory) Model F4-4000C18D-16GTZ
$200
CPU = Intel Core i5-9600KF Coffee Lake 6-Core 3.7 GHz (4.6 GHz Turbo) LGA 1151 (300 Series) 95W BX80684I59600KF Desktop Processor Without Graphics
$200
CPU Cooler = MSI Core Frozr XL 120MM
$120
Motherboard = MSI MAG Z390 TOMAHAWK
$160
SSD = SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 2-bit MLC Internal Solid State Drive (SSD) MZ-V7P512BW
$170
I figured I would go for broke with the m.2 NVMe SSD, so this one ranks pretty high up in the speed department and seems to get rave reviews with one user even claiming a 5 second boot time (seems dubious but at the very least I am future proofing)
the case I will be using:
I just ordered all the parts tonight. So expect an update by Friday!
$200
$200
$120
$160
$170
