Is 72C in GPU Hot Spot high for 1660 Super mining?
27 (0.02/day)
Processor Ryzen 5 3600 @ 4.350MHz 1.3V
Motherboard B450 Aorus Elite
Cooling Hyper H410R RGB
Memory XPG Spectrix D41 RGB
Video Card(s) Galax GTX 1660 Super ( 1 Click OC )
Storage Seagate Barracuda 2TB 7200RPM, PNY CS900 120GB, PNY CS3030 500gb
Case Redragon Diamond Storm Pro
Power Supply Cooler Master MWE 450 Bronze
I want to know if this temp is high for Galax GTX 1660 Super 1 Click OC
Hashrate average: 31.7MH/s
and 88C ( hot spot ) is high for Zotac RTX 2060 Twin Fan?
Nah, I wouldn't pay much attention to hotspot temps anyway. There's always going to be a discrepency between hotspot and average of about 15-20C under load, 57C is perfectly normal for average temps under load. That being said, 57C with 82% fan is a bit toasty. What's your ambient temp?
hot spot temperatures are somewhere between 15-30°C above the edge temp.
depending on what the GPU is doing it can be much more or way less than that.
74°C is totally fine (even 100°C is still okay)
google says 18C, but, probably, at my room is like 21C ( 69,8F )
That's quite a normal ambient temp, so either the card has a pretty bad cooling setup requiring a lot of fan speed to compensate, you haven't set a proper power limit (which in your screenshot it seems you have, so rule this out), or your airflow sucks.
Is this in a frame or in a normal chassis? Is it pressed up in a GPU sandwich [as in, are there other GPUs on either side]? If it is in a frame, do you have fans pointed at it to remove heat (if not, there's very little airflow so the heat lingers in an open frame-setup)
yeah i never really bothered with hotspot temps that's why i never used gpu-z to monitor that, i have a decent oc on my 750 ti with overvolt of +12v and those are maximum stable clocks it can go and i get nice 5-7fps boost in most games, i have a decently aggressive fan curve so no even in summer with ac off my gpu doesn't go above 70c that too with 70% fan speed
How would google know what's the temperature in your room ? Huh ? :kookoo:
It looks like you got some good settings there. Those are great temps for mining imo.
I'm assuming when I said ambient they were thinking of air temperature - which is understandable if you don't quite understand English 100% or aren't quite so knowledgeable about specific terms in the computer/hardware circles. For a layman ambient temperature usually refers to outside air temperature, so it is an understandable confusion - but yes, room temperature specifically is what ambient refers to when talking about computers usually :laugh:
