Is anyone else's Steam controller devouring batteries?
1,865 (0.53/day)
North Dakota
System Name Office
Processor Core i7 10700K
Motherboard Gigabyte Z590 Aourus Ultra
Video Card(s) Intel ARC A750
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
Title says it all. This didn't used to happen; when it was newer, I'd left a pair in there unused for months, probably over a year. I don't use the Steam controller much, but it beats a dual-analog for certain games. Anyway, the last couple sets of batteries have gone kaput in mere weeks, just sitting in the thing. This last time, it probably had 45 minutes of actual use. It's self-powering off if the light and chime are to be trusted. Is this a bug with the newest firmware, and can it be rolled back if so? I just dropped $50 on the Lunar New Year sale, plus a bunch more on some other recent hardware; not eager to also go controller shopping.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Wow, someone that actually likes the Steam controller!
I'd just get a set of rechargables.
1,865 (0.53/day)
North Dakota
System Name Office
Maybe. I used to use rechargeables in Rock Band equipment and wireless KBs/mice. The could even still be around. It'd be a cheaper way to test, if nothing else.
13,955 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
If your old rechargeable batteries are several years old, it may be time to invest in new ones. Not because the old are old, but because the technology for rechargeables have improved so you don't have to constantly recharge them.
1,029 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
Just pop the batteries out when not using it, don't have to worry about them leaking that way either.
1,865 (0.53/day)
North Dakota
System Name Office
That's an excellent point, though the batteries that have been dying are fresh Duracell alkalines.
Yeah, that'd also be an effective solution. I'd still love to know why there's an issue in the first place.
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
It’s possible that the batteries from this batch aren’t as good and you’ve only tried two sets.
I suggest buying some fresh Duracells and see how it goes.
Yes, it’s possible that the controller has become faulty. I used to have a Casio graphing calculator that ate batteries for breakfast due to a fault, including standby. It functioned normally otherwise and didn’t get hot. It used several CR2032 batteries, too.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
I've switched to Li-ion rechargeables and haven't looked back.
Definitely could be this. A small bit of corrosion somewhere could bridge a connection and cause the batteries to slowly drain at all times. Or a component could be faulty causing a small bit of current to pass when it shouldn't be.
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
I haven't charged my Steam controller since I bought it 4-5 years ago, I used it very little for gaming, mostly as wireless mouse. The batteries finally died couple weeks ago. :D
