System Name | ibuytheusedstuff |
Processor | 5960x |
Motherboard | x99 sabertooth |
Cooling | old socket775 cooler |
Memory | 32 Viper |
Video Card(s) | 1080ti on morpheus 1 |
Storage | raptors+ssd |
Display(s) | acer 120hz |
Case | open bench |
Audio Device(s) | onb |
Power Supply | antec 1200 moar power |
Mouse | mx 518 |
Keyboard | roccat arvo |
System Name | Upgraded CyberpowerPC Ultra 5 Elite Gaming PC |
Processor | AMD Ryzen 7 5800X3D |
Motherboard | MSI B450M Pro-VDH Plus |
Cooling | Thermalright Peerless Assassin 120 SE |
Memory | CM4X8GD3000C16K4D (OC to CL14) |
Video Card(s) | XFX Speedster MERC RX 7800 XT |
Storage | TCSunbow X3 1TB, ADATA SU630 240GB, Seagate BarraCuda ST2000DM008 2TB |
Display(s) | AOC Agon AG241QX 1440p 144Hz |
Case | Cooler Master MasterBox MB520 (CyberpowerPC variant) |
Power Supply | 600W Cooler Master |
But i have an i5-7400 in my b250m how does that work?No, it isn't.
The B250 chipset works with version 1 of the LGA1151 socket (only compatible with 6th gen "Skylake" and 7th gen "Kaby Lake" CPUs).
As a 9th gen "Coffee Lake" CPU, the i7-9700K requires a motherboard with a LGA1151 v2 socket. These motherboards have 300-series chipsets, and H310, B360, B365, H370, Z370 and Z390 are the most common.
System Name | Veral |
Processor | 7800x3D |
Motherboard | x670e Asus Crosshair Hero |
Cooling | Thermalright Phantom Spirit 120 EVO |
Memory | 2x24 Klevv Cras V RGB |
Video Card(s) | Powercolor 7900XTX Red Devil |
Storage | Crucial P5 Plus 1TB, Samsung 980 1TB, Teamgroup MP34 4TB |
Display(s) | Acer Nitro XZ342CK Pbmiiphx, 2x AOC 2425W, AOC I1601FWUX |
Case | Fractal Design Meshify Lite 2 |
Audio Device(s) | Blue Yeti + SteelSeries Arctis 5 / Samsung HW-T550 |
Power Supply | Corsair HX850 |
Mouse | Corsair Harpoon |
Keyboard | Corsair K55 |
VR HMD | HP Reverb G2 |
Software | Windows 11 Professional |
Benchmark Scores | PEBCAK |
7400 is early Skylake. Not Coffee Lake. The pinout is different between both chips.But i have an i5-7400 in my b250m how does that work?
System Name | Pioneer |
Processor | Ryzen 9 9950X |
Motherboard | MSI MAG X670E Tomahawk Wifi |
Cooling | Noctua NH-D15 + A whole lotta Sunon, Phanteks and Corsair Maglev blower fans... |
Memory | 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4200(Running 1:1:1 w/FCLK) |
Video Card(s) | XFX RX 7900 XTX Speedster Merc 310 |
Storage | Intel 5800X Optane 800GB boot, +2x Crucial P5 Plus 2TB PCIe 4.0 NVMe SSDs, 1x 2TB Seagate Exos 3.5" |
Display(s) | 55" LG 55" B9 OLED 4K Display |
Case | Thermaltake Core X31 |
Audio Device(s) | TOSLINK->Schiit Modi MB->Asgard 2 DAC Amp->AKG Pro K712 Headphones or HDMI->B9 OLED |
Power Supply | FSP Hydro Ti Pro 850W |
Mouse | Logitech G305 Lightspeed Wireless |
Keyboard | WASD Code v3 with Cherry Green keyswitches + PBT DS keycaps |
Software | Gentoo Linux x64, other office machines run Windows 11 Enterprise |
Because it's a 7th generation Kaby Lake desktop CPU, which means it is compatible with the LGA 1151 v1 socket. The CPU generation number matches the first digit after the series name (or the first 2 digits, for 10th and 11th generation). i5-6400 is 6th gen and is compatible with B250, i5-7400 is 7th gen and is compatible with B250, i5 8400 is 8th gen and is not compatible with B250.But i have an i5-7400 in my b250m how does that work?
It is technically possible to hack the BIOS of some 100/200-series chipset motherboards so they will work with 8000-series CPUs, but this is not recommended as it is not supported by the manufacturer, will void any warranty you have on your CPU and motherboard, may result in bugs or instability, and may brick your motherboard if something goes wrong. Officially B250 motherboards are only compatible with 6th and 7th generation CPUs.@GibusPie the latest series you can install is generally the 8xxx series 1151 socket chips. The common codename for those is "coffee lake."
I'm well aware, but that may as well be greek when you have to spell out model matches, so I intentionally left it outIt is technically possible to hack the BIOS of some 100/200-series chipset motherboards so they will work with 8000-series CPUs, but this is not recommended as it is not supported by the manufacturer, will void any warranty you have on your CPU and motherboard, may result in bugs or instability, and may brick your motherboard if something goes wrong. Officially B250 motherboards are only compatible with 6th and 7th generation CPUs.
