Is PC part picker always right with compatibility?
18,584 (2.63/day)
System Name AlderLake
Can I trust this site to check compatibility for my new hardware parts?
Frick
Fishfaced Nincompoop
20,060 (2.87/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
You mean compatibility as in stuff like motherboard QVLs? Honestly I can't imagine them keeping track of all that.
18,584 (2.63/day)
Yes, that and if the parts actually fit, such as a cooler with memory clearance, video card in specific case and such.
2,098 (0.51/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
Here is a quote from PC part pickers Philip
"The compatibility checker will definitely warn you if your CPU and motherboard are not compatible. Same with your video card. The wattage estimator should give you a reasonable lower-bound for your power supply wattage as well, though it is generally a good idea to add in a bit of headroom depending on what you'd like to do in the future, the quality of the PSU, etc. There are a few areas I'm not currently able to check, such as clearance from larger RAM modules and very large CPU heatsinks (i.e. Phanteks, Noctua DH-14, etc.). If you're still worried though, feel free to post your part list here and I can double-check it."
I've seen him respond to several reddit users comments about incompatibility issues and he seems to be a nice guy. I believe it's about more than 95% correct about incompatibility issues but before buying I usually check the manufacturers page aswell.
EDIT: Here is a interesting topic about it if you want to look any further into it.
https://www.reddit.com/r/buildapc/comments/2z8afd/how_reliable_is_pcpartpickers_compatibility_check/
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
I highly recommend double checking part lists, no matter what the source, for compatibility (e.g. CPU with chipset), clearance (some googling on case and HSF usually can get an answer), and completeness (e.g. have power supply, motherboard, memory, storage, processor, case, optical drives, cables, anything else?)before placing the order. It may be tedious and boring but an hour of making sure can save hours/days of time waiting and returning parts.
372 (0.06/day)
Where the beer is good
System Name Karl Arsch v. u. z. Abgewischt
Processor i5 3770K @5GHz delided
Motherboard ASRock Z77 Professional
Cooling Arctic Liquid Freezer 240
Memory 4x 4GB 1866 MHz DDR3
Video Card(s) GTX 970
Storage Samsung 830 - 512GB; 2x 2TB WD Blue
Display(s) Samsung T240 1920x1200
Case Bitfenix Shinobie XL
Power Supply Cougar G600
Mouse Logitech G500
Keyboard CMStorm Ultimate QuickFire (CherryMX Brown)
Software Win7 Pro 64bit
Yes and no.
  • CPU - motherboard - RAM usually works good at partpicker, but I 'd allways make sure if the CPU is supported by motherboard via motherboard vendors website. For example some Xeons might not work or only after a BIOS update.
  • What isn't working at all. When it comes to RAM clearance there is nothing partpicker can do about it. I havn't seen a single site that offers it. But high heatspreader are useless anyway nowdays.
  • What is managed really bad are: CPU cooler dimensions, case clearence for cpu coolers and GPUs. That iformation isn't displayed. For that you could use a german site as an assistant - that's how I do it usually. You would just have to learn ~5-7 german words and you are good to go.
here is an example:
CPU - cooler
Abmessungen (BreitexHöhexTiefe): 121x155x62.5mm = dimensions: (width x Height x Depth): 121x155x62.5mm
Case
CPU-Kühler: bis max. 170mm Höhe = CPU-cooler: up to 170mm height
Grafikkarten: bis max. 290mm (400mm ohne HDD-Käfig) = graphic cards up to 290m (400mm without HDD cage)
GPU
Abmessungen: 305x114x47mm = dimensions: 305x114x47mm
I usually create the parts list via partpicker and in a 2nd browser tab/window I have "geizhals" open and copy/paste the product names or parts number into the search field to check for dimensions, if I'm not sure about the fit.
69 (0.02/day)
Manila, Philippines
System Name Operation Scylla
Processor Intel Core i5-4690K
Motherboard MSi Z97S SLI Krait Edition
Cooling ID Cooling Frostflow 120L-W
Memory 4x4GB Avexir Core 1600MHz CL11 White
Video Card(s) Inno3d GTX 770 Herculez X3
Storage Plextor M6S 128GB, Seagate ST2000DM001 2TB
Display(s) Asus VC239H
Case Modded Silverstone Raven 05
Audio Device(s) Onboard 5.1
Power Supply Silverstone Strider S Series ST75F-GS 750W 80+ Gold
Mouse Logitech G402
Keyboard Motospeed CK104 Inflictor RGB Outemu Blue
Software Windows 7 Ultimate 64bit SP1
They didn't show an error when I checked the V8 GTS (166mm) and the RV05 (162mm compatible) so probably they don't have everything covered just yet.
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Couldn't agree more. Here's an example of what can go wrong.
I made a little booboo when I built my current PC: I'd ordered all the components, CPU, GPU, RAM and mobo, but couldn't decide what CPU cooler to get. This meant that I'd bought memory modules with tall vertical heatsinks on them without thinking about it. They were no problem with the Intel stock cooler and I ran the rig like that for a while, but you can imagine what happened when I finally settled on the huge Noctua NH-D14. Yup, I was forced to get rid of them and buy a whole new set of modules, which were ironically a little more expensive even though they were exactly the same brand and spec. Won't be making that mistake again. :p
31 (0.01/day)
Out there, not here, UK
Processor Ryzen5 2600
Motherboard MSi X470 Gaming PLus
Cooling CM MasterLiquid ML240L AIO
Memory Corsair Vengeance LPX (2x16Gb) DDR4 3200MHz
Video Card(s) MSi GTX Armor 1080
Storage Crucial MX500 250Gb SSD M.2 /Crucial MX500 1Tb SSD / Toshiba X300 4Tb HD
Display(s) AOC 31.5" 1440p
Case NZXT H500
Audio Device(s) Creative Z
Power Supply Silverstone Strider 650w
Mouse Corsair M65
Keyboard Corsair K70 RGB UK
You can trust them for most things, but as others have stated, it's always worth double checking your final "build". It's also easy enough to inform them if the info given is wrong, I've done that a number of times *evil grin* :p
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
69 (0.02/day)
Manila, Philippines
Mouse Logitech G402
Know what? I just flagged something incorrect by contacting support thru mail and they made the corrections in less than 2 minutes.
They're not 100% accurate just yet, but with everyone's help they soon will be. :)
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Only think I'd be concerned with is with coolers not clearing all of the other parts.
18,584 (2.63/day)
Yeah, thats one of the reasons why I was asking this.
I want to buy a Coolermaster 212 evo with this memory:
I have an Asus Z170 Pro Gaming motherboard, the heatspreaders of this memory are not tall so it should fit.
1,877 (0.30/day)
Cobourg,Ontario
System Name RyZen FX
Processor AMD Ryzen 9 5900x
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling DeepCool AK400 Zero Dark Plus
Memory Corsair CMK32GX4M2E3200C16 X2 32gig dual channel
Video Card(s) ASUS RX 7700XT TUF OC
Storage x2 Lexar SSD NM710 2TB 2XSeagate 1Terrabyte 1x Seagate 2 Terrabyte
Display(s) 40 Inch Samsung HDTV (monitor)
Case HAF-X:)
Audio Device(s) AMD/HDMI to Onkyo HT-R508 Receiver
Power Supply EVGA SuperNOVA 1000 G2 Power Supply
Software Windows 10 Pro X64
Should be good LPX means Low Profile Extreme performance memory .
798 (0.21/day)
Processor I5 4690K @ 4.8 Ghz
Motherboard Gigabyte Z97X Gaming 7
Cooling Swiftech H140X
Memory 16GB Crucial BallistiX 1866Mhz
Video Card(s) GTX 1070 G1 Gaming
Storage 850 PRO 1TB SSD, 840 EVO 500GB SSD, 850 EVO 500GB
Display(s) Nixeus EDG 27-Inch IPS 1440P, 144HZ 16:9
Case NZXT H440 Red/Black
Mouse G600
Keyboard G710+
Software Win 10 64B
It looks like it will clear the RAM. Are you planning on getting a 4 piece kit? or a 2 piece ?
If you use 4 RAM sticks you might have issues with the front intake fan on the 212 EVO, but it looks like if you just use 2 sticks in the right most grey slots you should be able to clear.
Its a close fit on my mine, but clears the heatsink by a cm or 2.
2,098 (0.51/day)
The Vengeance LPX units are low-profile sticks with a height of only 31 mm. They come with 8-layer PCBs and an all-aluminum heatspreader, and they'll be available in black, white, blue, and red.
The
Coolermaster 212 evo allows 37 mm memory stick.
The ram should fit in any slot presuming you install them first.
18,584 (2.63/day)
I will buy a 4x4GB kit, there was only one set of compatible set of 2x8GB sticks on the motherboard memory compatibility list but that brand is not available in my country so I found this 4 stick kit on the list which was available in my country.
798 (0.21/day)
Mouse G600
Keyboard G710+
Software Win 10 64B
You may have to not use a front intake fan, or adjust it so the RAM clears. You wont have issues vertically as Devon68 showed above.
However, I don't think theres enough horizontal space for 4 sticks and the 212EVO with that front stock fan it comes with.
18,584 (2.63/day)
I want to buy 1 of these for the cooler: https://azerty.nl/8-1088-832181/scythe-slip-stream-120-db-ventilatorhuis-120-mm-1300-rpm.html
Only using 1 fan on the 212 evo.
If it would not fit then I need to attach the fan it a bit higher, I don't think thats a huge problem is it?
798 (0.21/day)
Mouse G600
Keyboard G710+
Software Win 10 64B
Heres a picture of my rig. This should help you see how tight it is even with just 2 sticks.
69 (0.02/day)
Manila, Philippines
Mouse Logitech G402
Happened to see this online. Credit goes to the original uploader.
18,584 (2.63/day)
I think the distance of the ram slots may differ a few mm as well per motherboard? Or is this a fixed place for the memory slots on every ATX motherboard?
Thanks @Anarki ! I see now that it should fit.
798 (0.21/day)
Mouse G600
Keyboard G710+
Software Win 10 64B
Thanks @Anarki ! I see now that it will fit.
Yeah you should be able to use all 4 just fine. The fan will just need to be outward a bit like shown in the nice picture by Anarki.
372 (0.06/day)
Mouse Logitech G500
Also there is always the option to use a slim fan in the front and put a regular 25mm fan on the back of the cooler, exausting toward the rear case fan.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
No offense to anyone helping, but this is why aio coolers are such a massive success. No clearance issues, top tier air cooling performance, and no weight issues on the socket.
