Is Phenom II x4 capable of running 64bit VMware virtual machine ?
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
I have recently upgraded to AthlonII x3 that I unlocked to Phenom II x4 with L3 enabled.
And I started downloading VMware server while I was waiting for download to compete I have downloaded and started program from vmware site for checking if your cpu is capable of running 64bit virtual machines. The test come out like this
And I`m almost sure that should be capable of running 64bit guest OS.
Any thoughts ?
2,459 (0.38/day)
System Name PC
Processor i7 9700KF
Motherboard MSI Z390 A PRO
Cooling Noctua NH-U14S
Memory 32GB Corsair Vengeance DDR4 3000mhz
Video Card(s) PALIT RTX 4070 Dual 12Gb
Storage Samsung 990 Evo 2TB NVME, 2X Crucial MX500 2TB
Display(s) DELL C34H89x 34" Ultrawide
Case Corsair Obsidian 550D
Audio Device(s) Audioengine A5+ Speakers
Power Supply Corsair RM750
Mouse Logitech G403
Software Windows 11 64bit
And I started downloading VMware server while I was waiting for download to compete I have downloaded and started program from vmware site for checking if your cpu is capable of running 64bit virtual machines. The test come out like this http://forums.techpowerup.com/attachment.php?attachmentid=34687&stc=1&d=1270211287
Any thoughts ?
im not familiar with AMD chips but you do have the option of turning virtulisation on and off in the bios for intel 64bit chips that support it... perhaps your AMD equivalent setting is set to off in your bios?
Phxprovost
Xtreme Refugee
1,217 (0.21/day)
Pennsylvania
System Name Result of Boredom
Processor AMD FX-6350
Motherboard ASUS M5A97
Cooling Enzo Tech Extreme-X
Memory 16gb ddr3
Video Card(s) XFX R9 290
Display(s) Asus 24in (1920X1080) X 2 @144hz
Case NZXT S340
Software WIN7 64bit HP
:toast: sounds about right
r9
3,300 (0.54/day)
I`m going to check that now. Even though I highly doubt it.
brandonwh64
19,542 (3.42/day)
i ran VMware on my 965BE so it should work for that CPU
  • Like
Reactions: r9
r9
3,300 (0.54/day)
I just checked in BIOS and there is option SVM secure virtual machine which is enabled. I`m going to try installing one and see if the VMserver would allow me.
At the moment I can think only at one reason why could I have this problem. Before I upgraded to current setup I did fresh OS install then I just put the new system in and the winodows 7 just auto installed drivers for the new setup and that was it. My previous CPU was E5200 which was very anti VM.
HolyCow02
1,638 (0.27/day)
New York
System Name Shredder
Processor Phenom II 955 @stock (for the time being)
Motherboard MSI 790FX-GD70
Cooling Noctua U12P
Memory 8 GB muskin DDR3 1600 @ 7-7-6-18
Video Card(s) 2x Sapphire 4870 1GB
Storage 64 GB Super Talent UltraDrive SSD | 2 x WD Caviar Black 500GB in RAID1
Display(s) Samsung 22" 2ms GTG
Case Thermaltake Spedo Advanced Package
Power Supply Corsair HX1000
Software Vista Business 64-bit
As long as your host operating system is 64-bit, you will be able to run a 64-bit VM. You cannot run a 64-bit VM on a 32-bit machine because the the 32-bit OS cannot understand 64-bit instructions.
running 64-bit on 32-bit is like trying to translate spanish to english when you only understand russian. it doesn't work.
I see you are running a 64-bit version of Win 7, so you might just need to reinstall VMware
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It isn't just a matter of the host OS being 64-bit, though that is part of the requirements, Virtualization must also be enabled and working.
6,776 (0.92/day)
Republic of Asia (a.k.a Irvine), CA
System Name ---
Processor FX 8350 @ 4.00 Ghz with 1.28v
Motherboard Gigabyte 990FX-UD3 v4.0, Hacked Bios F4.x
Cooling Silenx 4 pipe Tower cooler + 2 x Cougar 120mm fan, 3 x 120mm, 1 x 200 mm Red LED fan
Memory Kingston HyperX DDR3 1866 16GB + Patriot Memory DDR3 1866 16GB
Video Card(s) Asus R9 290 OC @ GPU - 1050, MEM - 1300
Storage Inland 256GB PCIe NVMe SSD for OS, WDC Black - 2TB + 1TB Storage, Inland 480GB SSD - Games
Display(s) 3 x 1080P LCDs - Acer 25" + Acer 23" + HP 23"
Case AeroCool XPredator X3
Audio Device(s) Built-in Realtek
Power Supply Corsair HX1000 Modular
It might be either that Virtualization not enabled in bios or when the setup was moved from non-vt to a VT enabled one W7 didn't register it properly. Probably reinstall all the mobo drivers or best would be reinstall of W7.
what version of W7 x64 you are running?
356 (0.06/day)
Processor AMD Ryzen 3 1200 @ 3.7 GHz
Motherboard MSI B350M Gaming PRO
Cooling 2x Dynamic X2 GP-12
Memory 2x4GB GeIL EVO POTENZA AMD PC4-17000
Video Card(s) GIGABYTE Radeon RX 560 2GB
Storage Samsung SSD 840 Series (250GB)
Display(s) Asus VP239H-P (23")
Case Fractal Design Define Mini C TG
Audio Device(s) ASUS Xonar U3
Power Supply CORSAIR CX450
Mouse Logitech G500
Keyboard Corsair Vengeance K65
Software Windows 10 Pro (x64)
Holy is right in that you need to be running a 64-bit host OS. Having virtualization on in the BIOS isn't necessarily required in a lot of cases, as you can do virtualization through software as well. What enabling hardware support will do (with virtualization apps that support it) is make the process a heck of a lot faster.
I know the new version of VirtualPC in Windows 7 requires hardware support, but older versions did not and Sun's VirtualBox does not, though they both support it as an option. I am not sure whether or not VMware explicitly requires the feature, but if you have it (and you do), you might as well have it on.
r9
3,300 (0.54/day)
Ultimate x64.
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Motherboard Asrock B450M Pro4
Cooling Some CM tower cooler that will fit my case
Memory 4 x 8GB Kingston HyperX Fury 2666MHz
Video Card(s) IGP
Storage ADATA SU800 512GB
Display(s) 27' LG
Case Zalman
Audio Device(s) stock
Power Supply Seasonic SS-620GM
Software win10
Try virtualbox
6,776 (0.92/day)
System Name ---
Try virtualbox
Virtualbox is not even close. VMWare is the best. Did you install the latest VMWare? did you check if there are any patches?
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Video Card(s) IGP
Display(s) 27' LG
Case Zalman
Software win10
Um have you tried the latest version? It is pretty solid and now there's opengl 3d and hw accelerated flash
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
This is true if you are running a 32-bit guest os, however even with VMWare, virtualization is required to run a 64-bit guest os.
Trust me, I've tried getting VMWare to run a 64-bit guest OS without virtualization, it just won't do it. I fought the exact same problem on my Pentium D 830. The processor is 64-bit, the OS is 64-bit(Win7 Pro x64), but VMWare simply would not run a 64-bit guest OS.
Here is a VMware KB article for diagnosing this problem: http://kb.vmware.com/selfservice/mi...nguage=en_US&cmd=displayKC&externalId=1006190
Notice step 2 is to make sure Virtualization is enabled.
Deleted member 67555
try setting you cpu back to a tri core
I have a PII 555 that is perfectly stable in a 32 bit OS as a x4 but fails quickly under 64bit.
Your 4th core probably just isn't stable enough for VM
r9
3,300 (0.54/day)
Just to sum up. The host OS is Win7 64bit and the guest Ubuntu server 64bit installed just fine. It is just the program they made for checking compatibility sucks thats all.
tal.aloni
1 (0.00/day)
r9 is correct,
The program (VMware-guest64check-5.5.0-18463.exe) simply check the Family, Extended Family and Extended Model that are reported by the CPU against values that were known to support BT64 (Binary Translation) when the program was written. (Which was before AMD released the Phenom CPU).
The problem is not limited to the check utility, VMWare Server 1.x will refuse to run x64 guests with some of those newer CPUs, because their family / model values are not known to support BT64. (in practice they all support BT64)
If you need a solution to this problem, see here:
http://iknowu.dnsalias.com/files/public/vmware/VMWare-Server-v1-CPU-Detection-Fix.htm
MxPhenom 216
ASIC Engineer
13,168 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
You also need to enable No execute Bit memory in the bios for VMs to be provisioned and worked.
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
The irony of the whole thing is x64 is AMD's "baby" Odd it would need so much "hoop jumping" to get an x64 VM running.
4,012 (0.70/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
Are you sure it is not a problem caused by unlocking the chip? Tried returning it to a stock 3 core?
