Is there a way...Linux Mint question
4,380 (0.90/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
So, I have this old emachines box that I have upgraded to a P4 at 2.8Ghz.
I have Mint12, Lisa running problem free but, BOINC manager is also old and won't get jobs anymore.
My solution is to upgrade the distro. So, made a bootable disk of Sarah, mint 18. However, I cannot get it to boot from the USB or the CD drive. I have played with this effed up BIOS for what seems like forever.
Question is this: is there a command in Terminal that will download the boot file for the new distro? It seems like there should be a way. Although, I am unsure if my CD drive is being recognized.
So, Question 2: is there a way to see if the drive is accessible?
Dependant on the manufacturer of your particular emachine the boot menu key is esc, F9 or F12 these keys will allow you to select the boot device, Only the options listed are recognized as bootable.
If the device you intend to boot from is not listed you may be able to modify the priorities in bios to make it bootable.
legacy machines of that era may not support USB bootable but a bios update may introduce USB boot functions.
You might want to test the bootable media you created on another (more recent) computer, to see if it's really bootable as exepcted.
It may turn out that something went wrong during the creation (corrupted iso ? media doesn't have the active flag ? )
Another option may be to have someone load up a hard drive with the distro you want and send it to you.
I've done this with Ubuntu a few times but am not sure if Mint would be as easy to do.
After sleeping on it, I remembered that over a year ago, when I was loading, probably 3 years ago, a distro, that I had to use a different cd player. So, I just Frankenstein-ed a different drive and the image is loading. Go figure.
LOL, old machine quirks, I should write these things down!
:lovetpu:
No Bios updates available, Boot key is DEL and the Frankenstein-ed Drive did the trick. Now, to install BOINC and make it all worth it!
:lovetpu:
To my Experience Linux Refreshes on Boot to any Computer so by Installing the OS via Another PC and transfer the HDD to that PC should Boot Fine
BOINC really hasn't changed at all since version 5. What probably happened is that the security certificate is expired. If memory serves, I run version 7 on my server for all the files except the executable.
That said, you should be able to pull the latest version of BOINC off the MINT repository.
