Is there a way to tell web browsers to use integrated graphics and ignore your dedicated gpu?
17,938 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
In settings in all web browsers there is a feature called hardware acceleration, if I enable this (I assume it is using my dedicated gpu since that is where the cable to my monitor is connected), since I have OLED monitor sometimes Twitch streaming will flicker, if I turn hardware acceleration off, flickering goes away and twitch looks great, but with it off scrolling websites sometimes feels a bit janky.
So, is there a way to point web browsers to use only your integrated graphics (my 7800x3d has integrated graphics) and keep hardware acceleration on, but not utilize my dedicated gpu at all? I am just thinking maybe that will also stop the flickering, but keep websites running smooth at the same time, I dunno
3,362 (0.56/day)
System Name Panda? Storm Trooper?
Processor AMD 9950X3D
Motherboard Gigabyte Aorus Pro ICE X870E
Cooling AC Core 1 CPU Block | Heatkiller Radiators 2x 360-45mm 1x 240-30mm |AC Core 120mm Reservoir
Memory G.Skill Trident Z5 64GB CL30 6000Mhz
Video Card(s) RTX 5090 32GB Palit Gamerock w/ Alpha Core Waterblock
Storage 4TB WD Black NVME Gen 4 + 14TB WD HDD
Display(s) ASUS PG32UDCP 32" WOLED 240hz/480hz
Case HYTE Y70 Panda + ColdZero AF Front Panel
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply ASUS Thor III Platinum 1200w
Keyboard NEO75CU White + PBTFans Neon R2 Glitter + BSUN Macaron Switches
Not sure if this will help but I use my motherboard ports for my secondary screens where my browsers live and it seems to work well.
22,203 (3.44/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4200(Running 1:1:1 w/FCLK)
Case Thermaltake Core X31
This sounds more like it could be OLED freesync flicker, which is a known issue with many panels? Could be wrong but should be easy to test for...
4,118 (2.61/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Outside SLI/CF, and not counting IGPU video passthrough mode, is there even a theoretical possibility of dividing work (image generation) between two GPUs, which also implies separate frame buffers?
