System Name | WorkInProgress |
Processor | AMD 7800X3D |
Motherboard | MSI X670E GAMING PLUS |
Cooling | Thermalright AM5 Contact Frame + Phantom Spirit 120SE |
Memory | 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32 |
Video Card(s) | Asus Dual Radeon™ RX 6700 XT OC Edition |
Storage | WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming)| 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500 |
Display(s) | LG GP850-B |
Case | Corsair 760T (White) {1xCorsair ML120 Pro|5xML140 Pro} |
Audio Device(s) | Yamaha RX-V573|Speakers: JBL Control One|Auna 300-CN|Wharfedale Diamond SW150 |
Power Supply | Seasonic Focus GX-850 80+ GOLD |
Mouse | Logitech G502 X |
Keyboard | Cherry G80-3000N (TKL) |
Software | Windows 11 Home |
Benchmark Scores | ლ(ಠ益ಠ)ლ |
System Name | Wut? |
Processor | 3900X |
Motherboard | ASRock Taichi X570 |
Cooling | Water |
Memory | 32GB GSkill CL16 3600mhz |
Video Card(s) | Vega 56 |
Storage | 2 x AData XPG 8200 Pro 1TB |
Display(s) | 3440 x 1440 |
Case | Thermaltake Tower 900 |
Power Supply | Seasonic Prime Ultra Platinum |
System Name | The Worker/ Laptop |
Processor | Ryzen 5 3600/ i5 1035g1 |
Motherboard | MSI b450 Tomahawk Max / Lenovo proprietary |
Cooling | Arctic Freezer 33 eSport One |
Memory | 16Gb DDR4 3200 Mhz Corsair vengeance LPX / 12gb ddr4 3200Mhz (4gb are soldered :( ) |
Video Card(s) | Gigabyte gtx 1660 Ti OC @2030Mhz core and 7400Mhz memory / Intel G1 UHD |
Storage | 1 970Evo plus 500gb, 2x250Gb Samsung 850 Evo,3 TB HDD / 250gb WD SN530 |
Display(s) | Asus mx259h / 15.6 FHD TN |
Audio Device(s) | Onboard / Onboard |
Power Supply | CoolerMaster G750M |
Software | W10 64bit |
I had a 1050 ti for 2.5 years and I overclocked it Since the first day I got it. It helped me getting to 60 FPS back then.Hi everyone,
Is VRAM overclocking safe without overvoltage for pascal series? I have GTX 1050.
Thanks.
System Name | New compy |
Processor | AMD Ryzen 5800x3D |
Motherboard | MSI MPG x570S EDGE MAX WiFi |
Cooling | Noctua NH-D15S w. FHP141 + Xigmatek AOS XAF-F1451 |
Memory | 32gb G.Skill Ripjaws V Samsung B-Die Dual Rank F4-4000C16D-32GVKA |
Video Card(s) | ASUS TUF GAMING RTX 4070ti |
Storage | 17tb (8+4tb WD Black HDD's, 2+2+0.5+0.5tb M.2 SSD Drives) + 16tb WD Red Pro backup drive |
Display(s) | Alienware AW2518H 24" 240hz, Sony X85K 43" 4k 120hz HDR TV |
Case | Thermaltake Core v71 |
Audio Device(s) | iFi Nano Idsd Le, Creative T20 + T50, Sennheiser HD6Mix |
Power Supply | EVGA Supernova G2 1000w |
Mouse | Logitech G502 Hero custom w. G900 scroll wheel mod, Rival 3 + Rival 3 wireless, JLab Epic Mouse |
Keyboard | Corsair K68 RGB + K70 RGB + K57 RGB Wireless + Logitech G613 |
Software | Win 10 Pro |
Benchmark Scores | https://valid.x86.fr/s2y7ny |
Processor | 11700 |
Motherboard | TUF z590 |
Memory | G.Skill 32gb 3600mhz |
Video Card(s) | ROG Vega 56 |
Case | Deepcool |
Power Supply | RM 850 |
System Name | Tiny the White Yeti |
Processor | 7800X3D |
Motherboard | MSI MAG Mortar b650m wifi |
Cooling | CPU: Thermalright Peerless Assassin / Case: Phanteks T30-120 x3 |
Memory | 32GB Corsair Vengeance 30CL6000 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Lexar NM790 4TB + Samsung 850 EVO 1TB + Samsung 980 1TB + Crucial BX100 250GB |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Lian Li A3 mATX White |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | Steelseries Aerox 5 |
Keyboard | Lenovo Thinkpad Trackpoint II |
VR HMD | HD 420 - Green Edition ;) |
Software | W11 IoT Enterprise LTSC |
Benchmark Scores | Over 9000 |
System Name | Purple rain |
Processor | 10.5 thousand 4.2G 1.1v |
Motherboard | Zee 490 Aorus Elite |
Cooling | Noctua D15S |
Memory | 16GB 4133 CL16-16-16-31 Viper Steel |
Video Card(s) | RTX 2070 Super Gaming X Trio |
Storage | SU900 128,8200Pro 1TB,850 Pro 512+256+256,860 Evo 500,XPG950 480, Skyhawk 2TB |
Display(s) | Acer XB241YU+Dell S2716DG |
Case | P600S Silent w. Alpenfohn wing boost 3 ARGBT+ fans |
Audio Device(s) | K612 Pro w. FiiO E10k DAC,W830BT wireless |
Power Supply | Superflower Leadex Gold 850W |
Mouse | G903 lightspeed+powerplay,G403 wireless + Steelseries DeX + Roccat rest |
Keyboard | HyperX Alloy SilverSpeed (w.HyperX wrist rest),Razer Deathstalker |
Software | Windows 10 |
Benchmark Scores | A LOT |
ddr5On Nvidia cards I use MSI AB.
I simply set the temperature to the highest acceptable limit, create a better fan curve and raise the core until it boosts to it's Hard limits and then I do the same to the memory.
My core speed as it comes is set at 1607mhz...I have it set +215 (core) and that's enough for it to boost to 2113ghz
I've only been able to raise the memory does to +300?
Yeah...ikr... Every other Pascal seems to be able to do it.ddr5
Now you know 800 is stable, try 850 or 50mhz increase every time, scan for artefacts or errors and get to the max stable limit you can getI did test +1000 and i can't see any artifacts in games. But if i test with MSI Kombustor artifact scanner (FURMARK-MSI (GL) mod) it's give me many errors but i still can't see any artifacts. I start seeing fullscreen artifacts after 5 minutes when testing so i tested +800 for half hours and i don't get any error and artifacts with MSI Kombustor or games. I have hynix VRAM. Sorry for any grammatical mistakes :/
For example with my strix 1050 to I could get 750 mhz stable on ram, or even +1000 mhz but I think it wasn't that stable so I stepped back. For the core I was able to push it to 1987mhz, setting the power limit to the max and also the voltage(it actually does nothing to the GPU, only hard mod can rise it)Now you know 800 is stable, try 850 or 50mhz increase every time, scan for artefacts or errors and get to the max stable limit you can get
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
System Name | AlderLake |
Processor | Intel i7 12700K P-Cores @ 5Ghz |
Motherboard | Gigabyte Z690 Aorus Master |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p |
Case | Be quiet! Silent Base 600 - Window |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W |
Mouse | Logitech MX Anywhere 2 Laser wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless |
Software | Windows 11 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
My GTX1070 did +825 on the vram but the core wouldn't OC well.
System Name | GameWar |
Processor | AMD Ryzen 5 1600 AF overclock @ 4.0 ghz |
Motherboard | MSI B450 Tomahawk |
Cooling | AMD Wraith Max RGB cpu cooler |
Memory | G.SKILL Flare X Series 16GB (2 x 8GB) @ 3200 |
Video Card(s) | MSI Gaming GeForce GTX 1660 Super |
Storage | Crucial MX500 1TB , 2TB Seagate HDD |
Display(s) | BenQ ZOWIE XL2411P @ 144Hz |
Case | NZXT H510 Elite Case |
Power Supply | Seasonic Focus+ Gold 550FX |
Mouse | Logitech 100S gaming mouse |
Keyboard | Logitech G105 gaming keyboard |
Software | Windows 10 Home 64bit |
I stand corrected...The GPU has to budget its power between GDDR5 and an almost similar shader count versus a 1080 that can make do with more efficient GDDR5X and is also often better binned. Its really an odd one out.
As long as you dont over-volt you are safe.Hi everyone,
Thanks.
System Name | Good enough |
Processor | AMD Ryzen R9 7900 - Alphacool Eisblock XPX Aurora Edge |
Motherboard | ASRock B650 Pro RS |
Cooling | 2x 360mm NexXxoS ST30 X-Flow, 1x 360mm NexXxoS ST30, 1x 240mm NexXxoS ST30 |
Memory | 32GB - FURY Beast RGB 5600 Mhz |
Video Card(s) | Sapphire RX 7900 XT - Alphacool Eisblock Aurora |
Storage | 1x Kingston KC3000 1TB 1x Kingston A2000 1TB, 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB |
Display(s) | LG UltraGear 32GN650-B + 4K Samsung TV |
Case | Phanteks NV7 |
Power Supply | GPS-750C |
System Name | Main |
Processor | R7 5950x |
Motherboard | MSI x570S Unify-X Max |
Cooling | converted Eisbär 280, two F14 + three F12S intake, two P14S + two P14 + two F14 as exhaust |
Memory | 16 GB Corsair LPX bdie @3600/16 1.35v |
Video Card(s) | GB 2080S WaterForce WB |
Storage | six M.2 pcie gen 4 |
Display(s) | Sony 50X90J |
Case | Tt Level 20 HT |
Audio Device(s) | Asus Xonar AE, modded Sennheiser HD 558, Klipsch 2.1 THX |
Power Supply | Corsair RMx 750w |
Mouse | Logitech G903 |
Keyboard | GSKILL Ripjaws |
VR HMD | NA |
Software | win 10 pro x64 |
Benchmark Scores | TimeSpy score Fire Strike Ultra SuperPosition CB20 |
increasing voltage on any 10xx and 20xx cards that i had/installed, didnt help with anything,
VR HMD | NA |
Processor | i7 8700K |
Motherboard | MSI Z370 Gaming Plus |
Cooling | Noctua NH-D15S + NF-A12x25 PWM + 4xNF-A14 PWM |
Memory | 16 GB Adata XPG Dazzle DDR4 3000 MHz CL16 |
Video Card(s) | Gigabyte GTX 1070 Ti Gaming 8G |
Storage | Samsung 970 EVO Plus, Samsung 850 Evo |
Display(s) | Samsung C24FG73 144Hz 1080p |
Case | Fractal Design Meshify C |
Audio Device(s) | Steelseries Arctis 3 |
Power Supply | Superflower Leadex II Gold 650W |
Mouse | Steelseries Rival 600 |
Keyboard | Steelseries Apex 7 |
Software | Windows 11 Pro |
My 1070ti with Micron VRAM can only do about +350MHz on it before things get unstable. At first I thought +400 worked OK, but the card would TDR 1-2 times/month.Yeah...ikr... Every other Pascal seems to be able to do it.
