Issues with Deathadder 2013
8,305 (1.30/day)
Memory Corsair Vengeance RGB 2x8GB 3600MHz
Mouse Logitech G604s
Anyone else have issues with their Deathadder wherein you install synapsis for the mouse driver then upon messing with the DPI the mouse starts to stutter and not want to move? It's really starting to piss me off and it doesnt do this if i dont have the software installed, however, when in a game if i dont have the software installed, my mouse fucking bounces all other the place and I end up doing a full 360 if i want to turn around 180 degrees.
Im half tempted to go out and buy a new mouse.
I have not tried the new cloud based 2.0 yet. I am having no issues with the old drivers(plus there were no fixes or issues so I did not upgrade), but I am also using a mamba on my lappy. Try uninstalling the everything, restart your machine and reinstall the synapsis 2.0. Then check for any firmware upgrades razer may have out. I had similar happen to me with an older copperhead. I am not a huge fan of razer but I got a killer deal on this mamba for my lappy, my main machine I use a Cooler Master Storm Sentinel Advance 2.
Already tried what you suggested.
When it does it unplug it and plug it back in, might be the same issue i have with another razor i have of theirs. How ever i don't use the software at all and ever so often it would do what your talking about.
Replaced with a better mouse which is much older Microsoft wired blue ( 99c at swift store ).
I have a Razer Deathadder, and I think it's the 2013 version. I don't have any problems with Razer Synapse 2.0; did you change the DPI in Synapse, because if you immediately move your mouse after changing it there, I think the mouse will go weird like you said. I bound the two extra thumb buttons to change the DPI, you can do that too and check if your problems occur when changing DPI through that method as well.
Never had anything like that with mine =\
