large axial fans: power used is less at higher voltages?
So are most of the fans initially designed to work at +24VDC and the +12VDC or +48VDC models are just adaptations of the +24VDC models? Is that why they're less efficient than the +24VDC models?
Looks like 24V is the optimal voltage for such a design geometry.
If you need to use a boost converter to make your 12V into 24, its efficiency will probably be somewhere around 93%, narrowing the gap to:
leave your fans on 12v!!!!
lol
What would happen if you were to connect the positive lead to +12V and the negative lead to -12V on the 24-pin ATX power connector? Most PSU's still seem to have a -12V lead.
The -12V line can normally only carry a rather low current.
Just use a 12V fan and move on.
There are +24VDC PSU's that could be used, some of them are pretty small considering you don't need a lot of current to power +24VDC fans, but I only have 2 or 3 fans that come in +24VDC models.
I believe the +24VDC models of these fans can be had cheaper than the +12VDC models though (at least on ebay).
Most PSUs don’t like high load on the -12V side. It’s a leftover relic from older communication ports and protocols.
You would achieve your 24V difference, but not at enough wattage to do anything. I experimented with a older PSU once and the voltage drops back to 12 quickly as the load increased, and then it tripped since it believed it had a short circuit.
I'll bet -12V was for the old RS232c serial ports (which initially required +/- 12V to work).
@Shrek
That's a great idea except for two things:
1. every fan would need it's own AC power cord.
2. you can't control the fan speed
I do use two high power 127mm fans though and only at full speed. If I could convert those to 115AC it would reduce the power draw on my PSU by 66W (even more on start-up) and save power over using the +12VDC models it would be a winner.
Considering POTS established the TRS then 3.5 (POTS used 48~53VDC Ring Battery)
