Liquid cooling but without water?
1,755 (1.10/day)
I'd like to go with a liquid cooled build but my luck with computer hardware is so bad I'm sure it would be a disaster if I used water. I used to go off-roading a lot and baja bugs and thumpers used to use oil coolers. Why can't something similar be adapted to computers?
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
There was a time I never used liquid cooling to besides a aio that is.
It's not all that tough just take your time assembling...
Not sure I'd simplify it as "water" seeing water alone would get pretty funky fairly quickly
Comparing a baja buggy oil cooling to a computer well oil doesn't really care what parts is in aluminum/...
Computer cooling is a tad more complicated
But I have used a verity of fluids
Car antifreeze about 15% for 1 liter distilled water.
Also tried distilled and and additives but this was a pita to maintain ph7-8
Premixes in the beginning just my luck got some bad ek cryocrap stuff which was worse than V.D. to get rid of :laugh:
Now I'm on mayhems x1 clear concentrate with local distilled no issues so far it comes around ph8 and good for one year
Tried mayhem premix same x1 clear and on one machine it turned greenish seems hardware labs radiators there is a chance it will do this
Another mach did not with same rads and premix so I only batted 50-50 on that fluid.
ir_cow
5,013 (0.82/day)
USA
distilled water is non-conductive. I've gotten it everywhere on a powered on computer before no issues. After a few months I think the ions start to charge and it become conductive. You will have to do more reading on that one.
3,192 (2.27/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
Water cooling PCs isn't for people with sloppy habits, poor construction skills, or a marked lack of attention to detail. It's up to the individual to assess where they fall in the spectrum of those character traits.
The main reason why water is used is because it has superb thermal capacity just by itself. Additives usually reduce water's thermal capacity and add more complexity to the system (corrosion, expense, reactions with materials, etc.).
Things like automotive antifreeze in a custom cooling loop make zero sense. You add antifreeze to your car's radiator because your car is subject to more extreme operating conditions (i.e., lower temperatures). That's not applicable for typical desktop PCs which live a decidedly cushy life in the same temperature ranges that human beings find comfortable. Your PC isn't parked in the driveway during a snowstorm. So don't add automotive antifreeze to your PC's custom cooling loop. It's pointless and dumb.
Really all you need for a PC custom cooling loop is distilled water and a few drops of biocide to prevent algae from forming, sort of like the chlorine added to swimming pools and water fountains.
2,758 (0.66/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Things like automotive antifreeze make zero sense. You add antifreeze to your car's radiator because your car is subject to more extreme operating conditions (like freezing temperatures). That's not applicable for typical desktop PCs which live a decidedly cushy life in the same temperature ranges that human beings find comfortable. Your PC isn't parked in the driveway during a snowstorm. So don't add automotive antifreeze to your PC's custom cooling loop. It's pointless and dumb.
WRONG!!!
There are reasons why adding antifreeze to a custom system CAN be a good thing to do under the right conditions.
Has NOTHING to do about antifreeze being for an auto because it can be used for many other things too - It's not something that's exclusive to autos alone.
Yes - It's an additive yet it can also help against corrosion, some of which can be induced by having dissimilar/different metals in the system, causing corrosion issues such as a rad and block made of different materials that are reactive to each other.
I will agree that for most desktops it's not required at all, however in certain circumstances it can help things such as helping to reduce the effects of what I just described. I will also agree that water on it's own is better in terms of cooling efficiency, anytime you add something to water it's efficiency goes down but used correctly antifreeze in the system doesn't impact it much.
And I will say I've used it with good success in the past in mine, just know my watercooling setup is in an outside building here and it's required during the cooler months of the year or I'll have a busted block and whatever else if I don't use it during those times.
So yes, there are at least a few reasons why it could be used that does make sense if one thinks about it.
As for using it being dumb - That's just your own personal opinion of it which only matters to your own situation, not for anyone else.
Folks should determine their own individual needs and requirements, these will let them know what they'd need and what to do because it's their situation - Another's situation like yours or even mine need not apply to theirs because each and everyone is different.
3,192 (2.27/day)
Okay, okay, next time I'll profusely litter my post with weasel words and heavy use of "usually", "often", "generally" and "normally".
:D
That said, some people here (and other tech forums) enjoy making things as complicated as possible. With some thoughtful consideration beforehand, one can eliminate most of these complications that require specialized solutions. When you add more variables to a given system, you're going to end up with more possibilities for problems (perhaps some unforeseen). Making beef Wellington is more complicated than grilling a steak.
I know that additives or alternate cooling liquids are useful in extreme situations, some of which certain PC builders put themselves into.
The International Space Station uses radiators with ammonia but I'm not going to recommend any PC builder to use ammonia. I wouldn't be surprised if some YouTuber has tried but not everything people do on YouTube should be copied.
So yeah, there's usually an exception to every rule. We all know that.
That said, for someone exploring custom cooling loops for normal PCs, it's best to keep things simple rather than to jump off into the deep end.
There are tons of tutorials and videos that describe custom cooling loops for PCs (many of them poorly authored and inaccurate). There are really a handful of basic guidelines to follow to make this a relatively simple project.
2,758 (0.66/day)
Alabama
Memory C.R.S.
Okay, okay, next time I'll profusely litter my post with weasel words and heavy use of the words "usually", "often", and "normally".
:D
Please do. :D
What I'm saying is stating it as an absolute isn't correct, I used the above to demonstrate that.
Whatever is needed is needed, no getting around it and such rigid thinking limits, if not eliminates options.... Some of them being good ones too, even if they seem "Out There".
Something I had to learn along the way myself.
I do agree that keeping it KISS is the way to go for beginners, stick to the basics, let them learn and go from there.
3,192 (2.27/day)
We all crawl before we walk.
Yes, it's dumb to recommend advanced specialized options to a beginner. It's needlessly confusing. It's like teaching brain surgery to kindergarteners.
In the context of advanced custom cooling discussions, yes, there is a place for additives. However it's helpful to answer questions contextually. It is not constructive for me to launch into a deep dive into laminated doughs to someone who wants to put a simple breakfast on the table.
People on tech site forums (not just TPU) frequently dive off into the deep end without thinking about context.
Anyhow back to the original topic. If the OP wants to try a custom cooling loop, it might work out better for him to find a friend who has experience doing this and working on a build together. In the same way, lots of excellent cooks learned from family members in their early years.
Watching a few YouTube videos from random vloggers doesn't provide the same one-on-one guidance.
355 (0.34/day)
System Name EA-ZEN
Processor AMD Ryzen 7 5800X3D with -50mW UV
Motherboard Asus X570
Cooling Big Air
Memory 2x16 GB DDR4 3600 CL16
Video Card(s) Asus RTX 2080 Ti Strix highly OC’ed
Storage 1 TB NVME, 500 GB SSD etc
Display(s) 2x 27”, main: curved 144Hz SVA with BLS and HDR
Case Full Tower
Audio Device(s) Z906 5.1 and Audeze Headphones, Shure SM7B mic
Power Supply Enough
Mouse Old but gold
Keyboard Mechanical Cherry Brown
Benchmark Scores A lot
The good thing about antifreeze is that you can put the radiator outside during winter. Or use it with dry ice. Funny things.
Outback Bronze
Super Moderator
2,196 (0.44/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Razer
Keyboard Corsair
Software Win 11
Been using Anti Freeze Car coolant in my loops for 15+ years and never looked back! The best stuff I have ever used. Sorry...
*Edit: Probably close to 20 years now :rolleyes:
Or it wont boil. Water boils.
dgianstefani
TPU Proofreader
5,448 (2.04/day)
Swansea, Wales
Benchmark Scores Legendary
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Why use oil over distilled water? Nothing to worry about, especially since they make sealed AIO's that you install and forget about it.
1,065 (0.28/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
what advantages oil has might be disadvantages in PC cooling. i'm sure dune buggies have higher temps that oil's higher boiling point is desirable but with much larger (flow/pressure) pumps and larger radiators (at least in surface area) with air flow and static pressure that idk if noctua's leaf blowers could match.
just food for thought.
but whats the deal? you dangerous with a screwdriver of something? if thinking custom - soft tubing with compression fittings is easy peasey. just don't overtighten (two fingers!) and you'll be fine :)
5,471 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
Water has a very high specific heat and oil coolers are to cool the oil, not the engine.
1,755 (1.10/day)
Cooling the oil does cool the engine in air-cooled engines.
I was hoping there might be alternative mediums for liquid cooling that were non-conductive, but I suppose the pumps, blocks and radiators are all designed for water, not say, mineral oil.
807 (0.63/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
The thing with oil is that it acts as a heatsink, I guess you already know this if you worked in bugs or other vehicles.
An oil cooling system would be too big for a desktop computer.
355 (0.34/day)
System Name EA-ZEN
Cooling Big Air
Case Full Tower
Power Supply Enough
Mouse Old but gold
Someone cooled a whole pc once by submerging it into oil, but I don’t think that’s practical.
2,363 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
No, AIR cools the engine in air-cooled engines. Those cooling fins and some cases a big ass fan to flow air over them aren't there for decoration.
ir_cow
5,013 (0.82/day)
USA
A few people over the 20+ years I've known about it have done long term studies with this. It seems that anything solder on will fall off after awhile. Now this might be due to using low-grade oil. I don't know, but its a thing. Plus you can pretty much never clean it off. Once its submerged that is it.
355 (0.34/day)
System Name EA-ZEN
Cooling Big Air
Case Full Tower
Power Supply Enough
Mouse Old but gold
Yea I've only seen it done once with cooking oil, it was just a dumb experiment.
Count von Schwalbe
Nocturnus Moderatus
3,444 (2.74/day)
Knoxville, TN, USA
I say go for it, just use plain distilled water with a bit of biocide (and dye if you like) added separately. Leak test with external pump power and the computer turned off. There are a number of tips available, just look around a bit.
A couple of links if you are interested in submersion cooling:
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
The best coolant phase changes. In CPU cooling form, that ends up looking like this:
OneMoar
There is Always Moar
8,834 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
I mean there is that icegiant cooler thats pumpless and uses something like 3m novec
heavy AF tho so plan on figuring out how to brace it
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Or uh, heatpipes.
That's how they work, and all their talk about phase changed vapour chambers and other fancy names for "liquid evaporates and recondenses"
As for the OP: as a beginner, stick with the common options.
Why? Because theres a lot of things only experience can teach you, and the moment you go off into unusual choices you simply don't know what will go wrong.
Oh sure, use anti freeze... but is it safe with soft tubing? Do you need specific O-rings in your fittings? Will it still be safe to use with all the common biocides and dyes?
You wont be able to google it and get reliable answers, since no one really screws around with that except people who have nothing to lose on their sponsored builds that get torn down or never touched again after the builds are done.
1,755 (1.10/day)
Have you ever run a baja bug or an off road motorcycle? The oil acts as the coolant and the oil cooler cools the oil and thus the engine.
