- May 10, 2020
- 39 (0.03/day)
what hope have to be to what I´ve said ?My fingers typed the wrong word! It should have been, "I think [hope] that is something all of us were taught as children. "
Processor | AMD 5900x |
Motherboard | Asus x570 Strix-E |
Cooling | Hardware Labs |
Memory | G.Skill 4000c17 2x16gb |
Video Card(s) | RTX 3090 |
Storage | Sabrent |
Display(s) | Samsung G9 |
Case | Phanteks 719 |
Audio Device(s) | Fiio K5 Pro |
Power Supply | EVGA 1000 P2 |
Mouse | Logitech G600 |
Keyboard | Corsair K95 |
next time maybe , since it´s already connected. I think the motherboard don´t have bended like a lot to be unsafeAnother alternative is to get a CM 90 deg adapter. I keep one in my spares box.
Cooler Master ATX 24 Pin 90° Adapter Standard GL
The ATX 24 Pin 90° Adapter Standard GL adds a number of possibilitiesto how users can install the main power connector to their motherboard from the PSU.www.coolermaster.com
System Name | Einstein Albert |
Processor | Ryzen 5 2600 |
Motherboard | Asus B450-F gaming motherboard |
Cooling | AMD stock cooler |
Memory | 16 Gb DDR4 G skill 3600MHz |
Video Card(s) | MSI RTX 2060 |
Storage | Samsung 970 evo plus 1 TB |
Case | Nzxt h510 |
Power Supply | EVGA 650 watts |
Software | Windows 10 version 2004 |
How did you push The 24 pin connector all the way in the socket can you plz explain the steps you did because I am having the same problem.next time maybe , since it´s already connected. I think the motherboard don´t have bended like a lot to be unsafe
Case | Nzxt h510 |
Is it safe to touch the back of the motherboard and do I support the back of the motherboard with my fingers pressing the motherboard while I push in the 24 pinYou support the rear side/edge with one hand, and push with the other.
System Name | Firelance. |
Processor | Threadripper 3960X |
Motherboard | ROG Strix TRX40-E Gaming |
Cooling | IceGem 360 + 6x Arctic Cooling P12 |
Memory | 8x 16GB Patriot Viper DDR4-3200 CL16 |
Video Card(s) | MSI GeForce RTX 4060 Ti Ventus 2X OC |
Storage | 2TB WD SN850X (boot), 4TB Crucial P3 (data) |
Display(s) | 3x AOC Q32E2N (32" 2560x1440 75Hz) |
Case | Enthoo Pro II Server Edition (Closed Panel) + 6 fans |
Power Supply | Fractal Design Ion+ 2 Platinum 760W |
Mouse | Logitech G602 |
Keyboard | Logitech G613 |
Software | Windows 10 Professional x64 |
Case | Nzxt h510 |
Thank you appreciate the responseYup, as long as the system isn't powered on, you have grounded yourself beforehand, and your fingers aren't horribly dirty or covered with something that conducts electricity.
Case | Nzxt h510 |
My Power supply is a EVGA and the connector seems a bit rough to put in so I just bought cable extensions for the 24 pin to see if it go in the connector easierManufactured make money by usin parts that are not as good as the best available. A cheaper PSU Manufacturer is more likely to favor saving a few cents per connector where maybe they skipped some quality control steps .... maybe one or two of the male connector has a small burr, maybe there's some manufacturing "skizzle" ... it's a technical term ,,, thats adhering to the connector somewhere that is preventing full insertion. If you're anal about it (i resemeble that remark) , there are various wats to address from exacto blades, dremel tools, electically safe lubricants can be useed to make it fully seat. On;y a detailed examination will tell you what might have the best success.
