_33
- Mar 25, 2006
- 1,248 (0.18/day)
- Quebec
System Name | BEAST |
Processor | Intel Core i7 920 C0 Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA batch 3844A509 |
Motherboard | ASUS P6T Deluxe V2 X58 ATX LGA1366 DDR3 |
Cooling | CoolIt ECO A.L.C. 120mm radiator |
Memory | G.SKILL F3-12800CL8TU-6GBPI PC3-12800 6GB 3X2GB DDR3-1600 CL8-8-8-21 |
Video Card(s) | Sapphire Radeon HD 4890 1GB 850MHZ 1GB 3.9GHZ GDDR5 PCI-E 2XDVI HDTV |
Storage | SAMSUNG SPINPOINT F1 750GB X 2, WD2500KS 250GB, WD15EARS 1.5TB, WD20EARS 2.0TB |
Display(s) | LG W2361V-PF Monitors 23” Widescreen LCD Monitor (23.0” diagonal) |
Case | Cooler Master CM 690 II Advanced |
Power Supply | Thermaltake Toughpower 600W Power Supply ATX V2.2 20/24PIN EPS12V Qfan 140MM Fan Active PFC |
Software | Windows 7 Pro 64bit |
I found this interesting thing at a semi-bargain price
And also this one ...
My budget is around 225$ Canadian for CPU + GPU cooling through water. Looking at something like a 300+ Galons per hour performance from the pump at least, and q really free flowing copper tubing in radiator. If anyone has a better solution for me, I'm ready. Thinking of ordering the cooling system next week or max in 2 weeks.
Will let you know when it's installed for performance. Irm already quite overclocked (from sig), but I want 3Ghz from my CPU and around 600 mhz from the R480 gpu
I don't mind buying seperate components like an Alphacool NexXxoS Xtreme II (maybe too big, but I wouldn't mind trilling in my side pannel...)....
Later I'll take care of the memory... Thinking of OCZ / CURCIAL / CORSAIR ....
