- May 6, 2018
- 1,150 (0.45/day)
- Upstate NY
System Name | Dual Socket HP z820 Workstation |
Processor | Twin Intel Xeon E5 2673 v2 OEM processors (thats a total of 16C/32T) |
Motherboard | HP Dual Socket Motherboard |
Cooling | Stock HP liquid cooling |
Memory | 64GB Registered ECC memory kit (octal channel memory on this rig) |
Video Card(s) | MSI RX 5700 XT Gaming X 8GB |
Storage | 2 x 512GB SSD in raid 0 |
Display(s) | Acer 23" 75Hz Gaming monitors 1080P x2 |
Case | Brushed Aluminium |
Audio Device(s) | Integrated (5.1) |
Power Supply | HP 1125W Stock PSU |
Mouse | gaming mouse |
Keyboard | Dell |
Software | Windows 10 Pro |
Any advice? When I reboot at anything above 470Mhz FSB the CPU defaults to the lowest multiplier. I can then go into the BIOS and adjust the multi to 9.5 or below.
If I set it back on the 10x multi it simply defaults back to the lowest multiple (on reboot) instead.
In testing I can see the CPU appears to support above 500 MHz on the FSB... just this weird multiple issue... wondering if this is a known issue when running high FSB speeds.
Running with an Asus P5Q3 mainboard.
