OMGH4X!
- Aug 6, 2010
- 46 (0.01/day)
Processor | AMD PHII X4 955 |
Motherboard | M4A79XTD EVO |
Cooling | Hyper 212+ |
Memory | Corsair XMS DDR3 2GB (2x1GB) CL9 |
Video Card(s) | HIS HD5770 |
Storage | WD6401AALS |
Display(s) | Dell E771a CRT 1280x1024 |
Case | CoolerMaster 690 |
Power Supply | Corsair Tx650w |
Software | Vista SP2 |
I have been having problems with this 'board since i got it..
at first it was just small things, like very occasionally i would get 'NO SIGNAL' msg from my monitor on boot and sometimes not detecting HDD/USB media..
A few weeks ago i started getting BSOD's and after running some memtest86+ i was convinced it was the ram... i pulled out the offending stick and have been finerunning since then with 1gb installed.
So today i got another 2gb kit in the mail.. here's where things get a bit weird..
I removed the remaining 1gb from my mobo, opened up the new kit and chucked it in there, reset the CMOS jumpers, and.. it freezes dead at the green ASUS screen.
So at this point i'm thinkin' it's gotta be the 'Board, right?
I reboot a couple times and it finally gets into windows... runs stable for a few mins on prime95 then crashes
I remembered reading that sometimes you can have memory errors caused by bent CPU pins, as the memory controller resides on the CPU itself.
So with this in mind i took everything apart to have a look. The pins were fine but i did notice quite a bit of thermal gunk in places it shouldn't have been (namely; the side of the cpu and on the 'board around the socket) which i promptly removed with some tissue.
Re-assembled, stuck the new kit in there again and it boots fine this time
So.. i throw my other -previously troublesome- 2gb kit in there alongside the new (same model from corsair) so that i have 4gb installed. POST fine.. boots fine.. prime95 fine -touch wood- still running while i'm typing this
I am so confused... it could be (A) something messed up with the mobo (B) due to aforementioned MX-2 (C) maybe the new kit i got just needed warming up (D) Any number of other things i guess..
So yea.. my question is; Could cleaning the CPU and MB really have fixed the problem?
Is that even possible? :S
PS: ThankYou for reading
