(Please excuse me if this was posted already somewhere else and I missed it, If not, here we go
Findings on how to make Ryzen 3000 CPUs go faster, or cooler, or more power efficient.
Sure, the internet is full of reviews, but why not have our little corner.
--- My findings today on a R7 3700x ---
It's "boost" speeds (both single and multi thread) depend on... Voltage ?
- On "Auto" my mobo was setting 1.4 (ish) or something, it boosted to 4.2-4.25 multi core and 4.4 single thread... but the thing gets very hot (90+) degrees in multi-core tests.
- I gave it 1.1 volts manual in bios, the computer worked FINE. No crashes, nothing... but it was slower, barely cracking 3.9 multi core and a slow-ish 4.1 single thread
- I gave it 1.3 volts, the boosts increased more
... I stopped at 1.45 due to reaching thermal throttling even with all fans (case+cpu) turned to max. But it was boosting to 4.4 (advertised speed) A LOT (single thread), and sustained 4.3 Ghz on all cores !! (at least until the temperature took over)
(Using boxed cooler right now, no fancy AIO so I can try even more. But I'll probably need to buy one if I want that sweet 4.4 Ghz to happen)
Using PBO +OC ( +100 Mhz) I've seen it boost to 44.5, but ONLY on 1.45 volts. If I lower the voltage, it simply doesn't go there, doesn't matter what temp it has.
So...
First day of findings ... Automatic CPU clock depends directly on the Voltage given to it.
This is quite different from Intel, or even my previous 1700... which were simply crashing if it didn't have enough volts for stability.
I'm still puzzled on how these new things work...
What's your experience ?
Experiment - Over/Undervolting and running Cinebench R20
How low can it go before I'm unable to run CB ... or boot in windows ?
( Before anyone asks, the CPUz screenshots were taken WHILE CB WAS RUNNING... so that's the 16-threads operating voltage )
1.45v (THROTTLY THROTTLY)
CPUz:
Temp:
(going nuclear)
(Will try 1.425 just for science at the end)
1.4 v (let's get cookin')
CPUz:
Temp:
(smokin' !!)
1.375 (not getting any faster) ( ran out of attachments ... max 30)
CB: 4800 | CPUz Volts: 1.395 | Temp: 89 degr.
1.35v (BOOM baby ! Seems to be the sweet-spot - for my CPU at least)
CPUz Volts: 1.363 Temp: 86 degr. (toasty)
1.325v ( getting faster, but not that much faster)
CB: 4786 | CPUz Volts: 1.341 | Temp: 84 degr.
1.3 v ( now we're getting some speedz ! )
CPUz:
Temp:
(hottie)
1.287 v (found it ! This is the magic voltage where it starts to boost higher)
CB: 4252 | CPUz Volts: 1.297 | Temp: 76 degr.
1.275 v (nope, still slow...)
CB: 4046 | CPUz Volts: 1.286 | Temp: 74 degr.
1.25 ( hmm, not any better than the lower voltage )
CB: 3966 | CPUz Volts: 1.264 | Temp: 71 degr.
1.2 v ( beats me... seems that the CPU really doesn't like 1.1v-1.275 ... )
CPUz:
Temp:
(steamy)
1.1 v
CPUz:
Temp:
(warmish)
1.05 v (Yes, it's slower than 1.00 or 0.925) !! Ran it several times
CPUz:
Temp:
1.00 v
CPUz:
Temp:
0.975 v
CPUz:
Temp:
0.95 v
CPUz:
Temp - The same, doesn't drop more on my system. It's quite hot here in my room...
0.925 v
CPUz:
Temp:
(just chill)
0.9 v
(Cinebench crash as soon as I hit RUN, followed by Bluescreen)
So, it doesn't seem it got any slower until 0.925v, below that... Volts->
<- 3700x
So...
1.1 v
1.00 v
0.975 v
0.95 v
0.925 v
0.9 v
