- Jun 17, 2007
- 7,336 (1.12/day)
- C:\Program Files (x86)\Aphexdreamer\
System Name | Unknown |
Processor | AMD Bulldozer FX8320 @ 4.4Ghz |
Motherboard | Asus Crosshair V |
Cooling | XSPC Raystorm 750 EX240 for CPU |
Memory | 8 GB CORSAIR Vengeance Red DDR3 RAM 1922mhz (10-11-9-27) |
Video Card(s) | XFX R9 290 |
Storage | Samsung SSD 254GB and Western Digital Caviar Black 1TB 64MB Cache SATA 6.0Gb/s |
Display(s) | AOC 23" @ 1920x1080 + Asus 27" 1440p |
Case | HAF X |
Audio Device(s) | X Fi Titanium 5.1 Surround Sound |
Power Supply | 750 Watt PP&C Silencer Black |
Software | Windows 8.1 Pro 64-bit |
Gpuz has four Temps.
GPU Temp
Temp #1
Temp #2
Temp #3
They read
GPU Temp= Max (load) 81C
Temp #1= Max (load) 81C
Temp #2= Max (load) 89C
Temp #3= Max (load) 81C
Which one is accurate? the 81C or 89C and are these temps safe?
I'm currently pushing my card to its limits *Hopefully safe limits and I just want to be sure.
I've raised the volts just below 1.300 so that on load it hits 1.2938 and VDDC is 57%
Am I good or am I killing the card? I'll most likely have it running 24/7 like this if its safe. I can understand a lower life expectancy from daily usage but is this to extreme?
Thanks.
GPU Temp
Temp #1
Temp #2
Temp #3
They read
Thanks.
