Might be wrong ? Deshrouded GPU
drizztJK
3 (0.02/day)
Hi, new here but i wanted to ask some experts what i m facing with my 3080 Gigabyte 10gb OC
I built a terra case Terra — Fractal Design and i had no choice to deshroud my 3080.
The problem is that the 3 GPU LED (logo gigabyte) couldnt be removed (idk why but it was impossible) and I accidentally cut the wires attach to it.
The base of the 3PIN connector from the GPU LED stayed in there...
Is it easy to fix ? is there any change pieces available on internet, what would be the name ? Could it be dangerous (regarding electricity things...) ?
I'm a newbie in the domain and I just needed 2 cm more to fill up the full 3080.
Thanks in advance
2,199 (0.35/day)
System Name Ryzen7700
Processor AMD Ryzen 7 7700
Motherboard Asus ROG STRIX B650E-F GAMING WIFI
Cooling NZXT Kraken X62
Memory Patriot Viper Venom PVV532G700C32K (32GB @ 6000CL28)
Video Card(s) AMD Radeon RX 6800XT Midnight Black
We can't properly advice without pictures. A picture is worth a thousand words.
8,312 (5.23/day)
São Paulo, Brazil
Cooling Pichau Lunara ARGB 360 + Honeywell PTM7950
Memory 32 GB G.Skill Trident Z5 RGB @ 7600 MT/s
Video Card(s) Palit GameRock GeForce RTX 5090 32 GB
Storage 500 GB WD Black SN750 + 4x 300 GB WD VelociRaptor WD3000HLFS HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700 benchtable
Mouse Microsoft Classic IntelliMouse
Software Windows 10 Pro 22H2
If you just cut the wire it should be simple enough to fix - the simplest beginner soldering iron job - peel the plastic/rubber coating on both ends of the cut wire, tie them together, dip in the flux, drop of tin, flick the soldering iron, wrap it back in a piece of insulating tape (I like 3M's electrical tape) and you're set.
You can probably find a replacement part if you're still intimidated by this but, honestly, it's largely cosmetic and shouldn't affect the GPU's operation
710 (2.78/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Power down completely. A little dab of liquid electrical tape. Wait till cured. Power on. Pretend it never had lights to begin with.
drizztJK
3 (0.02/day)
Talking about this
(not exactly the same) stuck in the GPU board with the wire cutted.
2,199 (0.35/day)
Not enough info on how the connector is stuck on the board. I think you used the wrong kind of force when you tried to remove it.
I would say gently rock back and forth and try to pull.
