Missing FAN-Speed with 2.15.0
Yeti
6 (0.00/day)
I have two identical system with the same Grafic-Card (RTX 2080), the Same device Drivers (416.34), both are Windows 10 (1803) with full patches, but GPU-Z shows me different details. At Manni I'm missing the FANs
Identical loads ? really only way to do this is with a constant load.
Also by same GFX card, do\you mean two 2080s or two same, make and model , BIOS and OC ? for example .... MSI 2080 Gaming X's with in Gaming Mode. ?
New card is new, give it a few months
Both cards are: http://eu.palit.com/palit/vgapro.php?id=3027&lang=de
They are out of the box as I received them.
Identical load is no problem, put the same BOINC-Projects on the cards and you will see this
Do you have time for a quick debugging session? through Skype (text chat only), Forum PM, Email (in that order of preference)
Ah, sorry, have been on business travel and discovered your message just now.
Of course I will take the time to debug. I'm now in the office for several hours and you can contact me.
Skype and Skype-Business are installed, but I never have used them. You are welcome to try with Skype, but you have to tell what to do
try to add me: "w2zzard" or "w1zzard@techpowerup.com"
Edit: Thanks for your help! The underlying issue was that your system had no monitor connected to the NVIDIA card, so some functions didn't work.
This is fixed now and the changes will be included in next release.
