Mobile 3070ti horrible performance in games while GPU frequency stays at 510 Mhz por even 210 Mhz
OceanWindRider
3 (0.00/day)
Hello, I have a last year Asus Zephyrus M16. It has i9 and 3070ti. IT's only a few months old.
I have been noticing for the last few weeks it showing about 20 FPS in games. I tried multiple games and very rarely it goes above 25 FPS. I also tried to switching resolution to 1280*800 and a bunch of other things - removing drivers with DDU, reinstalling them from scratch, reinstalling games, etc. I also tried Ultimate mode where NVIDIA is the only GPU. And of course Performance mode.Nothing seems to work much.
I think it's overheating but I also think this should not be such a problem. I am in a relatively cold climate and the temperature in the room should be around 18 Celcius.
Recently, I tried Cyberpunk, Starfield and CAll of Duty - all showing really bad FPS.
Any ideas? I bought it only 2 months ago in the USA. So it's technically under warranty, but I am in south america now.
So i am not sure what to do. Repasting in a private repair store would be an option of course. Not sure what else.. :(((
P.S. I tried to disable CPU Power boost in Power plan, it slowed CPU down and decreased CPU temperature significantly.. But no effect on the GPU clock.
Check my response in here possibly the same issue, long story short sounds like a hardware problem. If you use GPU-Z what is the reported power draw in the sensors tab ?
