Mobo CPU temp/Mobo-CPU diode temp. Diffrence?
Emery
5 (0.00/day)
Processor AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, MMX, 3DNow (2 CPUs), ~2.2GHz
Motherboard ASUS A8N-SLI nVIDIA nFORCE4 SLI
Memory 1024MB RAM ( PC3200 )
Video Card(s) NVIDIA GeForce 7900 GTX 512Mb
Storage WD 36GB 360GD SATA-150 10,000RPM 8MB / WD 250GB 2500KS SATA300 16MB 7200RPM
Display(s) 19" flatscreen
Case ASPIRE X-CRUISER
Audio Device(s) AUDIGY 4
Software Windows XP Professional
I am confused on the difference of these....From what I understand the CPU diode take tempature readings directly from the center of the CPU but not all mobos can utilize this information correctly, and I'm not sure how motherboard CPU tempature works. Motherboard CPU tempature is 38C idle, and Diode is 28C idle. 38C seems pretty high.
If I am completely off, and/or thier measuring 2 different parts of the computer, please correct me. But if they are reading the CPU, which one should I go by?
Also, using systool to read all the tempatures.
I don't know but even 38c is good. Most people get 40-ish idle and 60-ish load.
from now on you can use coretemp to read your cpu temps.its supossed to be the most accurate.
So are my assumptions correct...? I should go by the CPU diode reading? It seems to update much more quickly than the latter.
