Monitor flickering when the screen is dark! Help!
17 (0.01/day)
Processor AMD FX 8150
Motherboard Asrock N68-GS4 FX
Cooling 220 Fans x3
Memory 8GB DDR3
Video Card(s) GTX 560 Ti
Storage 120GB SSD, 500GB HDD
Power Supply 500W
Hello my people. T'is I, bearing a new issue to be tackled. This time, with less poems and bush-beating.
See, I have this barely-used 32' LED monitor, and it has a very simple, very strange, very annoying problem:
It flickers slightly whenever the screen is mostly dark.
When I say "mostly dark", I mean, dark or cold colors - or even, if I lower the brightness/gamma/contrast to the point of darkening what is in the screen, it starts flickering again. And, strangely, this only happens on dark backgrounds. Testing using this very forum - mostly white - as background, it was irrelevant how much I lowered the color settings to darken it, it would not flicker, whilst the same settings - and even higher, would still flicker in my dark-and-red desktop background.
Now, I know it's not the cables, because I tried two different VGA cables. And I know it's not the computer or the video card, since I did try in two different computers. And neither should be the age, since it two years bought, and it was used... rarely.
I tried different resolutions. I tried different frequencies. I tried reinstalling the drivers, taking out and plugging the video card again. I tried to take away all the electrical equipment, which in the case it was just the computer itself and a phone...
Oh, and the integrated light detector. I disabled that one too.
I'm fresh out of ideas. Suggestions?
EDIT 1:
I lowered the resolution to 1024x8xx, and the flicker disappears entirely. I'll keep testing on this...
EDIT 2: The moment I raise it any higher than 1024, the flicker returns. Yet, my anger only increases.
FreedomEclipse
~Technological Technocrat~
24,796 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
How bad is the flicker?? It could be one or two things... Either the inverter or light tube is dying or its just the panel itself thats made with technology that just flickers.
My Nvidia Shield tablet flickers all the time, I just have to get on with it or toss it and get another one.
17 (0.01/day)
Cooling 220 Fans x3
Memory 8GB DDR3
Power Supply 500W
It is a very slight flicker, but it is constant and very, very annoying.
It -should not- be dying since this monitor saw very little use.
Testing more, in a full or mostly full black screen I can notice the flicker - even in 1024.
FreedomEclipse
24,796 (3.77/day)
Sometimes it doesnt matter about usage - if a product is defective, its defective. Simple as
What brand is the monitor? Do you have a brand and model number?
17 (0.01/day)
Cooling 220 Fans x3
Memory 8GB DDR3
Power Supply 500W
It's Hisense, which I don't really know how well known it may be out of this country.
Still! Model should be... ah... HLE3215E.
Frick
Fishfaced Nincompoop
20,065 (2.87/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Does it have DVI? If yes, use that. I have had the same problems with anything VGA across a number of monitors, GPUs and cables and I have no idea what the problem is. It does not happen over DVI.
9,801 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Could also be a grounding issue.
1,610 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Thermalright Phantom Spirit 120 EVO / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) MSI RTX 4080 Super Gaming X Slim / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Asus AP201 / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM1000e / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
Looks like a common VGA Problem, I had that with several VGA monitors that I used, some of them had ridiculous horizontal scan lines while on the dark backgrounds, Switching to DVI completely fixed it.
1,269 (0.33/day)
West Bromwich UK
System Name El Calpulator
Processor AMD Ryzen R7 7800X3D
Motherboard AORUS X870E Elite WiFi 7
Cooling ArcticCooling Freezer 3 360ARGB AIO
Memory 32GB Corsair Vengance 6000Mhz C30
Video Card(s) MSI RTX 4080 Gaming Trio X @ 2925 / 23500 mhz
Storage 5TB nvme SSD + Synology DS115j NAS with 4TB HDD
Display(s) Samsung G8 34" QD-OLED + Samsung 28" 4K 60hz UR550
Case Antec Flux+ 6 ARCTIC P14 PWM PST A-RGB
Audio Device(s) Marantz PM4001+Fosi P4+2xPolk XT60
Power Supply be quiet! Pure Power 12 M 1000W ATX 3.0 80+ Gold
Mouse Logitech G502X Plus LightSpeed Hero Wireless plus Logitech G POWERPLAY Wireless Charging Mouse Pad
Keyboard Logitech G915 LightSpeed Wireless
Software Win 11 Pro
Benchmark Scores Just enough
Hisense is not the best company in the world but not the worst either so why not send an email to their support team and inform them about this issue...
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Sounds like a faulty monitor.
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
When using VGA anything above native resolution will always cause some problem or another. You could use gold plated cords and any top of the line graphic card, VGA resolutions are the best you can hope for. Switch plugs to anything else.
17 (0.01/day)
Cooling 220 Fans x3
Memory 8GB DDR3
Power Supply 500W
It doesn't seem to support DVI, though HDMI is an option.
And while I have the HDMI cables, I don't have any HDMI output from my computer, but my video card has the good DVI and I have a VGA adapter.
Mm, let's see if there's such thing as an HDMI adapter from DVI...
1,610 (0.34/day)
Mouse Logitech G903
VR HMD Rift S
You should be able to use the DVI to HDMI adapter with your 560 Ti
17 (0.01/day)
Cooling 220 Fans x3
Memory 8GB DDR3
Power Supply 500W
Actually, yeah. I noticed that...
The 560 has HDMI support, but I didn't see it as first.
This, NATURALLY, brought new problems.
I have an HDMI cable, but OF COURSE it doesn't fit the HDMI port of the video card - because it is MINI HDMI.
Excuse me while I foam by the mouth and buy a mini-to-standard adapter.
Actually, a question:
Having the option to use the HDMI or DVI ports, which one should I choose?
My bard levels tell me that HDMI is better because Reasons.
1,610 (0.34/day)
Mouse Logitech G903
VR HMD Rift S
HDMI is digital only, whereas DVI still has some analog capabilities. HDMI can output sound, whereas DVI can not. Although I do like that DVI has some sort of locking features that HDMI does not have.
9,801 (3.23/day)
Case Phanteks NV7
I find it strange that card doesn't have DVI-D or HDMI. If that is the case you would need an active converter , which are more expensive.
1,610 (0.34/day)
Mouse Logitech G903
VR HMD Rift S
I find it strange that card doesn't have DVI-D or HDMI. If that is the case you would need an active converter , which are more expensive than.
400 and 500 series cards had mini-HDMI on them, so you still require an adapter for that. DVI isn't really an option for OP as his monitor doesn't have a DVI input. Better off with a DVI to HDMI adapter on the card itself, at least he'll get some sound out of that :D
@icelandia would you be able to post what card you have, so that everyone knows what you use?
23,888 (6.16/day)
HDMI for me personally: if I can avoid it I will.
DVI > DP are the only two I consider with DP having preference due to great bandwidth.
I like DVI for being no-nonsense, quick to connect/detect (faster than DP) and splitting the sound out of the signal is also generally an advantage to me, especially in PCs because monitor speakers suck if they even exist on your desktop.
HDMI is like the ugly little commercial rat that was invented to enforce limitations that shouldn't be there - look at current HDMI spec and how often its updated, the whole idea is dead to me from the day it was released. We're now struggling with 4K capable hardware that lacks HDMI 2.0... ridiculous.
17 (0.01/day)
Cooling 220 Fans x3
Memory 8GB DDR3
Power Supply 500W
Let me leave it clear now:
The video card has DVI-I x2, and a mini-HDMI.
The monitor has HDMI and VGA, but no DVI.
My specs are just on the left!
23,888 (6.16/day)
Consider mini-HDMI to HDMI. With that you've probably got a cable you might use for some exotic connection in the future when you replace the video card. DVI> HDMI is highly unlikely to have such purpose for anything new - although if you juggle old monitors, that has some use too.
9,801 (3.23/day)
Case Phanteks NV7
Then it's simple , find a HDMI full to mini-HDMI cable. No way to guarantee that will solve your problem though, I am more inclined to think this has something to do with the monitor.
1,610 (0.34/day)
Mouse Logitech G903
VR HMD Rift S
Having a mini-HDMI to HDMI cable is as useful as drinking coffee with a fork - no new cards use them.
17 (0.01/day)
Cooling 220 Fans x3
Memory 8GB DDR3
Power Supply 500W
I'm crossing my fingers with the cables and video output. Considering the cables and adapters themselves are like $3, I believe I can afford the try.
17 (0.01/day)
Cooling 220 Fans x3
Memory 8GB DDR3
Power Supply 500W
Okay. Enough.
The steaming stack of issues that come with this monitor vastly outweigh any advantage that it may bring.
Thank you all guys for the assistance, but I think I'm going back to my trusty 19'.
OneMoar
There is Always Moar
8,837 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
its back-light flicker probably a failing back-light or inverter board
hisense are like the lowest on the craptacular monitor scale
you get what you pay for
