- Dec 15, 2011
- 1,964 (0.40/day)
- Sydney NSW, Australia
System Name | Shoebox Sandwich | Razer Blade 14 | Synology DS423+ w/ 4X8TB WD Red | ROG Ally | Mac mini |
Processor | AMD Ryzen 7 7800X3D | AMD Ryzen 9 5900HX |
Motherboard | ASRock B650E PG-ITX WiFi | Razer thing |
Cooling | NZXT Kraken 240 RGB w/ Lian Li P28 + Corsair AF120 Slim | Double fan vapour chamber |
Memory | G.Skill Flare X5 2x16GB 6000MHz CL32 DDR5 | 16GB 3200MHz DDR4 |
Video Card(s) | Sapphire Radeon RX 7900 XTX | NVIDIA GeForce RTX 3070 8GB |
Storage | Seagate FireCuda 520 2TB + Lexar NM790 4TB | 1TB NVMe SSD + 2TB NVMe external SSD |
Display(s) | Alienware AW3423DW & Sony A90K 42" | 14" QHD IPS 165Hz & Sony BRAVIA 9 75" TV |
Case | FormD T1 - v2.1 - Titanium colourway w Aluminium mesh | Razer Blade 14 |
Audio Device(s) | Schiit Hel 2E (Focal Clear & HiFiMAN HE-4XX & DROP PC38X) | Samsung Q950A |
Power Supply | Corsair SF750 Platinum | Razer 230W brick |
Mouse | Razer Viper Ultimate Mercury | Roccat Kain 202 |
Keyboard | Womier SK75 (Green) | Corsair K63 |
VR HMD | Oculus Quest |
Software | Windows 11 Home | Windows 11 Home |
Benchmark Scores | 2022 MINI Countryman SE PHEV Hybrid ALL4 | British Racing Green| Malt Brown Interior| YOURS Trim |
Hey guys, I have an issue with my BenQ GW2765HT where if I turn on my computer with the monitor in standby (orange light) status the monitor will not wake up. I must then unplug the monitor from the AC power and then replug it and then also restart my computer before the monitor will wake up. This issue is intermittent however and also strangely if I do a restart from Windows the monitor goes to standby for a second or two before waking back up when the POST screen appears which is normal behaviour. So it seems only if the screen is on standby for some time does it fail to wake up again.
Also the monitor will not wake up if it is powered off (although still plugged in) under the same circumstances as if it were just on standby status and also requires the AC power to be disconnected and the computer to be restarted before it wakes up.
Any suggestions? Or should I just take it back to my shop?
info; I bought it in the middle of August last year.
edit; I am using a displayport cable. I've tried a different displayport cable and also with a different computer and I have the same problem. I also tried DVI and it happened more often.
