Monitor says no signal (gpu problem)
Synocrypt
1 (0.00/day)
Hello! So this might be an easy solution post of just returning it but, I just bought a new gpu. A 3060 ti nvidia. Old one was a 1660 super. When I put in the new one it just says “no signal” on both monitors. I applied both the same and the one I had originally worked but this didn’t. i Inserted into the slot correctly.
I’m not sure if it’s whatever this is. I only needed one of these for my old gpu and since this needed two I found another in the pc. It might be the gpu itself and maybe damaged I’m not sure please help It’s pissing me off
142 (0.16/day)
Processor AMD Ryzen 2700X
Motherboard MSI X470 Gaming Pro Carbon
Cooling NH-D15 SE-AM4
Memory 4x Kingston 8GB DDR4-2666
Video Card(s) 2x EVGA GTX 960
Storage Kingston SA400 480GB, LSI 9260-8I RAID[2x WD4005 4TB, 3x Kingston SA400 480GB]
Display(s) Scepter P30, Samsung T22B350
Case Phanteks Enthoo Pro
Power Supply Seasonic Prime Titanium 650w
Mouse Logitech MX Master 3
Keyboard Corsair K60 RGB Pro RGP01110
It's hard to tell from your photograph, but the right-hand connector may or may not be fully seated. Double check that you can't remove it without unlatching it, and that the plug has clicked into place. Also have you tried using other ports on your graphics card? Do the fans spin up on the GPU when you boot the computer?
Deleted member 229121
Was your 1660S connected with HDMI or Display port and what is your new card connected with?
You might have to just go into the OSD settings on the monitor and change it to a newer input method.
3,106 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
