Motherboard + GPU compatibility Q
59 (0.02/day)
System Name Teh 1080p Annihilator Destroyer Killer Crusher Smasher Wrecker Pwner @75hz
Processor i5 3570k @ 3.4ghz
Motherboard B75MA-P45
Cooling 3x 120mm fans + stock cpu cooler
Memory 8gb DDR3 1333mhz
Video Card(s) EVGA GTX 1060 3GB SC AXC 2.0
Storage crucial mx500 1tb
Display(s) Benq RL2455HM + Flatron W2453V
Case Thermaltake Commander MS-I Epic Edition Red
Power Supply Seasonic M12II 620w 80+ Bronze
Mouse g502 hero se
Keyboard Devastator II LED Gaming Keyboard with Red LED by Coolermaster
Hey guys so I'm on the lookout for possibly a new GPU, but I'm looking at my MoBo and I'm not sure if a 380x type card would fit? Their's a SATA III connector somewhat in the way and I dont wanna lose HDD performance.
My mobo is
b75ma-p45
The white SATA is the SATA III the others are II. Do you think their could be enough space? most cards like the 380x are about 10" x 5.5" and 1.65" height. and that SATA 3 is about 8" in
18,584 (2.64/day)
System Name AlderLake
The new videocard should be in the top slot, so no problems there with your sata.
59 (0.02/day)
Mouse g502 hero se
Hm? well that's awesome I somewhat tried to measure and all I could gather was it might be really really close so wasn't sure.
Unless anyone else figure's it wont fit then they can post other than that thanks for the quick reply :D
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
Just install the SATA connector before you put the GPU. Just be sure to use a righ angle connector, since otherwise it won't fit under the GPU.
Install the connector even if you aren't using it right now. You'll easily be able to attach a drive to it later without removing the GPU.
18,584 (2.64/day)
Hmm, I think it'l fit fine even with a straight connector, I think it makes no difference but ok a angled connector should work as well.
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I'd be more concerned about the ram slots being so close to the gpu once installed.
If you want to swap ram you would have to remove the graphics card.
2,318 (0.39/day)
Texas
System Name Mr. Reliable
Processor Ryzen R7 7800X3D
Motherboard MSI X670E Carbon Wifi
Cooling D5 Pump, Singularity Top/Res, 2x360mm EK P rads, EK Magnitude/Bitspower Blocks
Memory 32Gb (2x16Gb) GSkill Trident Z5 DDR5 6000 Cl30
Video Card(s) Asus Tuf 4080 Super
Storage 4 x Crucial P5 1TB; 2 x Samsung 870 2TB
Display(s) Acer 32" Z321QU 2560x1440; LG 34GP83A-B 34" 3440x1440
Case Lian Li PC-011 Dynamic XL; Synology DS218j w/ 2 x 2TB WD Red
Audio Device(s) SteelSeries Arctis Pro+
Power Supply EVGA SuperNova 850G3
Mouse Razer Basilisk V2
Keyboard Das Keyboard 6; Razer Orbweaver Chroma
I would be concerned about this also, especially if the GPU you're looking at includes a backplate.
JAT
59 (0.02/day)
Mouse g502 hero se
That is interesting guess I hadn't concidered about the backplate either and will have to take that into account. XFX doesn't have a backplate though so yeah even though I'd prefer a GPU with one. and if it did fit with a backplate would the backplate melt the ram slots or anything?
One more thing also I'm sure this is a no but this mobo doesn't support pascal/polaris right? and negative on DDR4 ram too?
776 (0.23/day)
All your questions i met a long time ago , from a boy . The backplate cant be an issue . The mobo has PCI-E x16 gen 3.0 slot , thus any PCI-E card will work , Polaris/Pascal included . No DDR4 support , only DDR3 RAM
https://www.msi.com/Motherboard/B75MA-P45.html#hero-specification
Edit : If have trouble with the backplate , remove it . It should be possible
MSI are no fools , they know long card exist . So dont worry about video card , close to the RAM slots .
59 (0.02/day)
Mouse g502 hero se
was it polaris/pascal that has ddr5x memory? thought it'd be like ddr4 and not compatible. that's pretty new to me if my mobo is compatible with pascal/polaris and that's sweet. and true about the backplate, thanks
776 (0.23/day)
VRAM (GDDR5 here) has nothing to do with system /PC RAM . The first is on the video card . It must be compatible with the video card only .
59 (0.02/day)
Mouse g502 hero se
ok awesome thanks :)
