Mouse and keyboard
179 (0.10/day)
Serbia
System Name Dell Precision Workstation 5820 XL Tower
Processor Intel Xeon W-2195 18 cores 36 threads 2,3 - 4,3GHz 25MB l3 cache 8GT/s QPI
Motherboard Dell 0TVW7J
Cooling Air
Memory 8x32GB (256GB) DDR4 ECC registered Samsung 2400MHz CL17
Video Card(s) Manli Gallardo RTX 3080 Ti
Storage 10TB
Display(s) HyperX Armada 25 240Hz
Case Dell Precision 5820 XL Tower
Audio Device(s) Jamo Cornet 145, Technics SU-VZ320, Yamaha YST-SW80
Power Supply Delta Electronics H950EF-00 950W
Mouse Asus ROG Chakram
Keyboard Asus ROG Claymore II
Software Window 11 Pro for Workstations x64 24H2
Benchmark Scores 3D Mark Time spy 16848
Look at the peripherals I have. The mouse and keyboard are wireless. They become depleted over time and must be recharged. This leads to the conclusion that they have a battery. It is known that every battery has a lifespan. Now I wonder what will happen when that battery can no longer be charged. Does this mean that both the mouse and keyboard will become wired instead of wireless peripherals?
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
:roll:
Sorry. No disrespect meant. But the fact the mouse and keyboard are "wireless" is what should have led you to the conclusion they use batteries.
According the reviews I can find, both your mouse and keyboard do support wired mode operation, as well as wireless. My "guess", to answer your question, depends on how the battery fails.
If the battery, after [hopefully] 100s and 100s of recharges just gets tired and too weak to hold a charge (the typical end result with rechargeable batteries), the device "should" keep working in wired mode.
HOWEVER, some batteries fail by developing an internal short. And if that happens, it is likely the device will not work, even in wired mode because the voltage require to operate is being shorted back to ground.
Hopefully, for that kind of money, both the keyboard and mouse will give you many years of quality service and will be retired or replaced by you for other reasons, besides the battery failing.
179 (0.10/day)
Serbia
Cooling Air
Storage 10TB
Mouse and keyboard work normally when connected by cable while charging. But cable is very rigid and not elastic.
Anyway, many thanks for responding. :clap::lovetpu:
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Not a problem with the keyboard but that would be unacceptable with a mouse. Personally, I don't like wired mice, even with light and very flexible cables.
Well, hopefully yours lasts many years. Fingers crossed.
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Two things....
The batteries are replaceable, but you have to open the devices to do this.
You can buy custom cables to fix the rigidity.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Lei
1,143 (0.82/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
@uco73
Do not store your devices with empty battery.
That is if you're not using a mouse or keyboard for weeks, make sure to charge them before you leave them alone.
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
I reviewed a ton of peripherals and all internally battery powered options used a two pin plug that is user friendly.
5,487 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
I just use hardwired keyboards and mice, replacing switches and cables as I go; just can't stand one extra thing to take care of (batteries).
1,816 (0.97/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
I refuse to use wireless keyboards, mice or joypads. I like the security of a cable, until my kitten eats through it.
360 (0.19/day)
System Name myPC
Processor i5-11600k @ stock
Motherboard Asus TUF Z590 Gaming Plus
Memory Corsair Vengeance LPX 2x8GB DDR4 3200
Video Card(s) Asus Dual RTX 3060 ti
Storage Boot: WD Black SN770 1TB - Game Storage: WD Black SN770 2TB - Other Storage: 4TB
Display(s) Samsung Odyssey G5 curved 27" 1440p 144hz
Case Thermaltake v100 perforated
Audio Device(s) Some headphones and some speakers
Power Supply Gigabyte UD750GM
Mouse Logitech G203
Keyboard Redragon K509
Software W11 Pro
The mouse looks pretty easy, keyboard looks like a ribbon cable maybe. Pics from TPU articles.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Years ago, security might have been a problem for a few in certain scenarios. But these days, AES Encrypted Wireless devices are easy to fine.
I think it also important to remember for the data exchange between your keyboard and computer to be compromised, the bad guy must essentially have physical access at your location. This is because the effective range for such BT and RF devices is very limited. So even if your devices do not support AES Encryption, you have to ask yourself, how likely is a bad guy going to get that close without you being aware of him/her? If you work in a crowded office with 30 cubicles around you, then maybe that will be an issue. In your home? Not likely.
That said, if the bad guy has that level of access, you have bigger problems than the data between your keyboard and computer being compromised.
Lei
1,143 (0.82/day)
usually in my shirt
My keyboard uses two AAAs, but I juice it with LiPo
360 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
  • Like
Reactions: Lei
Lei
1,143 (0.82/day)
usually in my shirt
Does the software show the battery level or is there a LVC?
Nope, keyboard front light blinks red when battery is near finished.
I added a charging board:
batteries could last for 2 months, LiPo works much longer
18,584 (2.63/day)
System Name AlderLake
I use a Rapoo 5Ghz wireless keyboard, it uses 2AA batteries and they last long (1 year+), I use duracell, same with my wireless xbox controller.
  • Like
Reactions: Lei
6,683 (1.59/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard Beelink/AZW SEI
Video Card(s) Iris XE
Storage WD Black SN850X 8TB m.2, Seagate 4TB SSD + SN850 8TB x2 in an external enclosure
Display(s) 2x Samsung 43" + 1x 32"
Audio Device(s) No-name compact bluetooth speakers
Power Supply 65w brick
Mouse Logitech MX Master 3
VR HMD Whahdatiz ???
Benchmark Scores PDQ
I have several Logi G613's, which are all used for an average of 6-8 hrs/day x 6 days/week, in which I use the PinkBunny AA Lithiums, and the last time I changed them was about 2 years ago :)
My MX Masters, which are used along with the above 613's, usually will last about 6-8 weeks on a charge....
#CordedPeriphsBeGone4Eva#
  • Like
Reactions: Lei
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
My Microsoft 5050 keyboard also uses 2AA and also gives me ~1+ year support. There is a little red LED indicator light on the keyboard that will light when I need to replace them.
I avoid Duracell AA and AAA batteries (and their Costco/Kirtland rebranded versions) as much as possible. I've had more problems with leaking Duracell batteries over the years than any other brand. :(
Now, I typically use rechargeable Nimh (Nickel Metal Hydride) or Member's Mark (Sam's Club) batteries, which are made by the pink bunny :). The rechargeables don't typically last as long as non-rechargeables before they need to be recharged, but they don't end up in the trash and landfills either - at least not right away, as frequently, or in the massive quantities as regular alkaline batteries.
18,584 (2.63/day)
No issues with that here, btw there are various Duracell AA type batteries, I'm using "Duracell Plus" at the moment, before that I used Duracell Industrial.
If I had leaking onces from some brand I wouldn't buy them anymore either.
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Yeah dam those Duracell and the rechargeable have been terrible as well, never used to have a issue with them but over the last 6-7 years they are trash and just ride on the name of what they used to be.
18,584 (2.63/day)
Well the Duracell I buy here are from the Duracell factory Belgium, no issues at all!
Ok I don't have Duracell rechargeables though, don't know about that.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
I have never used Duracell rechargeables either. But it should be noted that rechargeables use a different chemical process, typically Nimh, and not alkaline. I don't believe Nimh batteries are prone to leaking.
1,262 (0.21/day)
Duracell switches OEMs from time to time. idk if they still use rebranded Enelooops these days, but the ones that were rebranded Eneloops are/were good.
I haven't purchased any rechargeables other than Ikea's for years now though, since they're the cheapest and most consistent source of rebranded Eneloops available AFAIK
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Never had the rechargables leak but they don't seem to last as long as others say LA Crosse or eneloop, they are older then the dura rechargeable and still going strong were the duracell ones i have had several of them fail and all are in low power usage items like thermistates and remotes etc.
264 (0.25/day)
Processor 7950X, PBO CO -15
Motherboard Gigabyte X670 AORUS Elite AX (rev. 1.0)
Cooling EVGA CLC 360 w/Arctic P12 PWM PST A-RGB fans
Memory 64GB G.Skill Trident Z5 RGB F5-6000J3040G32GA2-TZ5RK
Video Card(s) ASUS TUF Gaming GeForce RTX 3070
Storage 970 EVO Plus 2TB x2, 970 EVO 1TB; SATA: 850 EVO 500GB (HDD cache), HDDs: 6TB Seagate, 1TB Samsung
Display(s) ASUS 32" 165Hz IPS (VG32AQL1A), ASUS 27" 144Hz TN (MG278Q)
Case Corsair 4000D Airflow
Audio Device(s) Razer BlackShark V2 Pro
Mouse Logitech M720
Keyboard G.Skill KM780R MX
Software Win10 Pro, PrimoCache, VMware Workstation Pro 16
It's best to use low-self-discharge (LSD) batteries for devices that don't drain batteries fast, like keyboards, mice, TV remotes. Precharged rechargeable batteries are typically, if not always, LSD.
