Mouse scrolling up sometimes when I scroll down
2,365 (0.44/day)
Marlow, ENGLAND
System Name Chachamaru-IV | Retro Battlestation
Processor AMD Ryzen 9 5900X | Intel Pentium II 450MHz
Motherboard ASUS ROG STRIX X570-F Gaming | MSI MS-6116 (Intel 440BX chipset)
Cooling Noctua NH-D15 SE-AM4
Memory 32GB Corsair DDR4-3000 (16-20-20-38) | 512MB PC133 SDRAM
Video Card(s) nVIDIA GeForce RTX 4070 FE | 3dfx Voodoo3 3000
Storage 1TB WD_Black SN850 SSD (OS), 3TB Toshiba (Storage), 8TB Seagate FireCuda/2TB WD_Black SN580X (Steam)
Display(s) Samsung Odyssey G5 27" @ 1440p144 & Dell U2412M @ 1200p60
Case SilverStone Seta A1 | Beige box
Audio Device(s) Creative Sound Blaster AE-7, Edifier speakers, Grado Labs SR80 X headphones | Sound Blaster AWE64
Power Supply EVGA Supernova 750 G2 | 250W ASETEC
Mouse MX Master 3S| Microsoft Serial Mouse v2.0A
Keyboard Vortex Race3 | Dell AT102W
Software Microsoft Windows 11 Pro | Microsoft Windows 98SE
I decided to retire the mouse I was using, as the rubber grip was getting a little sticky. I pulled two completely different mice out of storage (a regular mouse and a trackball), and both exhibit this strange problem while scrolling. While I'm scrolling down, it will either suddenly scroll up or skip a scroll. I have never come across this issue before, and both mice were used without issue in the past. I've uninstalled all drivers related to the previous mouse, and restarted my computer, but to no avail.
Anyone come across this issue?
silentbogo
5,649 (1.35/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
That's most likely a mechanical issue, not the software.
What mouse do you have? Do you have a mechanical or optical scroll wheel?
If it's mechanical, then the surest way to fix it is to replace the encoder. If it's an optical scroll, then you should start with cleaning the wheel assembly (optical sensor, holes in the wheel etc.)
2,365 (0.44/day)
Marlow, ENGLAND
I have an identical issue with two completely different mice of different types. It's not a hardware issue.
silentbogo
5,649 (1.35/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Just because you have two random old mice in a shed does not mean that they both don't have the same hardware issue. Mechanical scroll wheel (encoder) is the most common problem, even more common than faulty buttons. Try changing scrolling sensitivity, removing any type of "smooth scrolling" plugins, and if it won't help - clean your friggin' mice! :laugh:
Deleted member 24505
Tbh, they probably need cleaning. Erratic scroll wheel behaviour is probably hair or some crap stuck in it.
911 (0.36/day)
Al Balqa', Jordan
Processor AMD Ryzen 5 2600, OC: 4.0 GHz @1.3 V
Motherboard ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta]
Cooling Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust)
Memory Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8)
Video Card(s) Palit GeForce GTX 1660 Ti Dual OC
Storage Kingston NV2 1 TB
Display(s) MSI PRO M251 (HDMI), Running @104 Hz
Case Cooler Master MasterBox MB520
Audio Device(s) HP H360G USB
Power Supply Cooler Master MWE 550 80+ White
Mouse HP G200 Black
Keyboard Redragon MITRA K551-1 RGB
Software Windows 11 Home
I have the exact problem , if you scroll down so hard and fast it'll start skipping and scrolling up , if you are scrolling gently everything goes fine , i'm really used to it.
6,431 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
I had it with my old Logitech G400, people reported it on MX518, it's due to optical sensor for scroll wheel action. The only way to "solve" this is to switch to a mouse with mechanical scroll wheel. Alternatively you can simply ignore it and learn to live with it.
259 (0.06/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
I've encountered this problem on multiple Steelseries Sensei RAW mice. These mice have a mechanical encoder for the scroll wheel. I'm pretty sure it's the mechanical encoder that is causing this.
On the mouse I used to use I cleaned the encoder using alcohol and then greased the encoder and it seems to have mostly fixed the issue. I used thick grease that is safe on plastics.
The best way to fix this is to probably replace the encoder.
If two mice that were previously good suddenly develop this problem, I would check them on another PC to make sure it's not a software issue.
2,365 (0.44/day)
Marlow, ENGLAND
After a couple of days, it miraculously stopped. Must have been a gremlin.
44,274 (6.80/day)
