Mouse smoothing
Does mouse smoothing have any effect in games on fps number?
  • Yes
  • No
Results are only viewable after voting.
231 (0.06/day)
System Name hazazs
Processor Intel Core i7-6700K @4.0GHz
Motherboard MSI B250 GAMING M3
Cooling be quiet! Shadow Rock Slim / 2 * be quiet! Shadow Wings 140mm / 3 * be quiet! Shadow Wings 120mm
Memory 2 * 8GB Corsair Vengeance LPX DDR4 @2133MHz CL13 Red
Video Card(s) MSI GTX 980 Gaming 4G
Storage Samsung 970 EVO Plus 1TB / Kingston DataTraveler SE9 G2 8GB
Display(s) Dell P2219H / SONY KDL-43W755C
Case Cooler Master Silencio 652S
Audio Device(s) Creative Inspire P580 / Sennheiser PC 320
Power Supply Cooler Master V550 Semi-Modular
Mouse Logitech G300S
Keyboard Logitech Ultra-Flat
Software Microsoft Windows 10 Professional x64
Hi all,
Does mouse smoothing have any effect in games on fps number? Is it possible that the games will be smoother (based on fps numbers) then this option is enabled? Or just the mouse move?
Thanks,
hazazs
No, but you shouldn't really use mouse smoothing in games anyway, particularly shooters. Ideally you want zero acceleration and raw mouse input.
I like to use mouse smoothing for photoshop and that's about it.
No difference to frames per second, but noticeable difference to lag in first person shooter games. Basically don't bother.
OP asked about amount of FPS, not the games (at least thats how I read it) which the answer is no.
it is ONLY the movement of the mouse that "Smoothing" refers to, NOT "smoothing" of FPS. So no is the answer to Your question.
But I agree, Rcoon is correct, don't use it in game.If You have been using it for a while, it won't take too long for You to get used to NOT using it, and You'll be better off.
Thank you guys!
And Toothless is right, I meant fps as frame per second, not first person shooter.
What many aren't aware of is even if you use such settings in game AND in the Windows mouse options, you still actually have some mouse acceleration. It takes a registry hack to completely remove it.
I utilized this hack some time ago, and it made a noticeable difference. Honestly though, I don't advise it unless you have a mouse that has adjustable DPI sensitivity.
To the OP's question though, mouse smoothing CAN cause mouse lag, which some might mistake as FPS lag, but is not the same.
