Moving a dial up connection across computers
ex_reven
5,217 (0.76/day)
Ok guys, the beatdown is that im swapping out the hardware from an old packard bell (piece of shite) with a newer IBM that i have lieing around.
The PB belongs to my grandparents who have dial up internet and it originally had Windows ME.
The IBM has XP on it and much better hardware. The one thing Ive never done before is setting up a dial up connection.
The PB has a modem that I will move across into the IBM, but I dunno what i need to do on the software end of things other than install the drivers for it. How do I set up the dial up internet?
Thankyou for your time.
Use the Windows internet connections wizzard, just choose the Dial-up connections checkboxes etc. It's made to be easy.
:toast:
When i used to have dialup, well, i had it over a wireless connection.. with 3 computers connected it was hell, well thats off subject.. but.. Just set it up with the wizard, it should cover everything. Then a box will pop up where u must put the dialup connection details in and then it makes the very annoying dialing (you can disable the sound thank god)
