msi k9n neo v2 easy problem
curt
584 (0.09/day)
Processor amd phenom II x4 955be @4.2gh 1.4v 24/7 max so far 4.6gh 1.5v in windows
Motherboard asus crosshair V well cooled
Cooling dd mc tdx block with 10000btu a/c rad with cold air piped from outside
Memory ocz low volt reapers 1600mh @ 1667mh 8.8.8.20 1.6v
Video Card(s) bfg gtx 280 1gig core has hit over 733mh
Storage 2 intel 40gb ssd.s in raid 0/ 1tb seagate 7200.12
Display(s) 2x 19inch non wide lcd.s
Case none sits on back plate from a case lol
Audio Device(s) sb xfi extream music [pci]
Power Supply #1corsair tx850 for mobo/vid #2 enermax true 460wat for hd.s/cd/fans
Software xp pro/7 64bit [biggest comp out of 3 i run]
Benchmark Scores the marks ar well ownage lol
ok short is i need to flash the platnum so i get th v core ajusters an so on
any way the files ar difernt size an dosent wana let me flash i know theres away around it just cant remeber im trying to use this afud408 flash thing
curt
584 (0.09/day)
i did read a bunch of forums saying this platnum bios does work on the neo an they basikly show me how to do it then thay say read instructions to over rite old bios witch i cant see or arnt there [evin in the afud408 program i cant find any over rite old bios instructions]
so yeah the only reson it wont flash it size ones 1 mb the other is 512k
mins 1mb
the platnum is 512k
i got the check sum to by pass the bios model numbers but the size still says no
InnocentCriminal
Resident Grammar Amender
6,477 (0.88/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
Wonder if this would work for the older Neo2... maybe you need to do some more searching around dude. I'll see what I can when I look for some info on my board.
Good luck!
DrPepper
The Doctor is in the house
7,482 (1.19/day)
Scotland (It rains alot)
System Name Rusky
Processor Intel Core i7 D0 3.8Ghz
Motherboard Asus P6T
Cooling Thermaltake Dark Knight
Memory 12GB Patriot Viper's 1866mhz 9-9-9-24
Video Card(s) GTX470 1280MB
Storage OCZ Summit 60GB + Samsung 1TB + Samsung 2TB
Display(s) Sharp Aquos L32X20E 1920 x 1080
Case Silverstone Raven RV01
Power Supply Corsair 650 Watt
Software Windows 7 x64
Benchmark Scores 3DMark06 - 18064 http://img.techpowerup.org/090720/Capture002.jpg
I was looking to do that with the k9n neo v3 same board except with a nforce 560. Couldn't find a way to do it but I saw on forums that some people could.
curt
584 (0.09/day)
yeah the platnum is sead to work on 550 to 570 not all fechures work but it works for the most part i have the specifyed platnum bios vershion 1.7
my board has the 560 chip [so my board would be the neo v3 sorry]
ill try an find a simaler bios that 1mb they sead dont use the ultra so i wont try that one
DrPepper
7,482 (1.19/day)
System Name Rusky
The neo v3 and v2 are incredibly similar, V2 drivers work really well on the v3. Anyway I was looking for a way to increase the vcore, Unless you know how to modify the bios I suppose you could try that.
curt
584 (0.09/day)
yeah i duno how to mod bioses wish i did u gota use hex thow i think
i took a look couldent rilly find any 1mb bioses
there ar pin mods for v core now i duno about amd but iv used them on p4.s an works great tricks the cpu/mobo into thinking the vcore stock is 1.3 istead of 1.2 so the bios would give you up to 1.450 i dont need that thow
i need the HTL mutiplyer
curt
584 (0.09/day)
omg lol cant beleave i missed it lol but i found the ht multiplyer it was allmost hidden but its msi so i figured it would be ther
will post top clocks from 4200+ 2200mh
curt
584 (0.09/day)
ok max cpu volts 1.350 mobo dosent alow higher
2900mh seams to be about max
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
I will never flash my BIOS.:rockout:
