MSI Twin Frozr III OC No GOP (graphics output protocol) detected
JuanIsHere
3 (0.00/day)
Hello all.
I stumbled here after searching my issue and noticed that there might be a way to fix this. I found this thread: https://www.techpowerup.com/forums/threads/cant-boot-with-uefi-enabled-in-bios.263238/ but even with this, I am not sure what to do. I got GPU-Z, and the BIOS seems to be the latest ones available, however, I still have this issue when botting up, even before POST, it gives me this error.
MOBO: MSI B550 EDGE GAMING WIFI
I am looking to know if this can be fixed. I assume I need to FLASH the BIOS. I got the programs that I need (I think I have them, I am using that thread above as a reference) but I don't know what file to use as FLASH.
Any help would be appreciated.
  • GK106.zip
    GK106.zip
Have you tried booting without any storage devices installed to see if that gets rid of the error message?
I have not done that as I am going to use it for an UnRaid server. At the end of the day, I don’t even think it would matter for an UnRaid server, but I decided to ask regardless.
it works perfect on my regular machine (where it’s installed now and I took these pictures and wrote original post).
I'm pretty sure there are no UEFI Bios for that series card.
It might run with the Motherboard's Bios in compatibility mode, CSM. (compatibility support module)
Hello. So basically I just let it do whatever it wants and I should be fine?
Thanks everyone for your help.
