[Case Gallery] My box o' hardware
0V3CHKiN
75 (0.01/day)
Processor AMD Athlon X2 4400+
Motherboard ASUS A8N-E
Cooling AMD Stock Heatsink
Memory OCZ Platinum 2x 1GB DDR400
Video Card(s) HIS X1900XT 512MB w/ Zalman VF-900
Storage 2x WD 400GB RAID 0 + 1x WD 500GB
Display(s) Samsung 17"
Case Lian-Li PC-G50
Audio Device(s) Creative X-Fi Music
Power Supply Enermax Liberty 500w
Software Microsoft Windows XP Pro w/ SP2
Specs:
AMD X2 4400+, ASUS A8N-E, OCZ Platinum 2GB DDR400, ATI X1900XT w/Zalman VF-900 mod, Plextor PX-716A & 760A, 2x WD 400GB SATA RAID 0, WD 500GB SATA, Creative X-Fi Music, Belkin firewire PCI card, Enermax Liberty 500w.
Mods:
So far I've only added the Zalman VF-900 to the ATI card.
Someone else had this case and mentioned there was little to do with organizing the wires. I'll be in the process of making it better somehow.
well right now the wiremanagement is horrible. push the wires up and under the harddrive tray and affix them to the bottom of the case as tight as possible.
You need wire management!!!!! Get that done and I think it will be a pretty good computer. 6/10. It will be 8/10 if you fix the wires.
Like the case but the wires are way to messy I give it a 6
Cables dude, cables.
6 here but will soon go up with some tidying
________________
OOoo mann ,cpu cooler under power supply..?
I think Ur better need wiremanagment..second is the casing is nice man..but the power supply at the bottom cpu cooler..?If me i better buy a new casing that not screw up power supply at bottom Cpu Cooler...remember dude this about heat...
I gave you an 8 out of 10, because there is no real modding. The cableing looks fine to me. I used that case and reviewed it here on TPU and I know how cramped that thing is.
cheers
DS
