[Case Gallery] My Case
JC316
Knows what makes you tick
9,397 (1.33/day)
System Name Budget Gaming
Processor AMD FX6300
Motherboard Gigabyte 880GMA-USB3
Cooling Coolermaster Hyper 212+
Memory 8GB Ripjaws DDR3 1600
Video Card(s) HD7850 1GB
Storage 1TB Sata2
Display(s) Acer 24" LED
Case Generic black
Audio Device(s) Stock onboard
Power Supply FSP Aurum Gold 650W
Software Windows 7 Home Premium 64bit
Specs:
AMD Athlon 64 3000+ @ 2.45GHZ
1GB PC3200 Corsair XMS 2.5-3-3-8 220MHZ
X1800XT 256 625MHZ 750MHZ
Mods:
Cable management fans added
nothing addtional
clean and to the point
i like the colors too
I wanted the black one, but the red one was the only one they had. Once I got it hooked up I liked the red one better anyway.
i love it when that happens
that's happened to me a few times with bikes
Lol, that's happened to me with...doughnuts. At first, I didn't like sprinkles, then I did because it looked cool...I know out of topic.
Great case, and nice, clean system. 8/10...
Nice case. Maybe you can get a nice CPU cooler.
7 from me
Pretty good, relatively tidy, easy on they eye, doesnt look like it sounds like a jet engine when its on. 7\10
i like the raidmax sagita case i wanted one but there hard to get here in the uk especially black ones
It is pretty quiet, if that X1800 get to 100% it aint so quiet anymore. If you put it on the floor, you can't hear anything, as it sits, it's more of a low hum. Anyone catch my cable tied fan in the PCI slots? Sure beat the hell out of a blow hole.
Do those actually work? Placing 80mm fans in the bottom?
Yeah, it dropped my temps BIG TIME. Since I have another one at the same level pulling air in, it creates a nice flow through. My ambient temps were 39*C, after that it dropped to 30-33*C, which in turn keeps my GPU and CPU cooler.
You can see in the pics that there is screen in bechind the LED's, I didn't realise it, but those are intake vents with a spot for a fan. It's really an all in one type case. Another thing is the quick connects, everything is screwless, just slide the quick connect and everything is mounted.
No, the case is pretty much stock. I removed the quick connects for the cards, because they were fugly and they didn't work well. I badged it up and add fans, thats the extent of the case modding.
