My gpu usage is always high even in idle mode. (RTX 4090)
22,203 (3.44/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4200(Running 1:1:1 w/FCLK)
Case Thermaltake Core X31
I believe it's a nvidia driver bug they are working on. No, your card is not actually being used that hard.
yoni280
5 (0.01/day)
I see, so it's only fake usage?.
what about using the cpu gpu for simple tasks like dwm?
771 (0.14/day)
Germany
System Name Acer Nitro 5 (AN515-45-R715)
Processor AMD Ryzen 9 5900HX
Motherboard AMD Promontory / Bixby FCH
Cooling Acer Nitro Sense
Memory 32 GB
Video Card(s) AMD Radeon Graphics (Cezanne) / NVIDIA RTX 3080 Laptop GPU
Storage WDC PC SN530 SDBPNPZ
Display(s) BOE CQ NE156QHM-NY3
Software Windows 11 beta channel
526.47 Open Issues:
  • Desktop Window Manager (dwm.exe) service may report higher GPU usage on some RTX 30-series configurations [3830387] -> Workaround: disable Hardware-accelerated GPU Scheduling from the Windows Settings
GeForce Hotfix display driver version 526.61
  • GPU stuck in P0 state after exiting certain games. [3846389]
yoni280
5 (0.01/day)
22,203 (3.44/day)
Olympia, WA
System Name Pioneer
I don't understand what you mean by cpu gpu issue, can you elaborate/explain a bit more?
yoni280
5 (0.01/day)
Yes, my "Intel(R) UHD Graphics" have 0% usage, nothing use it, everything is on my gpu
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
There are no internal switch in a desktop motherboard. So you'd have to use a separate monitor.
If you really want to overcomplicate things you could use another input on your monitor (assuming you have more available) and switch between them for desktop/gaming duties. But that would get old real fast imho.
22,203 (3.44/day)
Olympia, WA
System Name Pioneer
That's normal. You use your gpu or integrated graphics card, but not both. The way it is running is optimal (the gpu has more power so it is chosen).
Solaris17
Super Dainty Moderator
27,608 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
This. The same happens to me it’s the nvidia driver and the windows task scheduler. The issue is that task scheduler isn’t taking into consideration relative usage.
So when we are in idle state say 210mhz and watching a video or 3d effects (desktop display manager) task manager shows that as heavy load because the GPU is at like 200mhz.
Nvidia plans to fix this but there is a horrid driver that may help (it didn’t in my case)
Edit in my phone didn’t see this was taken care of
22,203 (3.44/day)
Olympia, WA
System Name Pioneer
Solaris17
27,608 (3.84/day)
Alabama
VR HMD Quest 3
StephanS
1 (0.00/day)
I disagree that your card is not actually being used due this bug as stated above. Set the energy mode to normal instead of performance in the nvidia control panel (reboot your pc). You will notice your idle gpu temp will drop by 15-20c while idle. Also take a look at the taskmanager and you see the gpu will settle after activity at around 5%. This will also have affect on your gaming performance and temps. The Nvidia driver releases after version 517.48 all have this same issue.
yoni280
5 (0.01/day)
It's already on normal mod
