My new build won't start, please help!
Heroic
34 (0.01/day)
Hi guys,
I built my first computer not just on "paper" but by hands, but after putting everything together, nothing happens when I push the ON button.. I build it very carefully with my wrist grounded. The build is:
Intel DX79SI, i7-3820K LGA2011 with Arctic Cooler I30, Gigabyte 670 GTX 2GB, 2x4GB DDR3 Kingston 2400MHz, FSP700-808PN, with 120GB OCZ SSD and all placed in HAF 912 Plus..
The thing is that when I turn on the back power button on Power supply, MOBO starts to light in 3 places... red=the power button, green=the restart button on its right and another green LED shines on the left side of both.. Then when I turn on the power button the Power Supply fan slightly moves and stops, returning to its original place.. then nothing... it is dead..
Do you have some ideas whats wrong and what should I do? Thank you guys
Heroic
12,172 (1.71/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Make sure everything is plugged in correctly for power, and if that fails try a BIOS reset.
manofthem
WCG-TPU Team All-Star!
10,960 (2.10/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Something grounding out? Make sure your motherboard is screwed in correctly with the standoffs all installed.
Heroic
34 (0.01/day)
Yeah, that's maybe the problem.. I'm not sure if everything is plugged right.. I'mm pretty sure about the front panel and main 2x12 power cable, but for CPU supply I had to put two 2x2 cables to make 2x4.. another option is to make 2x4 from 1x2 + 3x2..
There is the GPU too.. the card has 2 power slots on its side (2x3 and 2x4)..
Heroic
34 (0.01/day)
The MOBO is screwed to the case by 9 metal screws with metal extenders.. Or should it be grounded differently?
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Your PSU only has one PCI-E power connector and you need two for your video card. You need a different PSU.
669 (0.13/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
give it a good COLD boot... LMAO... sorry... could not resist. (hey, at least there was not any smoke!)
anyways... reseat everything... check that the ram is seated properly... check that all of the components are in working condition... yes its something that you assume, but when you are troubleshooting, everything is suspect.
so, start at the psu, and work from there...
upon reading an intel manual, amazed me with the number of post stages that there are... problem is you may need a POST code reader...
Heroic
34 (0.01/day)
Oh... f*ck up... okay, can you tell me which one could be good for this build? Thanks
UbErN00b
255 (0.06/day)
Ingerland
System Name le me gaming and porn rig!!
Processor 2500k
Motherboard GA-Z68X-UD3-b3
Cooling Air baby!
Memory 8GB 2000mhz dual channel
Video Card(s) Sapphire Vapor X HD 7950 3GB
Storage Corsair Force 3 240GB & 2TB HDD
Display(s) Catleap 1440p ;)
Case CM Storm Sniper
Audio Device(s) HUD-MX1 headphone amp/DAC
Power Supply Corsair TX750
This, why have you used such an old PSU (if it's the correct one I am thinking featured here: http://xsreviews.co.uk/reviews/power-supply-units/fsp-epsilon-700w/ ) for a new high end build? and the card has a 6pin and 8 pin pcie connectors not 2x3 and 2x4. You need a PSU with 2x8pin. Any modern good branded 600w PSU should be fine, look at Corsair, Seasonic, Antec etc.
374 (0.07/day)
Netherlands
Processor Core i5 4690K @ 3.5 GHz \\ C2Q Q6600 @ 3.4 GHz
Motherboard Gigabyte GA-Z97X-Gaming 3 SLI \\ Asus P5K Deluxe
Cooling Thermaltake Water 3.0 Performer \\ Xigmatek Dark Knight
Memory Crucial Ballistix Sport 2x 4GB \\ Corsair XMS2 2x 2 GB
Video Card(s) GIGABYTE GTX 970 G1 Gaming v1.1 (Hynix) \\ Sapphire HD 6850
Storage Kingston SV200, 3 TB Seagate 7200.14 \\ 2x 320 GB WD Blue
Display(s) LG 24MP56HQ
Case Corsair Carbide 200R Windowed \\ CM 690
Audio Device(s) Realtek ALC1150 \\ Audigy 2 ZS
Power Supply Adata HM850 \\ Corsair HX520
Mouse Logitech G602, SteelSeries Sensei Raw Frostblue, Corsair M65
Keyboard Logitech Media Keyboard Elite
Software Windows 10 Pro x64 \\ Windows 7 Ultimate x64
For the time-being, try to rebuild the system with less hardware/components, e.g. just motherboard + cpu + ram + PSU + LCD monitor; then try to boot up the system and see if you can go to the bios. If you can shut down and install the rest of the hardware into the PC.
Also make sure you attach the correct cables for Power button, reset button etc., though you can use the power/reset buttons on the motherboard for the time-being. Furthermore, make sure you have plug in the PSU's 8-pin eps cable into the 8-pin CPU power-connector on the motherboard, besides the 24 pin 12V ATX power-connector.
Heroic
34 (0.01/day)
I see it now.. Thanks for explaining me.. My friend helped me with choosing the supply, I trusted him.. so the 8 pin, more clever now, thanks
UbErN00b
255 (0.06/day)
Ingerland
Processor 2500k
Cooling Air baby!
Where are you from and where do you normally buy your components from, I will have a look for some suitable PSU's for you :)
And your friend is a n00b, give him a slap when you see him next :slap: :roll:
DOM
7,628 (1.10/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
Heroic
34 (0.01/day)
Nah, he's good friend :) I already forgave him.. I'm from Prague, Czech Republic.. you already know the build... and I'd like to buy it in www.alza.cz it is little bit more expensive, but great service.. Thanks!
374 (0.07/day)
Netherlands
Is this one the Fortron PSU you mentioned? If it is, then you have 2x 6+2 pin PCI-E power-connectors. Check your Fortron PSU before buying a new one.
UbErN00b
255 (0.06/day)
Ingerland
Processor 2500k
Cooling Air baby!
Nice find, hopefully this is the case and he won't have to buy a new one :toast:
Heroic
34 (0.01/day)
Yes, it is....... Then, where is the problem? ok, the GPU card has 6pin put in and 8pin reduction to 2 molexes.. so should I change the molexes to 6+2? and how? the +2 from right side?
UbErN00b
255 (0.06/day)
Ingerland
Processor 2500k
Cooling Air baby!
You don't need to use molex, you have the correct 6+2 pin pcie cables, you should plug them direct into your GPU.
Heroic
34 (0.01/day)
Ok that didn't help.. the GPU is well placed now.. the CPU doesn't have any other options too... my friend is not a retard (thank god).. so I'm going to sleep, continue tomorrow maybe removing the GPU card and try it without how TC-man said.. Thanks for help :)
374 (0.07/day)
Netherlands
I guess you have the Gigabyte GTX670 Windforce model, hence the requirement for a 8 pin & 6-pin PCI-E power connectors instead of two 6-pin PCI-E power connectors). Anyway, if that PSU is the one you have, then you can use the 2+6-pin and another 6-pin (without using the extra 2-pin that's attached with it) PCI-E power connector to connect it to the VGA card, so you don't have to use some molex adapter.
Heroic
34 (0.01/day)
That's what I did exactly, so it seems solution lies elsewhere... Could it be that PSU is overloaded or something?
2,668 (0.42/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
Is the PSU !!
You need a decent PSU for that build !
446 (0.09/day)
Santa Ana, Ca.
System Name Mobydick
Processor Intel i7 2600k @ 4.4
Motherboard MSI M Power
Cooling CM TPC 812
Memory patriot 8gb x 2
Video Card(s) EVGA GTX 970
Storage Kingston hyper x 3k 120ssd,Samsung 256ssd, seagate 750gb green
Display(s) Benq XL2720Z
Case Haf X
Audio Device(s) creative soundblast xz
Power Supply EVGA G2 850w
Mouse deathadder chroma
Keyboard logitech g710
Software Windows 7 64bit
make sure those little small connectors are plugged in right, you know the ones that control the leds on the power button. this happened to me earlier, had that little pin plugged in a different way.
Heroic
34 (0.01/day)
I unplugged them all, tried to start the MOBO with the start button and the same story happened :(
We discussed the PSU before, this one should be okay..
1,259 (0.24/day)
So many things can go wrong when assembling a build, and it can happen to experienced builders as well, so don't get discouraged:)
Perhaps a few pictures could help a lot to spot a badly placed cable or other errors you might made.
Also: this is from the manual of your motherboard, I wonder if it helps to track down the problem:
Code:
[I][B]Table 18. Front-panel Power LED Blink Codes[/B][/I]
[B]Processor initialization complete:[/B] On when the system powers up, then off for 0.5 seconds.
[B]POST complete:[/B] On when the system powers up, then off for 0.5 seconds.
[B]BIOS update in progress:[/B] Off when the update begins, then on for 0.5 seconds, then off for 0.5 seconds. The pattern repeats until the BIOS update is complete.
[B]Video error:[/B] On-off (0.5 seconds each) two times, then 3.0 second pause (off), entire pattern repeats (blink and pause) until the system is powered off.
[B]Memory error:[/B] On-off (0.5 seconds each) three times, then 3.0 second pause (off), entire pattern repeats (blinks and pause) until the system is powered off.
[B]Thermal trip warning:[/B] On-off (0.5 seconds each) four times, then 3.0 second pause (off), entire pattern repeats (blinks and pause) until the sixteenth blink, then ends.
