dvxtawa5lrwb
- Jun 1, 2025
- 17 (1.00/day)
System Name | Aged Veteran |
Processor | Ryzen 5 5600 |
Motherboard | Aorus X370 Gaming 5 |
Cooling | Cooler Master ML240L V2 |
Memory | 3200mhz CL16 Silicon Power (2 X 16GB) |
Video Card(s) | Aorus 5700 XT |
Storage | Samsung 970 Evo Plus 500GB + Crucial P3 1TB |
Display(s) | XG2431 |
Case | Cooler Master MB TG520 |
Audio Device(s) | HyperX Cloud Alpha |
Power Supply | AP850GM |
Mouse | LAMZU Maya X |
Keyboard | Redragon K614 |
Software | Windows 11 Home |
Benchmark Scores | 4.7GHZ on the CPU at 1.3 Volts |
As long as the performance is stable, you'll be fine. For reference;GPU-Z says my GPU technology is 5 nm, AIDA64 says it's 4 nm. Should I worry about it?
I was wondering if they sold me another model but replaced their BIOS to 4060 or something and that's why it's showing it wrong.As long as the performance is stable, you'll be fine. For reference;
NVIDIA GeForce RTX 4060 Specs
NVIDIA AD107, 2460 MHz, 3072 Cores, 96 TMUs, 48 ROPs, 8192 MB GDDR6, 2125 MHz, 128 bitwww.techpowerup.com
A thorough insight into technical specs and benchmarks of RTX 4060.technical.city
All of these sources seem to agree that 5nm is the correct process node.GeForce RTX 40 series - Wikipedia
en.wikipedia.org
System Name | Gaming rig |
Processor | AMD Ryzen 7 5900X |
Motherboard | Asus X570-Plus TUF /w "passive" chipset mod |
Cooling | Noctua NH-D15S |
Memory | Crucial Ballistix Sport LT 2x16GB 3200C16 @3600C16 |
Video Card(s) | MSI RTX 3060 TI Gaming X Trio |
Storage | Samsung 970 Pro 1TB, Crucial MX500 2TB, Samsung 860 QVO 4TB |
Display(s) | Samsung C32HG7x |
Case | Fractal Design Define R5 |
Audio Device(s) | Asus Xonar Essence STX |
Power Supply | Corsair RM850i 850W |
Mouse | Logitech G502 Hero |
Keyboard | Logitech G710+ |
Software | Windows 10 Pro |
Scores are higher than average, can we call it okay then?Run some test like 3d mark etc to see if the performance is about what it should be for that card, if you are worried.
Processor | Ryzen 7 5700X |
Memory | 48 GB |
Video Card(s) | RTX 4080 |
Storage | 2x HDD RAID 1, 3x M.2 NVMe |
Display(s) | 30" 2560x1600 + 19" 1280x1024 |
Software | Windows 10 64-bit |
As other mentioned, this is just a table lookup. Some extra context "Blackwell is built on the same 5 nanometer "NVIDIA 4N" TSMC node as last generation's Ada. NVIDIA claims this is a "4 nanometer process," but during Ada it was confirmed that NVIDIA 4N is actually not TSMC N4 (note the order of N and 4), but 5 nanometer. At the end of the day the actual number doesn't matter much, what's important is that NVIDIA is using the same process node."GPU-Z says my GPU technology is 5 nm, AIDA64 says it's 4 nm. Should I worry about it?
System Name | Karen |
Motherboard | MSI Mag X670E Tomahawk WiFi |
Cooling | Thermalright PS120SE |
Video Card(s) | Sapphire Pulse 9070 XT |
Storage | Yes |
Case | Corsair 4000D |
Power Supply | Corsair RM850x |
Memory | 48 GB |
NoIs it even possible to detect the process node of a GPU by software?
No, you're fine. There would have been more serious problems if you had been sent a BIOS-jacked card.I was wondering if they sold me another model but replaced their BIOS to 4060 or something and that's why it's showing it wrong.
